help understanding strange vehicle behavior
Discussion in 'Gen 3 Prius Main Forum' started by AKTroy, Jun 21, 2017.
  1. AKTroy
    AKTroy New Member
    17
    Alaska
    okay folks I need some help understanding some strange vehicle behavior.
    I got out of the vehicle while it was running, and when I returned to the vehicle and put it in drive it would not move. I believe the ICE was running at the time as well. I pressed the park button, put my foot on the brake and again put it in drive, but it would not move. Everything appeared to be functioning fine, no warning lights or anything like that.
    So, I turned the vehicle off, restarted, and drove away without issue. So, could somebody please explain what happened? I'm assuming some kind of a security protection, but haven't a clue. Vehicle is a 2011, Trim IV.
    Troy
  2. NavyLCDR
    NavyLCDR Active Member
    188
    120
    Stanwood, WA
    My guess is that the vehicle did not immediately recognize the presence of the smart key inside the vehicle upon your return. I might check the battery in the key fob.
  3. AKTroy
    AKTroy New Member
    17
    Alaska
    Okay, I'll change it out. Sure had me confused.
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Don't need the FOB once the vehicle is started (in "ready"). That's not it. Parking brake stuck on? Some new so far unknown mode?
    I do this every time I drive Pearl S and this has never happened.
    KennyGS likes this.
  5. Quattro
    Quattro Member
    60
    28
    Silicon Valley, CA
    Is the 12V battery original? If it is from 2011, it's due for a replacement. Strange electronics behavior could be from a low 12V battery.
    My 2010 had strange starting issues and a new battery fixed it.
  6. AKTroy
    AKTroy New Member
    17
    Alaska
    I'm pretty sure the battery is original. Expensive little buggers too. So far I've not had another incident of the strange behavior. I may have the battery load tested, and just check out the resting voltage as well. With our extreme winters here in Alaska, I definitely want to have a good battery for the upcoming winter. I'm also going to change out the batteries in the remotes as previously suggested.
  7. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    Strange. I've never had that experience.
    Usually my problem is when I get back to the car after leaving it running, I press the start button - shutting it off because I forgot. So I then have to press the the start button again. :facepalm:
    jerrymildred likes this.
  8. AzWxGuy
    AzWxGuy Weather Guy
    982
    495
    Tucson, AZ
    2021 Prius
    When you shifted to drive did the MFD shift display actually change from P to D? I too suspect the 12V battery, as it is almost always the cause for malfunctions. True, when the vehicle is running the 12V power comes from the DC to DC converter. But something might not have initialized properly when making it ready, where it uses power from that little 12V to "boot up".
