Help! POA92/INF126
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by B Estel, Jan 20, 2019.
Tags:
  1. B Estel
    B Estel New Member
    Norge, VA
    My friend JUST BOUGHT a 2008 Prius 163,000 miles. We have proof of PERFECT maintenance since original purchase. However, after a few weeks it went into limp home mode while driving about 45 mph. Zero signs of anything unusual beforehand. The dealership said they couldn't read the codes without replacing the 12v battery (really?). Codes downloaded by Toyota dealership are POA92/INF 126. I've read on this site that POA92 is either transmission/transaxle or inverter? They are saying it's a transmission issue and estimate $2500-$5000. Can anyone give any additional insight? The car purchase price is the same as the high estimate!!! When we start the car, there is now an obvious noise from the engine (or a fan?) where before it was completely silent when started - that doesn't seem like a transmission issue?
    #1 B Estel, Jan 20, 2019
  2. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Welcome to PriusChat!!
    Sorry to hear about your friends unfortunate used vehicle purchase :(
    You can check the vehicle service history by entering the VIN at http://www.toyota.com/owners/my-vehicle
    Not sure if this link (below) will offer additional insight, or possibly confirmation on the noise(s) you are hearing.
    Gen 2 Prius (2004-2009) Transmission Failure, P0AA6, P0A92, P0A7A - Luscious Garage | Hybrid Specialists
    Can you please confirm that INF code again.
    Please report back here with any updates (y)
    Skibob and Raytheeagle like this.
  3. B Estel
    B Estel New Member
    Norge, VA
    Sorry, the POA92 INF CODE was 261. Now it's also reporting code P3191, POAOF, P0102, P0113, P0351-354, P0102, B1400, B1421, C1259, C1310. The mechanic said he cleaned oil from intake manifold that he says damaged engine. He showed me compression numbers for cylinder; I can't remember exact numbers but they were lower but not terrible. They are recommending we replace both the engine and the transmission. It's hard to believe there could just be a catastrophic failure. Maintenance entire life of vehicle is exceptional and the car was not using oil, gas mileage was phenomenal, no indications of transmission issues before all this started. So, 2 questions: 1) Is it possible that I really need both an engine and a transmission (ref codes and details above) and 2) if car is in good shape otherwise, is it worth it to put $5500 into a 2008 Prius?
  4. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    Can you please clarify, do you have more than one mechanic involved here? Did the Toyota dealership that gave you the P0A92-261 diagnosis the same one who said he cleaned oil from intake manifold that he says damaged engine?
    Have you had two scans? The first one gave you the P0A92-261? Were there any other codes in this scan?
    The second scan gave you P3191, P0A0F, P0102, P0113, P0351-354, P0102, B1400, B1421, C1259, C1310, but not a P0A92-261?
    I'm finding it a little hard to decipher, so can you please be very precise with the information you're posting.
    #4 dolj, Jan 31, 2019
  5. bisco
    51,140
    are your two threads two different 2008's?
    Raytheeagle likes this.
  6. dolj
    dolj Senior Member
    8,209
    4,180
    Possibly.
    This one (the friend's):
    The other one:
    Good spotting bisco, I didn't notice the miles. Apart from the miles, both threads read like it's the same car.
    Curious how they both have a P0A92-126. :whistle:
    #6 dolj, Jan 31, 2019
    Raytheeagle and bisco like this.
  7. bisco
    51,140
    @Skibob hooked me up in the other thread :p
    Skibob likes this.
  8. Skibob
    Skibob Senior Member
    2,912
    1,502
    Northern California
    I saw that too. There can’t be 2 cars with the same problems. Just 1 confused OP
  9. Yaga1973
    Yaga1973 Junior Member
    Oklahoma City, OK
    And the mystery continues in both threads....
  10. B Estel
    B Estel New Member
    Norge, VA
    same car, escalating issues
  11. B Estel
    B Estel New Member
    Norge, VA
    Sorry! Here's full story, chronologically: Prius (2008) with perfect maintenance record and no hints of any issues went into limp mode at 45 mph, we drove it to nearby Toyota dealer about 5 miles away. Dealer said they couldn't read the codes because 12v battery was bad so they replaced it, charged up $450 for supposedly new battery plus unclear misc. We got scalped. Drove away and car went back into limp mode within a few miles. Returned and the Toyota dealer then reported we needed a new transmission for $5200. We asked for full report but they only gave us a summary with P0A92-261 codes. They didn't exactly build trust or confidence with us, so we had it towed to a certified Toyota mechanic in town. He said he got over 20 codes, oil was low, and he found oil in manifold but not enough to explain how low the dipstick indicator was; he also told us the compression was on low side on all 4 cylinders. He says both engine and transmission need to be replaced. With used parts and labor guaranteed for 3 years, he wants $5400. We paid $5000 to purchase the car just 1 month ago. The previous owner is a good friend, and I am 100% positive she maintained it to perfection - thus why we bought it. It broke down before we could even make the first payment on the loan. We're devastated and don't know whether to give up on it or fix it. My questions: 1) Does any of this sound plausible for a car is great shape - do Prius have catastrophic failures like this?! Most importantly 2) could driving it away from the dealer after the first mechanic looked at it have damaged the engine and thus could the dealership have caused these issues? 3) would you keep the car if it was repaired with parts guaranteed for either 1 year (cheapest options), or 3 years? Thanks for everyone's patience and thoughts!
  12. B Estel
    B Estel New Member
    Norge, VA
    Sorry, got the miles wrong the first time. :(
  13. bisco
    51,140
    can you return it?
    Skibob, SFO and Rmay635703 like this.
  14. Skibob
    2,912
    1,502
    Northern California
    It’s not unusual for a Prius with that mileage to burn oil. The level gets low because everyone thinks it like every other Toyota and never checks the oil. What are the compression numbers? What are the 20 codes? People here need that information if you are going to get any help.
  15. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    So looking at the codes, I see the following. Poor engine power, engine failed to start, mass air flow, intake air temp, coil primary circuit 1-4, then ABS/Power Steering faults. The C1259/C1310 are commonly set when the 12v fails. So the other codes, mass air flow, intake air, coil primary circuits were probably the result of doing a compression test. That leaves the P3191 and P0A0F. Poor engine power, and fails to start. If this were my car, I’d reset the codes(with a scanner, not unplugging the 12v), and drive it until the triangle or check engine light came back.
    Is this a Gen 2 where the ICE is just worn out, or is it a Gen 2 that has a dying hybrid battery. The compression test numbers would tell us a lot. It takes 90 or so psi for combustion to occur. Toyota specification is 99-128, with no more then 14psi variance.
    So compression test results are the key.
    Yaga1973 likes this.
