HELP - Quick answer needed....Inverter fluid vs radiator coolant?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by seeh2o, Dec 1, 2008.
  1. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    I have a 2004 Prius. Is the coolant for the inverter the same as the coolant for the gas engine? I know they are both pink/red. I've read here they are different coolants, but I just talked to a Toyota service dept. and was told they are the exact same coolant, SLLC, I believe.
    I was putting in windshield washer fluid and noticed that the inverter reservoir was below low, then I opened the ICE engine coolant reservoir and I couldn't see anything. I am currently out of town and am going to be driving about 300 miles in the next few hours, so I don't have the luxury of taking the car in right now, but I could run over to the dealership and buy a gallon of the red stuff.
  2. seeh2o
    seeh2o Prius OG
    447
    16
    City of Angels
    Nevermind...Galaxee to the rescue (again). Tis the same stuff. WHEW!
  3. tochatihu
    tochatihu Senior Member
    9,058
    3,529
    Kunming Yunnan China
    2001 Prius
    I see that you will be topping off both reservoirs and then taking a long trip. Please check the fluid levels of both, as frequently as you can bear to, during th etrip. If you have a fluid leak in either system, it must be corrected without delay. Especially on the electricals side!
  4. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
    The Toyota SLLC is pink, not red, and prepare to pay dearly for it ($23 for a gallon of pre-diluted). The premium Prestone concentrate is only about $10 a gallon (makes 2 gallons of 50/50 mix), with the same specs as the SLLC.
    fish1236 likes this.
