HELP PLS- Prius won't turn on!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Lexi_1297, Apr 16, 2020.
  1. Lexi_1297
    Lexi_1297 Junior Member
    Kansas City, MO
    I
    So a couple days ago, my brakes were making a grinding noise when I pressed the brake pedals. I drove the 8 minutes it took to get home and made an appointment to get my brakes fixed.
    Today, I got in my car to take it to the shop and my car isn't working. When I press the brake and push power, the car stays in accessory mode as if I never hit the breaks while I was pushing power. The dash comes on, the power locks work, the key fob works, and the windows roll down. But it won't shift into any gear, the power button light is orange, the air won't come on, the radio won't play any sound, and a lot of dash warning lights are on. Hoping someone might know what this could be before I have it towed to the garage! Thanks for any info!!
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Check battery voltage
    pjksr02 and Lexi_1297 like this.
  3. Rebound
    Rebound Senior Member
    3,964
    2,612
    Portland, OR
    Yup, you might need a new 12V battery
    49,371
    make sure the brake lights come on when stepping on the pedal
  5. RustyNaki
    RustyNaki New Member
    Taranaki
    2012 Aqua
    Did you get an outcome from this? My aqua is doing something similar
