HELP!!! Valve Core Sticking, Tire won't hold air.
Discussion in 'Gen 2 Prius Technical Discussion' started by Agontyr, Dec 17, 2006.
  1. Agontyr
    Agontyr New Member
    I have 2 out of 4 valve cores that stick open whenever I attempt to put air into the tires. Usually I can jiggle them with the point of a screw and get them to close, but one has gotten to the point where the tire usually goes flat before I can do it.
    I've tried asking at the dealership parts desk, but whenever I say the words "valve core" they get that deer-in-the-headlights look. They've told me everything from $5 to $65 per tire to replace and they never have them in stock. Special orders must be pre-paid and I'd rather not pay for something that I'm not sure is right.
    Has anyone else had this problem? Does anyone have access to a real part number?
  2. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(Agontyr @ Dec 17 2006, 04:52 PM) [snapback]363482[/snapback]</div>
    Yes, this happened to one of my other cars, not our Prius. Go to the nearest tire store and get a whole new stem (or two in your case) is what worked for me.
  3. FL Buckeye
    FL Buckeye Member
    146
    WC Florida
    I haven't checked in my owners manual, but since the 2006 Prius takes a special tire valve because it houses the tire pressure sensing transmitter for the TPWS, I would have guessed that your warranty would cover this problem. I'd read up on your warranty and talk to the service manager at your dealership. If the valve stem takes a normal type valve core, they should be very cheap and obtainable.
    Could your compressor be putting moisture into the tire, and it is causing the problem? If so, make sure you have a filter on your airline.
  4. theorist
    theorist Member
    365
    Lexington, MA
    I always thought that valve stem cores were standardized. You'll find some cheap and readily available in the aisles of any auto parts store, together with an inexpensive tool for replacing the core. I believe that many tire shops routinely replace the valve stem cores each when they replace tires on cars without disposable valve stems (like the 2006+ Prius.) They usually charge $1 to $3 for this. If you confirm that standard valve stems won't work on your 2006 Prius, please let us know.
    2 out of 4 failing in a year is bad. Be sure to use those valve caps on to keep dirt and moisture out.
  5. glenk
    glenk Member
    109
    Fairfield, CA
    <div class='quotetop'>QUOTE(theorist @ Dec 18 2006, 01:56 PM) [snapback]363859[/snapback]</div>
    I had a flat OEM tire fixed with the TPMS sensor installed. The tire service pulled the valve core to deflate the tire and threw it away. The store that sold me the replacement Goodyear Integrity had me take the bare rim to another store that had the tires in stock. They simply installed a new valve core. I'm pretty sure that the TPMS uses a standard valve core.
  6. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    <_< One more vote for... CAUTION
    If you have the TPWS [Tire Pressure Warning System - Pages 150-154 in my 2007 Owner's Manual], be aware of potential problems when a tire is demounted for repair, or if you elect to replace the OEM tires. Among other items, if you elect to deal with a tire store other than your Toyota dealer there's a possibility they could damage the TPWS sensor on the inside of your wheel at the base of the valve stem. It has been posted in PriusChat that a tire store damaged a sensor and ordered and installed a replacement but then the owner needed to go to a Toyota dealer to "register" the new sensor with the Prius' computer.
    The same caution applies to replacing the stock OEM wheels.
  7. theorist
    theorist Member
    365
    Lexington, MA
    <div class='quotetop'>QUOTE(Charles Suitt @ Dec 18 2006, 03:56 PM) [snapback]363910[/snapback]</div>
    Bad things can happen, anywhere. Last week I saw a friend at the side of the road, having his wife's 4 year old Camry towed. Apparently the engine seized. After towing it to the neighborhood Toyota dealer (Lexington Toyota) he received a call from Watertown Toyota where he bought the car and has always had it serviced. Apparently they somehow messed up the oil change that they had done 15 miles earlier. When the car seized there was no oil in the car.
    Toyota immediately offered to replace the engine. My friend said how fortunate he was that he had always taken it to the dealership so that they took responsibility right away. I joked that he would have also been fortunate if he had his car serviced at a shop where they can perform oil changes without such serious mistakes.
  8. koa
    koa Active Member
    980
    45
    Hawaii
    Did you try a drop of WD40 or something similar (I use Corrosion Block) on the stem before putting air in? I have had this problem on my boat trailer tires and this usually works. I would think it's alright to do with the TPWS but not sure.
  9. narf
    narf Active Member
    611
    44
    Colorado
    Four Touring
    You should be able to just screw in a new core to the valve stem. You can buy them at any auto parts store for a buck or 2, and the "tool" is just as cheap. Just be sure to be near a source of air when you do it.
  10. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Geez. Never go back to that dealer. Ever!
    Pretty easy to find tire valve core kits at Canadian Tire, so I imagine NAPA should have them too. The best "tool" I've seen is the metal tire stem cap that has the little tool built right into the end. I always keep one in every vehicle I drive, they're cheap too.
    I've had several go bad on me over the years, just quickly unscrewed the core and put the new one in, then put air back into the tire. Do this with the tire jacked up, or by the time you get air in you could have the tire unseat from the bead, then you're SOL.
    I've also had valve cores just loosen up, which would be a great way to get a slow leak. The little "tool" makes it a cinch to check the tightness.
    The air chuck might also be damaged, that could bend the little pintle assembly enough to cause a leak
  11. member
    member New Member
    197
    Add a drop of teflon lube (dry/waxy) to the tip of the valve, add air, done.
  12. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    I too was going to suggest to check that the cores were inserted tightly. If they get loose, they will leak.
  13. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    well if you've got the tpms sensors in there, why not just have 'em order new ones for you and not take any chances? are you still under warranty?
  14. chogan
    chogan New Member
    590
    Vienna, VA
    The tool you want is known as a "Schrader valve extraction tool" or just shrader valve tool. I own one (can't recall why, must have had this problem some years back). Usually they'll come with a collection of valve cores. I vaguely recall that there are at least 2 different sizes of valve cores, though all car tires take the same size.. Takes about 30 seconds to replace one.
    Here's a random internet site with a $1.63 kit, including the cores. I'm sure you local auto parts deal sells them.
    http://www.outdoordistributors.com/Campbel...ireandstem.html
  15. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    There was information presented on Motorweek last week about this. You want to be sure to get the nickle plated valve inserts, not the plain brass ones. For some reason they are necessary in TPM systems. Other than that, they are normal valve inserts.
