HELP!.... Spark plug Porcelain broke off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Thomas Ziongas, Feb 10, 2014.
  1. Thomas Ziongas
    Thomas Ziongas Junior Member
    So I was changing my spark plugs and 3 of 4 went smooth. but one of them was very tough to get out. after a little while it came out, but.... porcelain was broken up. looked down the hole and saw some pieces. Vacuumed it up with a small hose. saw the pieces come into the vacuum, but i dont think i got them all.
    Started the engine and made a terrible rattle sound. turned it off and researched a bit. one hit was on here from a few years back, saying the car ran rough for a sec and then cleared up. Hoping it was kicked out the exhaust. I started it up let it run and it cleared up and idled smooth.
    Drove it today and seems fine. Slight click noise when accelerating but not sure if that was there before or im just being paranoid now. Called some places and they all said same...could have cleared through exhaust, stuck in catalytic converter, damaged the interior walls etc etc.
    Any help or advise would be appreciated. Thanks
  2. Patrick Wong
    18,200
    6,472
    Not much help can be provided at this point. Just drive the car and as long as it runs, don't worry about it. Worst case, you'll have to replace the engine - but you are a long way from having to take that action.
  3. Thomas Ziongas
    worse case...replace engine. lol not very rewarding for doing your own maintenance. its pathetic that a $7 spark plug is going to cause me this much pain.
  4. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    As Patrick said the worse case is a new engine, but that is most unlikely.
    The fact that the engine runs smoothly is a big plus. Valve damage is the most likely thing to happen when something is dropped in a cylinder, but this is immediately followed by a continuous misfire at low engine speeds.
    A regular check on your oil consumption will tell if there is bore damage, but this is less likely. The CAT will not be damaged or blocked by a small piece of porcelain. If you are worried by this the CAT could be removed and the piece (s) shaken out, but not worth the effort in my opinion.
    John (Britprius)
  5. Thomas Ziongas
    John (Britprius) ,
    so if I do not have a misfire at low speeds and my oil consumption is normal, theoretically I could have gotten lucky and there be no issues?
    Like I stated above, when I first started the engine it was knocking and rattling, but stopped and haven't heard it since. The only thing I notice now is a slight "click click" when accelerating but I think it is just the normal sound....
  6. Britprius
    5,194
    1,914
    Yes valve damage is the most common result in this scenario as the object has to pass through a small gap when the valve is open. This is a very short time period and as the valve shuts it can trap the object under it stopping the valve from closing. The valve is then hit by the rising piston bending it so that it can never close properly again causing compression loss and a misfire.
    If the bore is scored oil is passed up the score mark and burnt in the cylinder. Obviously this causes a higher rate of oil consumption.
    John (Britprius)
  7. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    If you are really worried about it, a mechanic can remove the spark plug and look inside the cylinder with a bore scope, but as others have stated any potential damage was likely done once the engine was started. At this point, just keep your fingers crossed.
  8. Patrick Wong
    18,200
    6,472
    "lol not very rewarding for doing your own maintenance."
    If you DIY, you need to perform the work correctly and use appropriate tools. In this particular case you need a spark plug socket with the rubber insert to protect the porcelain tail. Did you use such a socket?
    Or, you need to figure out that the tail was broken before you fully remove the plug from the hole, so that you could improve your chances of vacuuming up the porcelain bits before they enter the combustion chamber.
    What was the odometer reading when you replaced the spark plugs? Some owners like to defer this work beyond the 120K mile schedule. That just makes it harder to replace the plugs if the threads get seized.
  9. bisco
    49,434
    i think your fine. disregard any 'sounds' you hear, as your imagination will be working overtiime.;)
  10. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    tom,
    its always the cheapest part that causes the most damage or costs the most to replace...
  11. Thomas Ziongas
    Patrick wong,
    yes I used the right socket. Used the right tools and all. Like I said above others came out smooth. Idk how it broke...yes I should have taken a better look before taking them out. Everyone learns at some point. ...also I'm at 119xxx miles. Figured it was about time.
  12. Patrick Wong
    18,200
    6,472
    "Idk how it broke..."
    Usually, this will happen if the socket is tipped at an angle, to put pressure on the porcelain tail. If the spark plug remains coaxial with the socket then the tail will not have any stress placed upon it.
    Anyway, it sounds like your engine is probably OK. Check oil consumption over time and if that remains normal and you don't hear any other noises, you should be good.
  13. Thomas Ziongas
    Thanks for the help. Only concern is this ticking now. Happens when I accelerate. Don't remember it being there. Might bring it in to Toyota. idk.
  14. Thomas Ziongas
    Ok... kinda frustrated . so I took it to Toyota. They couldn't find anything. No damage to the cylinder, no bent valves no porcelain on the top half. They said "the pieces could be on the bottom, or it could be something completely different. The knock is at idle" said it might be kicked out the exhaust but if it's stuck in catalytic converter then it might need replacing.
    Basically they couldn't pin point it. Wth. Im positive this noise wasn't there before i changed the plugs.
    Any ideads?
  15. Britprius
    5,194
    1,914
    I appreciate this could be a difficult question to answer. Is the tapping noise at half engine speed or engine speed. Half engine speed would point to valve noise. At engine speed would point to piston, or little end noise.
    Listening through the handle of a long screw driver used like a stethoscope "if you do not have access to stethoscope" will often pin point such noises.
    John (Britprius)
  16. Thomas Ziongas
    Hmmm. Idk. It ticks under light and heavy acceleration.apparently it ticks or rattles arty idle now.
    I'm at the dealer now going for a ride with the mechanic momentarily. I'll report back in a little.
  17. EKIM
    EKIM Junior Member
    61
    Escondido, CA
    If there was something in the cylinder and there was a rattle sound, you already know a foreign object was in your cylinder trying to escape.
    As was already said, that foreign object likely ejected itself through the only way possible, past a valve. The valves only open a fraction of an inch and many times a second. This isn't much of a passage or opportunity for the foreign object to escape. It is very likely a piece was jamming a valve (likely an exhaust, but possibly an intake) open until combustion forces pushed it into the exhaust or intake tract.
    While it is stuck in that opening, it is possible that the valve bent since it's just a coin on a stick and is designed to hit square and if it is pushed off of square it can bend the stem. It can also put a divot in the valve or valve seat, but this is a piece of porcelain we're talking about-- it will be pulverized and ejected, but it can still do damage.
    a leakdown test on that cylinder will tell the technician if there is an abnormal amount of leakage in that cylinder which would indicate poor sealing. A good technician will be able to ascertain if it is the rings or possibly the intake or exhaust valve that is not sealing correctly, if anything at all.
    Likely, if anything, you would have a slight leak due to some damage to the valve and seat mating surface which is lowering your peak combustion pressure in that cylinder and combustion gasses are leaking out either through an intake or exhaust valve. Ask the shop if they performed a leakdown test on that cylinder and compared it to the other cylinders and if there was any significant variance.
    IF there is a bent valve or damaged seat, the ONLY fix requires removing the head and performing a valve job and possibly replacing a seat and / or valve.
    Drive it. If there's damage done, it's already done. It will get progressively worse if it's damaged. If it is damaged, the worst case scenario is you'll need to replace the motor. But more than likely, it'll blow a head gasket or completely burn a valve which will prevent you from being able to drive the car LONG before it completely destroys the motor.
  18. EKIM
    EKIM Junior Member
    61
    Escondido, CA
    In other words, there's a greater chance that if you decide to have the head removed to inspect for damage you're just spending your money unnecessarily. Some people need that peace-of-mind, though.
  19. Patrick Wong
    18,200
    6,472
    I will assume that you are correct and that your engine is producing a new noise. So what?
    If you don't notice any power train driveability or engine oil consumption issues and your fuel economy is normal, then why worry?
    Or, are you determined to spend a four-digit amount to replace the engine just because there is more noise now than in the past?
  20. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    To learn from the OP's mistake, would this be the correct procedure to completely remove the broken spark plug pieces? Assuming non-overhead valves, which is the case for Gen2 Prius?
    1) remove the valve cover (or whatever it is called that contains the spark plug threads)
    2) remove the broken spark plug porcelain pieces from cylinder
    3) NEW valve cover gasket (guessing not a good idea to reuse old gasket?)
    4) reattach valve cover
    5) replace spark plug this last spark plug (as the other three were installed and torqued correctly)
