Help! Something is running in the back of my car.
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Zipy, Jan 4, 2024.
  1. Zipy
    Zipy Junior Member
    22
    Independence, MO
    Just went into my garage to retrieve my keys from my 2016 Prius. Accidentally left them in the tray when I parked it about 5 hours ago. Something was buzzing/running in the back of the car. It wasn’t just the common occasional sounds that they make. It was constant. I got it to stop by starting the car briefly and then shutting it off. Nothing smelled hot. Could it be due to the keys being left in the car for an extended period? Should I be concerned and move it outside for the night?
  2. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    That's the fuel vapor containment/capture system running a self-test. Has nothing to do with fob in the car. Totally normal.
    fotomoto and bisco like this.
  3. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    ^ That.
    Pretty much any year 2000+ gas powered car, about 5 hours after shutdown
  4. Zipy
    Zipy Junior Member
    22
    Independence, MO
    Thanks! Had me worried. Never heard it run constantly like that before.
  5. ChapmanF
    15,614
    The sound is the leak detection pump, and you'll hear it from around seven to around twenty-two minutes, depending on how long step C of the test happens to take.
    mjoo likes this.
  6. Doug McC
    Doug McC Senior Member
    1,004
    377
    Midwest
    2022 Prius
    Check your Owners Manual near the beginning (page 8 in the 2022 manual) under “For Your Information” for an explanation.
  7. Doug McC
    1,004
    377
    Midwest
    2022 Prius
    Could you have made it any more complicated? :)
  8. Mendel Leisk
    38,726
  9. ChapmanF
    15,614
    Probably. Good thing Toyota designed it, not me, huh?
    Doug McC likes this.
