Help: white smoke after new spark plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by icyrius, Jun 28, 2018.
  1. icyrius
    icyrius Active Member
    242
    115
    Florida, USA
    2014 Prius v wagon
    Hello fellow Prius owners,
    Today I completed switching the spark plus in my Prius gen 3. I rubbed anti-sieze greese and dielectric grease just as suggested in Nutz and Boltz video. However, when I started by car, white smoke started coming out all the spark plug holes. I immediately shut off the car to prevent any further (if any) damage.
    Can someone help me undestand what is happenning?
    I even was careful to label the spark plug cables as 1,2,3,4 to avoid crossing the spark sequence.
    Thank you for your help.
    52,671
    did you thread the plugs in by hand, then torque them down?
    Raytheeagle likes this.
  3. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    All the spark plug holes? Possibly all are a bit loose. White smoke, that’s a puzzler.
    There is a firing order, which can be traced, generally 1-4-3-2 I haven’t done that since 2006.
    Since the fuel injection must match the firing order, double check that too.
    #3 Andyprius1, Jun 28, 2018
  4. icyrius
    242
    115
    Florida, USA
    2014 Prius v wagon
    Yes. I did all of them by hand first until I could not tighten them any longer.
  5. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Firing order is 1-3-4-2, but doubt that is the problem.
    Andyprius1 likes this.
  6. Andyprius1
    2,327
    859
    Cool CA
    Some one, like Ed will solve your problem, soon.
  7. bisco
    52,671
    how many ft/lbs did you torque them to?
  8. icyrius
    242
    115
    Florida, USA
    2014 Prius v wagon
    That is my theory too. SInce all of them were smoking. I have a torque wrench, but do not remember how much I set it at. I think it was 15 Ft/lbf?
  9. Andyprius1
    2,327
    859
    Cool CA
    People on PC make a big things about this, I have never torqued Plugs. Just a 1/4 turn beyond hand tight~ always subject variances.
  10. Andyprius1
    2,327
    859
    Cool CA
    someone give me a rundown on correct firing order, 4 injectors, 4 plugs right?
  11. bisco
    52,671
    see post #5.
    Grit, ITBland and Andyprius1 like this.
  12. Andyprius1
    2,327
    859
    Cool CA
    It’s one thing to know the firing order, it’s another to prove that it’s actually wired correctly. It’s sometimes easy to switch two wires.
  13. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Due to wiring lengths, it's pretty hard to mis-wire COP sparkplugs.
    Besides that wouldn't affect smoking in the engine bay, the car would just run rough or not at all and/or smoke at the tailpipe. Just start it up and let it run awhile to let it burn off any excess applied chemicals.
    #13 fotomoto, Jun 28, 2018
  14. Andyprius1
    2,327
    859
    Cool CA
    You always make so much sense.
    fotomoto likes this.
  15. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    How much greas and anti seize did you use?
    Could it be that “burning off”?
    What did the white smoke smell like?
    milkman44 and WilDavis like this.
  16. icyrius
    242
    115
    Florida, USA
    2014 Prius v wagon
    I was "generous" with the grease. I made sure I covered the entire threaded portion of the spark plugs. With the dielectric grease, I rubbed just the tips of them.
  17. icyrius
    242
    115
    Florida, USA
    2014 Prius v wagon
    I did not get to smell the smoke. I just went back to smell the car and it does not smell like burned rubber or anything strange.
  18. Andyprius1
    2,327
    859
    Cool CA
    I’m sure fotomoto is right. Just run it for a while.
  19. icyrius
    242
    115
    Florida, USA
    2014 Prius v wagon
    I will give it a shot again tomorrow morning and share the findings. It is kind of late to deal with it now. Thank you all for your help!!!!
  20. fotomoto
    5,639
    3,815
    So. Texas
    Too kind, thanks.
    Cleaned my daughters recently purchased and very dirty 10 yr old, 125k mile Suzuki engine bay and it smoked too at first start up; just got to let it burn off. Next apply liberal doses of protectorant and elbow grease and these are the results (and might smoke/smell some more for a bit):
    #20 fotomoto, Jun 28, 2018
