Help removing headlight assemblies...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by treehggr, Feb 5, 2008.
  1. treehggr
    treehggr New Member
    230
    Hello everyone. Is there any documentation out there on how to remove the headlights? I think I read somewhere that you have to remove the whole front bumper cover? Is this true? If so is there maybe a work around to make this go as smoothly and as fast as possible? Thanks for the help, Brandon
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Hey, what are you up to with removing headlight assemblies? Keeping yourself busy?
    I have a repair manual at home to look it up. I'll PM you some info.
  3. Doc Willie
    1,717
    142
    Out there, somewhere
    I do not know the OP's motivation, but according to autopia.com, some detailing chores may be easier if the headlights are removed.
  4. treehggr
    treehggr New Member
    230
    Yeah I'm planning on installing some HID's in the stock assemblies here in the next few days and wanted to get a head start on figuring it all out.
    Thanks usbseawolf2000, I appreciate it. :D
  5. dogfriend
    7,512
    1,185
    Carmichael, CA
    The service manual says to remove the LH and RH front fender liners and then remove the front bumper cover. The reason you have to remove the bumper cover is that there are some screws holding the headlight assembly that are only accessable with the bumper cover off the vehicle.
  6. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    You shouldn't have to remove the entire nose. There's a way
    to detach enough around the fender liner and the end of the
    bumper cover to allow bending the nosepiece aside just enough to
    access that pesky third bolt on the headlight assembly.
    Unfortunately I haven't done it or I'd have shot pictures, but
    I did see some auto techs do it at one of the training classes
    and it didn't take very long. If you pull your fender liner,
    a la this pic, or even just the front part of it, there should
    be some obvious attachment points for the nosepiece.
    _H*
  7. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    you mean drop the nose like this?
    i'll ask DH how he did it.
  8. treehggr
    treehggr New Member
    230
    Yeah it would be nice to not have to remove the bumper cover completely.
    I'd be curious to find out the easiest way possible to remove and reinstall these assemblies. If I could find out which screws to remove to just shift the bumper forward that would be awesome, thanks.
    Thanks everyone for the help so far.
