HELP!!! Slip indicator lights (Hill-start assist) solid on
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hptsang, Nov 8, 2009.
  1. hptsang
    hptsang Member
    139
    Houston, Tx
    I read the http://priuschat.com/forums/gen-iii...6952-slip-indicator-comes-when-full-stop.html but it didn't fix my problem. I was on my drive way the other day installing my fog light stalk switch with my battery disconnected. After I finished the installation, that slip indicator came on. It doesn't beep or flash or anything. I tried the press the brake very hard to turn it off, but it doesn't work. I tried the release the brake but it doesn't do that delay on brake. Is there any way to turn it off?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I wonder if there is a chance you might have crossed or shorted something while you were re-wiring?
    When I was working on my fog mod, I pulled a harness from my ECU to get a better look and I lost all my data on the HSI. Everything but my best tank average and the ODO. All my trip data is gone...:(
  3. ABL
    ABL Member
    163
    30
    San Jose Ca.
    Check under the hood for a blown 10 amp fuse. This happened to me when I was installing mu BU lights
  4. ABL
    ABL Member
    163
    30
    San Jose Ca.
    Sorry BU camera not lights
  5. hptsang
    hptsang Member
    139
    Houston, Tx
    All my trip data is gone too but I know that is just because I disconnected my battery.
  6. hptsang
    hptsang Member
    139
    Houston, Tx
    I will do that tomorrow morning. Thanks
  7. hptsang
    hptsang Member
    139
    Houston, Tx
    Can you tell me Which 10 amp fuse? I couldn't find a blown one
  8. ABL
    ABL Member
    163
    30
    San Jose Ca.
    It was the 10 amp PCU fuse lower right end of the fuse box. I blew it twice and this caused the slip light to remain on until I replaced the fuse. Hope this helps Good luck
    Jim
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Just curious Jim, how did you blow the fuse twice? So I don't do it myself.
  10. ABL
    ABL Member
    163
    30
    San Jose Ca.
    Shorted out the rear cargo lamp (Manual On/Off) switch. Very thin wires.
  11. Tideland Prius
    16,125
    Hmm, mine is exhibiting the same symptoms but this time, it's all the interior lights are off and the slip indicator is solid. I'm having a hard time pulling out Fuse 29 (10A). What's the best way to remove the fuse?
  12. ABL
    ABL Member
    163
    30
    San Jose Ca.
    There should be a fuse puller in the fuse box
    Jim
  13. Tideland Prius
    16,125
    I just found it LOL. I got the fuse out and replaced it. Thanks!
  14. jayvee
    jayvee Member
    341
    89
    WA
    Did this solve the slip indicator on problem?
  15. hptsang
    hptsang Member
    139
    Houston, Tx
    I did both 25 and 29 fuse and still the same
  16. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It's a pain but check them all. Possibly the ones under the dash too.? It seems like this light might be used to indicate other faults.
  17. Tideland Prius
    16,125
    Yup. I got my interior lights back, the cruise is working and the Slip Indicator is off.
  18. hptsang
    hptsang Member
    139
    Houston, Tx
    For my case, everything works fine just the indicator lights is solid on.
  19. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Bummer. If you want that light off you will likely have to have the service dept. track it down for you. Just curious, can you tell if the hill-assist still works (beeps when you hold down the brake pedal for a few seconds)?
  20. hptsang
    hptsang Member
    139
    Houston, Tx
    it doesn't beeps when I hold it down. I am afraid to go to the dealership that I bought my car from, since they refused to turn the seat belt warning beep thing and I used the techstream with the mongoose wire to turn it off myself. I am afraid they will blame it on that, but the light didn't turn on until I was doing that stalk installation for the fog light so I am pretty sure I didn't mess the car up by doing the program myself.
