Help! Prius v won't turn on!
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by darkleafar, Sep 1, 2014.
  1. darkleafar
    darkleafar Member
    232
    Houston TX
    This morning when trying to leave for work, my prius refused to turn on. When you press the brake so you can press the start button, the brake feels extremely hard, almost like it doesn't want you to press it. The light on the start button becomes orange after a pressing the button once. And on the dashboard screen (I don't know what call it on a Prius) in the very bottom right corner, a red notifications light flashes very quickly, so quickly that is hard to tell what it is, but by staring at it for like 30 seconds it looks like the symbol of a car with a lock attached to it. I may be wrong though. My Prius v is a 2012 model, trim three, and it has a little over 60,000 miles on it. I also have a prepaid maintenance through the dealership. Advice, please? I don't even know where to start. Thank you very much for your time.
  2. darkleafar
    darkleafar Member
    232
    Houston TX
    Also its been a while since I posted here, and I'm noticing there seems to be a difference between lower case v and upper case V Prius. Mine is the "wagon style" Prius, trim "three", first of its kind in 2012
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Try placing your fob right next to the power button, it may have a dead battery.
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  5. darkleafar
    darkleafar Member
    232
    Houston TX
    I tried two different key fobs. However, they were both obtained at the same time. I guess it could make sense for the battery to go out at the same time on both? I did place the key fob right next to the power button and it didn't work though.
  6. Mike500
    Mike500 Senior Member
    2,593
    766
    JimboPalmer likes this.
  7. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  8. bisco
    51,141
    and if it's not your fob, try testing your 12 volt battery.
  9. darkleafar
    darkleafar Member
    232
    Houston TX
    So I ended buying the Optima auto battery 46b24r, for 219 at autozone. Yes I know it's cheaper online but I need my car functioning by tomorrow morning and all local shops had the same price... Sigh.
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    And ... ?
    By the way, the OEM 12v at the dealership is ~ $190 and now carries a 7 year warranty. This might be the only instance where a trip to the dealership will save some money and get you a superior part.
  11. SageBrush
    11,627
    2,533
    Southwest Colorado
    Hint for alarms that blink too fast to read: Shoot a short video with your smartphone, then look frame by frame until the item is seen.
    LisaMarli likes this.
  12. darkleafar
    darkleafar Member
    232
    Houston TX
    ... And it worked. It was totally the battery. Since its labor day, dealership service center was closed... As much as I would have wanted to shop around for a battery, my car is a lifeline and waiting was not an option
  13. Mike500
    2,593
    766
  14. Makaru
    Makaru Junior Member
    51
    2013 Prius v wagon
    2 years seems a very short lifetime for a car battery, does it not?
  15. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Its all relative. Variables (in order of importance) are: use/abuse of the battery, temperature of the battery, quality of the battery and any defects.
    OEM batteries are the cheapest of the cheap.
  16. SageBrush
    11,627
    2,533
    Southwest Colorado
    How many times was the battery drained ?
  17. Makaru
    51
    2013 Prius v wagon
    True enough, but I have had OEM batteries last 8 years plus in a vehicle. 2 years is far shorter than the norm.
