HELP!! Prius is restarting on its own.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by devinb72, Jun 23, 2012.
  1. devinb72
    devinb72 Junior Member
    Ohio
    I am having some electrical?? problems with my Prius. Here is whats going on:
    • I turn the car off and 1 of 3 things happen.
    1. Nothing and everything is fine.
    2. It restarts itself instantly and everything is reset ( radio stations, gas gauge, MPG info )
    3. I shut the door and start to walk away and it restarts ( and everything in 2 )
    • Just like number 2, everything just resets ( it looses it's memory) but it doesn't restart.
    • Or I get in the car and nothing happens at all. I sit there push the power button NOTHING, no lights, no panel lights, no response whatsoever. At this point I usually just wait and keep pushing it until it finally starts. Sometimes if I shut the door hard it will come back to life, but not always.
    My first thought was the 12v battery, but I ran the checker on the car and it seems fine, I also had it checked at Midas and they said that it was fine.
    I feel like the car is possessed or something. It doesn't always happen but today it happened 8 times, and that's just effin annoying.
    I know I will probably have to have it looked at, but they want to charge me $100 an hour for diagnostic work. REALLY?? $100 an hr, and I know that they're just going to stand around the car with there thumb up there butt. OR my car won't restart it's self and I will have wasted $200 on nothing.
    So can someone please tell me what is wrong or might be wrong. I kind of looked around and couldn't find anything that was similar to my situation.
  2. richard schumacher
    7,663
    1,038
    United States
    1st guess: loose battery cable(s). Check the clamps on the battery terminals and the connection of the negative cable to the stud on the car body, which is in the same battery compartment. Careful with the wrenches, you really don't want to short the positive terminal or cable to anything else.
  3. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    It could also be the battery. Is yours the original? A shorting cell could cause it to behave like you described.
  4. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    I would check the 12v after sitting all night. Should have 12V plus. H
  5. Oldwolf
    Oldwolf Prius Enthusiast
    816
    107
    NC
    2016 Prius v wagon
    Here is a SOC chart.
  6. ursle
    ursle Gas miser
    1,049
    192
    NH
    Do you have a practical joker around, someone that installed a remote starter and is playing with you?
    Or did the car come with a remote start option and someone has an extra set of keys?
  7. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Oh really? Are you certain about this? Where did you learn this nugget of information?
    If this were the case, all I'd have to do is fiddle with a random Prius's battery cable and I could drive away in it.
    Something tells me this isn't how the car was designed...
  8. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Midas would not be my first choice for Prius maintenance, of any kind! You say Midas checked the battery, how? Do you have a Voltmeter? If so all you need to do is measure the battery yourself. the above chart gives the voltages. If it is in fact the original battery I would proactively dump it, get an Optima made for the Prius. Check Specializing in: dictionaries including the Collins Cobuild, Oxford English Dictionary (OED), Webster's & Random House The suggestion to check the battery cables is a very valid point. Check for corrosion, loose cables, green copper patina, water is getting on the cables causing them to oxidize. make sure the ground is securely tightened to the body of the cay. If you have a meter, measure the ohmic value. anything more than 0 for such a short ground wire is wrong!
    At some point if the above ideas don't take care of the problem, a trip to Toyota may be in order!
    Let us know what you find out!
  9. devinb72
    Ohio
    But I was thinking, if the battery was dead and would not start the car, how does it start eventually. ( Get in, car won't start or show signs it's trying, then all of a sudden it's good to go and were off ) it's not like the battery can charge itself. It has happened multiple times before. BUT today I had to call roadside assistance and get a jump.
    But I think I just need to get a new battery. Does anyone know if easycare will cover the cost of a new battery? Is the Optima battery really better than an OEM and are there people on here that have it?
  10. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yes, plenty of folks have the Optima Yellow Top battery, including me.
  11. HaroldW
    716
    95
    It does not use the 12V to start the car, but if the 12V is week the cars PC will not work! The PC is the cars brain. H
  12. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Me too. Have changed to that two years. Working fine.
  13. richard schumacher
    7,663
    1,038
    United States
    You're quite right, a dead battery will never start any car. That would be the effect of a loose cable or clamp: it makes intermittent contact. Would you rather start by spending 10 minutes checking for loose connections, or $200 on a new battery that you might not need?
  14. devinb72
    Ohio
    I already checked the cables and the connections. The battery voltage on the Prius screen is in the low 12v and when using the windows it drops to around 11.6v. I already bought the Optima battery, got it today actually.
    Is there anything special that needs done or is it ready to go. This is the direct fit model.
  15. devinb72
    Ohio
    Nevermind I got it installed. Just need to wait and see if any of this freaky stuff happens again.
  16. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Wish you good luck.
  17. KK6PD
    4,003
    944
    118
    Well it's been almost a week, the Optima must have done the job!
  18. richard schumacher
    7,663
    1,038
    United States
    At least we know all the connections are now tight :_>
    "Is it ready to go" depends somewhat on where you bought it. eLearnaid has been very good about fully charging them immediately before shipment; other suppliers, maybe not so much. It is prudent to check the voltage before installation to make sure it's fully charged, and if not either return it or charge it yourself outside the car. The Prius charging system is pretty low current and may not deal well with a battery with a low initial charge, which doesn't do anything good for that battery's life.
  19. devinb72
    Ohio
    Yep, everything is working fine now, no issues whatsoever.
  20. devinb72
    Ohio
    Thanks for all the help.
