Help Wiring an AMP for a Sub
Discussion in 'Gen 2 Prius Audio and Electronics' started by VisualMonster, Jul 17, 2005.
  1. VisualMonster
    VisualMonster New Member
    San Diego
    I'm going to be adding a kenwood amp to my Prius to power a sub. I have a 2005 package 6 and am hoping that I can just tap into the wires from the stock amp for the signals.
    My question is, from the output of the stock amp, what color wires are the left rear and right rear speakers? I'll be using an RCA line output converter.
    My amp also has a Remote wire so that it knows when to turn on. Is there a wire from the stock amp that I can tap into for this remote wire?
    Any wiring diagrams floating around? I haven't been able to find one. Thanks for the help!!
  2. tmorrowus
    tmorrowus Member
    514
  3. NuShrike
    NuShrike Active Member
    1,378
    Read the Kenwood bass threads (which should be a KB article by itself now), for all the information you need.
  4. bradr9
    bradr9 Junior Member
    TMORROWUS THANK YOU SO MUCH YOU HELPED SO MUCH!!!!!
