Help=RAT Ate part of the Hose from windshield water tank,how do I Fix it?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Jun 30, 2018.
  1. ski.dive
    ski.dive Active Member
    900
    233
    Hutchinson Island,FL. Mt. Snow,VT
    Help=
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    I’d get more hose / tubing / splicing supplies from a home improvement store and install;).
    You seem to have a rash of issues with your Prius :whistle:.
    Good luck and keep us posted (y).
    milkman44 likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,790
    2017 Prius c
    Replace the whole hose.
    Available at any auto parts store.
    Then put out some rat poison in tamper proof bait stations.
  4. Mendel Leisk
    38,789
    The hose are the rat? :)
    I've read rodents don't like peppermint oil?
  5. MickyMatter
    MickyMatter Active Member
    260
    166
    Germany
  6. Mendel Leisk
    38,789
    Interesting. I'm always leary of something using voltage when the car's off though. I ran the pdf manual through a translator; here's the opening paragraph:
    The full pdf attached:
    SFO likes this.
  7. Leadfoot J. McCoalroller
    7,203
    6,754
    Pennsylvania
    2018 Prius c
    Neat gadget! You can get solar powered ultrasonic pest control. It won't be packaged for automotive use, but it wouldn't take much to fashion a bracket for mounting.
  8. milkman44
    milkman44 Active Member
    591
    386
    Ky
  9. Leadfoot J. McCoalroller
    7,203
    6,754
    Pennsylvania
    2018 Prius c
  10. Leadfoot J. McCoalroller
    7,203
    6,754
    Pennsylvania
    2018 Prius c
    That tubing is generic, but you might have an easier time of it by using metric sizes- you're less likely to find that at a home improvement store, but most auto parts stores will sell it cheaply from a big spool. Just make sure you tell them it's for the washer, you certainly don't need expensive pressure or fuel rated stuff.
    ITBland likes this.
  11. bisco
    49,587
  12. DMC-5180
    DMC-5180 Active Member
    292
    134
    How much length got chewed on. If it’s just an inch or so, i’d cut the damage out and splice with a vacuum line splice. Various sizes Available at an auto parts store for cheap.
    iPhone X ?
    Raytheeagle likes this.
