Help! Prius 2007 error with P0A78 P0A7A P0A94 PA040 PA041
Discussion in 'Gen 2 Prius Main Forum' started by Sun Chanras, Jun 16, 2018.
  1. Sun Chanras
    Sun Chanras Junior Member
    Phnom Penh
    My Prius 2007 was jerky on acceleration and traction control came out all the time. When I started accelerating fast, the car was error in complete error(show engine check,vsc,abs, red triangle ) , engine rev up, the car can be driven again after stopped and started again. I had the car scanned at dealer it show P0A78 P0A7A P0A94 PA040 PA041
    The codes show that the problem related to inverter and transmission
    1. This problem can be also cause by 12V Aux Battery ? because I can notice my 12V aux battery is very weak at some time.
    2. Or cause by inverter overhead due to short circuit somewhere that lead inverter/converter work harder to convert electric energy to charge 12v battery ?
    Thanks
  2. SFO
    SFO Senior Member
    5,302
    4,243
    Northern California
    It would help narrow down the trouble if you could also supply the three digit INF (subcode) related to any of the thrown DTCs.
    Click on the little flower (or cloud) looking icon to the left of the DTC, then post both the DTC code with its associated INF(s) please.
    Sun Chanras and Raytheeagle like this.
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,379
    3,238
    Madison, Wisconsin
    I would always start with a good 12v battery.
    Bit realistically your problem maybbe much worse.
    Sun Chanras likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,075
    Columbia, SC
    Gulp, I'm showing 25 possible subcodes for the P0A78, 14 for the P0A7A, 25 for the P0A94.
    Almost all of them list the HV ecu or inverter/converter as a possibility, along with wiring/connectors, motor, transaxle, etc. Sounds like it's going to be a bad day.......
    SFO, Sun Chanras and Raytheeagle like this.
  5. Sun Chanras
    Phnom Penh
    Thanks all guys, I will check three digit INF (subcode), to narrow down the problem.
  6. Sun Chanras
    Phnom Penh
    The problems come from one of the radiator fans was stalled and the inverter was trying harder to supply power to the stalled inverter until it overheat and shutdown the inverter. After disconnected the stalled radiator fan, the car run find.
    Thanks all for taking time help with the issue.
    Thanks,
    txducker and SFO like this.
  7. TMR-JWAP
    6,404
    6,075
    Columbia, SC
    Isn't that interesting. Learn something new every day.
    Thanks for posting your findings. it's always good to hear when a solution is found, especially when it's something a bit uncommon.
  8. Sun Chanras
    Phnom Penh
    @TMR-JWAP the dealer said I have to replace inverter and transmission, but it was too much expensive, so I tried to find the solution on my own, luckily I fixed the problem by myself for just few bucks.
    SFO and MGpwr like this.
  9. French_doctor
    French_doctor New Member
    France
    Hello ! First sorry for my bad english !
    I think i have the same problem ! Could you please explain me how disconnect stalled radiator please ? Did you have change it yourself ? Have you references or the radiator ?
    Thank you ! I'm on an island and my prius is stopped : i can't go home with the ferry boat. Please help !
