Help w/ solar panels
Discussion in 'Environmental Discussion' started by SSimon, Jul 15, 2008.
  1. SSimon
    SSimon Active Member
    1,426
    N/W of Chicago
    I've recently heard that heating costs will increase by about 30% this upcoming heating season. This prompted me to revisit costs to install panels on my house. The cost for a four panel system is about $22m. After rebates our out of pocket would be about $12,000. The panels should displace anywhere between 30-50% of our conventional energy use.
    I've researched natural gas prices and the price just about doubles every 3-4 years. With current price escalations, it looks like the price is now set to double by this winter, within a one year period. I can speculate that costs will continue to increase on the current scale but using historical prices it looks like it will take about 10-14 years for us to recoup the costs of the panels based on historical cost escalations.
    With the exception of two things, we've performed all energy improvements recommended on energy audit websites. Our windows are single paned with storms. I've caulked them and use plastic on them in the colder months. Based on these two things, and the related small drop in our energy use, I'm not convinced new windows will provide a rate of return better than would be provided by panels. The other things we have yet to do is have an HVAC contractor out to inspect our ductwork for leaks. We are definitely going to do this and have them fix any leaky ductwork.
    The panels wouldn't be funded by cash. We'd have to take out debt. We're thinking of using our home equity line to fund the purchase so that we can write off any associated interest.
    What would you do given the above scenario?
  2. Godiva
    Godiva AmeriKan Citizen
    10,339
    If you're going to get an equity loan, can you increase the PV system to provide 100% of your electricity/year rather than thed 30-50%?
    Have you considered solar water?
    How is your insulation?
    If you're going to need a new roof soon, do that before adding PV.
  3. SSimon
    1,426
    N/W of Chicago
    The panels wouldn't cover any electricity. Only natural gas.
    I'm not too concerned about water heating costs since we hardly use any water. We typically use about 18-30 therms in the warmer months and this includes the energy used for our clothes dryer. I'm more concerned about home heating than anything else. It's killing us. We have paid up to $300 in some months. Could go up to $500 for some months this year with the kind of price escalations I'm witnessing.
    I just blew in loose insulation throughout the attic. That's done. Nice sound abatement as well as reduction in energy use.
    I asked about the roof replacement and she said that since the panels won't be flush, the roofer can work around the panels with no worries. If we do this I will call my roofer to ensure this before contracting for solar.
    How do you like your system? Are you electric only conversion? I checked with them about electric and this type of system would take even longer for us to make back our outlay. We use very little electricity compared to norms.
  4. Zythryn
    Zythryn Senior Member
    6,406
    4,403
    I would check into the windows again. Double pane (or triple) argon filled windows can save you a bunch of heat in cold months.
    Just how cold is 'cold' in your area?
    Our panels are roof mounted, have survived through two hail storms which damaged vents, gutters and such. However we use no natural gas, our home is all electric and geothermal so our positions are quite different.
    Also, have you checked into wood pelet stoves?
  5. finiyon
    finiyon Re-Member
    66
    Philly, PA
    Where are you looking to get the panels? Do you have it down to a single manufacturer? We are looking to install in new construction.
  6. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    SSimon, you really should check out the stoves, wood pellet or otherwise. If you have good access to wood a good stove that's EPAII rated would probably do a great job of heating your house. Doing that and buying new windows might be considerably cheaper than the radiant heating (that's what you're doing, right). Just a thought.
  7. Godiva
    10,339
    I've got a natural gas furnace, stove, water heater (on demand tankless) and dryer.
    I have PV for the electrical. My electric bill should be zero at the end of the year.
    In order to replace the NG I'd have to convert the furnace, stove, water heater and dryer to electricity. I'm not willing to do that yet. (I do use a small electric space heater in the winter in the bedroom.)
    If natural gas gets to be too cost prohibitive...I may replace these large appliances and simply add more solar PV to make up the difference. But that is not cost effective yet.
    I don't see how the solar is going to replace your NG. Do you use a boiler and radiators to heat and the solar will be hot water for that?
  8. Godiva
    10,339
    My parents have a fireplace that heats their home in the winter. They haven't bought wood in years.
    They have a deal going with a local tree removal, stump grinder service. They call my Dad when they're taking down a tree and the owner doesn't want the wood. He comes with his truck and the guys load it up. The tree guys don't have to pay to dispose of the tree in the local land fill, and my Dad gets free firewood.
  9. SSimon
    1,426
    N/W of Chicago
    To answer the above questions:
    I'm near Chicago so it typically gets pretty cold here. Wind is also a big factor here. I've installed a wind break that's not yet mature enough for me to advise if it's going to help.
    I haven't checked into wood pellet stoves. It seems pellets would have higher ghg emissions than NG??? (no radiant heating in my house) I've no doubt a pellet stove would heat my house. It's small and our fireplace can keep our house warm on very cold winter days. If emissions aren't nasty, noxious and abundant, I will look into this option. Anyone know?
    I received the solar panel quote not from a manufacturer but from a solar panel installation contractor.
    I just talked w/ my handyman and he said they put new siding on their house along with new windows and their energy costs almost halved. I'm going to call a siding contractor that I'm familiar with and see what they think. If this reduction bares out, I'd much rather spend money for improvements to my house that are sure to bring my money back (in part) on the sale of the house. The solar market isn't yet aged enough around here to tell how the investment will hold upon sale.
    I'm also not real comfortable spending the money for solar without our state budget resolved. This would account for almost $7,000 of the panels that we'd be paying out of pocket and hoping that the "discretionary" alternative energy part of the budget holds, that the monetary cap isn't already account for with new applicants and that I don't have to wait a year or so to get my rebate due to the timing of my application.
    Thanks for the wood pellet stove recommendation. Let me know on emissions. I'll google in the meanwhile.
  10. Zythryn
    6,406
    4,403
    SSimon, the windows should definately help. Siding really doesn't do much, it is all the windows (unless you are adding insulation at the time of siding?).
    The pellet stoves I looked into actually ran quite clean.
    Many actually have remote thermometers which turn on and off automatically to maintain a certain room temp. This and the windows may be your best bet.
    Seriously though, get double pane windows, those single pane ones are nasty in the cold.
  11. PriuStorm
    PriuStorm Senior Member
    2,239
    149
    Davis, CA
    Just curious... is this usage per month or for the entire warm season?
    We use gas for furnace, fireplace insert, stove, water heater and dryer. Of course, most of that is not used in the summer, including the dryer (we line dry). Our usage is 4-5 therms per month in summer.
  12. icarus
    icarus Senior Member
    4,884
    976
    earth
    Simon,
    If you are considering getting PV solar to reduce your heating bills PLEASE, PLEASE take a look through the following forum. Solar Electric Discussion Forum - Powered by vBulletin
    It may help you avoid the 'ready, fire aim", syndrome! While PV is a great thing to consider, in the real world, it should be about fourth on your list of things to do BEFORE you install PV. The first to consider conservation first, second and third. Extra insulation, windows, including heat saving night insulation shades, hi-ef appliances, lighting etc. Then consider solar water heat, followed by passive, and active solar space heat. (These in cost effective order). Then , and only then does it make sense to consider PV solar.
    One very important thing to consider, is that using PV solar for heat generation is crazy! PV solar is ~15% efficient in converting sun to power, while solar water heat (either domestic or hydronic) can approach 80%. To heat with PV throws 65% of it away.
    Please don't deluge me with being anti-pv. Quite the contrary, I make my living designing and installing PV systems. As I have said many times before, PV solar is sexy, conservation is not so sexy.
    The above link is populated by a considerable number of very smart experts who have vast real world experience in all aspects of RE. Most own PV and other solar systems,,,they are not salesmen.
    Consider that the retail price of PV is ~$8/watt. A 2kw system would then cost ~$16k. With tax credits and rebate, perhaps you can cut that to $10k. That $10k system will produce ~12kwh of power on a good clear summer day at lat. 49 degrees N. That works out to about less than $2 worth of electricity per (good) day. Depending on your climate you can do the math.
    Icarus
    After further reading of your posts, these thoughts. Residing the house and adding a layer of Thermax will have 2 huge benefits. The first is the a huge reduction in heat loss through the walls, the second is it will dramatically reduce the infiltration of cold air. (Remember, every cubic foot that blows into your house replaces one that you have paid to heat!) As to "not worrying" about the hot water, because you don't use much proves my point that PV solar is sexy and conservation is not!
    If you spend $1 on PV before doing everything you can possibly do to conserve first, you are throwing money away. Again, PLEASE don't consider heating with PV solar,,,,that is just plain dumb!
  13. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Triage your choices: No. 1 - insulation, No. 2 windows, drapes & doors, No. 3 new sources of heat.
    The most cost effective thing you can do is hold onto what you already have vs. "go get more." Efficiency is very cost effective (wrapping the water heater, storm liners on curtains, weather stripping around doors and windows, "warm window" curtains, etc.
    I retrofitted our home several years ago and our monthly utility bill (electricity and natural gas) averages less than $30 month year round. We are cool in summer and warm in winter. No PV, no wood burning stove.
  14. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    How big is your back yard? Heat exchanging pipes buried under your lawn is another "free" energy source if you can lay enough pipe.
  15. SSimon
    1,426
    N/W of Chicago
    You guys are awesome. Great input.
    Godiva, I had the solar contractor out about 5 years ago for a quote and they went over the system dynamic with me. Can't remember how conversion takes place since this discussion was so long ago. Currently, they're just talking price with me over the phone.
    For all the other suggestions, we are conservation oriented for all resources as much as is humanly possible. There truly isn't much room to move in this area. So I'm left with trying anything possible to make my house more efficient. Have caulked windows and doors, purchased thick shades and drapes, put foam insulation in all cracks to outdoors, etc.
    You've all steered me away from solar at least until I review the other options left on the table, which are - new windows, siding (will consider if it's found the the last siding contractor didn't properly insulate and I have a feeling they didn't since there is loose insulation falling out of the bottom of my shingles. This certainly doesn't seem normal. Checking into Thermax as suggested.), pellet stove and review of ductwork to ensure no leaks then consideration of solar if none of the aforementioned bare out.
    And yes, PriuStorm, that's our monthly energy use range in the warmer season. I'm telling you that heating costs are killing us. With the rate increases due this year, we'd rather apply this money towards home energy efficiency improvements instead of giving this to the energy supplier.
    And, Jack, my yard is tiny.
  16. Godiva
    10,339
    Before you reconsider Solar, you need to do a lot of homework. The internet is your friend.
    If you decide to go ahead, you need to get bids from 3-4 contractors. And you need to know your stuff so you can evaluate the answers you're getting from them. Anyone who only talks price isn't anyone you'd want to hire. And remember, the lowest bidder isn't always a winner.
    Five years ago is a long time.
    Look at your applicances. How old is your refrigerator? If it isn't an energy star, replace it. Likewise the dishwasher, washer/dryer, etc. Especially if you have an air conditioner.
  17. SSimon
    1,426
    N/W of Chicago
    Absolutely. I would have a lot of home work to do to be sure I'm getting the best product and contractor out there. The contractor I've been talking with installed panels on a house nearby and the owner of the house gave me their info. I'm in very preliminary stages of all of this and don't want to spend foolish money. That's what doesn't sit right to me on solar....possible 40% annual conventional energy replacement for a huge up front cash outlay. Waiting for possibly over a decade to make that money back when quite possibly there's a better way to get that money to work for me. At least if I end up doing the siding and windows, I'll be sure to get some of that value on sale. As I said earlier, the market hasn't been really that well tested around here for resale value of solar. When I asked the contractor if I can take the equipment with me if I move, they really didn't welcome that idea. That doesn't make me too comfortable either.
    All appliances are within 4 years old and all are energy star status. New furnace, new a/c unit (even though this hardly gets used). Hot water heater is the only thing that's old (9 years). Could account for my high therm use in the warmer months. I've been meaning to get a blanket, just haven't done this yet.
  18. PriuStorm
    2,239
    149
    Davis, CA
    If one of your prime objectives is to cut down on your natural gas usage, I would suggest you consider line drying your clothes. Sure, it takes a little set-up and work, but once you're in the habit, it's really not that much extra work. Plus, you're taking advantage of the sun's free energy with little investment.
    Here's a page of all the different types of systems they offer.
    Brabantia Outdoor Clothes Lines / Dryers | Free Shipping by Brabantia Home Furnishings
    I have a Lift-o-matic spinner
    When we poured the concrete pad outside the garage side-door, I had the dryer base set as part of the pad. The clothes dryer is light-weight and very easy to take out and open, or take down and put away. It also spins, so you basically just stand in one location and hang clothes, spinning the dryer to reach new lines. It's very user friendly.
    Anyway, just a suggestion since you say your hot water use is minimal, then I just surmised that most of your gas usage in summer is probably your clothes dryer. Taking that out of the equation, you might cut your usage down considerably.
  19. Godiva
    10,339
    Is the water heater natural gas? 9 years is nearer the end of it's life. Yes, a blanket will help. You might look into a water heater that will be more efficient. Solar water will be cheaper than putting in PV and get you more payback.
  20. icarus
    4,884
    976
    earth
    Rather than checking and repairing your ducts, consider the idea of installing a couple of Rinnai vented space heaters. Forced air heating is full of losses . A Rinnai can be more than 90% efficient depending on size and usage. The other advantage is that you can zone heat very efficiently. They can be had with programable t-stats so that you only need to fully heat the rooms you use, when you use them.
    Beware however of cheaper direct vent space heaters (empire and the like)
    even though they are rated at 75% or better I would be surprised if they were to make that. The Rinnai vent system vents through a 1.5" pipe. A typical "b" vent furnace through a 4-6" hole. Other direct vents are ~5". doesn't take long to figure out where the efficiency lies.
    Icarus
