Help with '08 Nav Speed Wire hack
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Karlos, Jun 13, 2011.
  1. Karlos
    Karlos Junior Member
    US
    After lots of searching and research through these forums and Darrell's EV page, I attempted the Nav speed wire hack....without success.
    I removed the vent panel to the right of the MFD to access the wiring block shown in Darrell's photos. The wiring on my 2008 is different than what is in the photo. Rather than the Nav speed wire (pin 5 of N2) located where the photo shows, mine was located a few positions up.
    I cut the upper purple wire and installed my switch. It has no effect on the Nav or Bluetooth in either switch position.
    Has anyone out there done this on an '08 ???? Which wire do I intercept? I'd like to use the same wiring block since it is easy to get to. I'm not sure if Darrell's access through the dash speaker will expose a Nav speed wire. He did his for the Bluetooth and music, I believe.
    Help please!
    Karl
  2. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    why not just buy a coastal lockpick basic for $100?
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    A 555 timer, 2 resisters, a cap and a switch cost less than $15
  4. LIPriusFreak
    449
    34
    Long Island, NY
    and the cost when you short something out because you don't know what to do=priceless
  5. Karlos
    US
    I actually enjoy doing these mods....and I like keeping the cost down. The Prius Chat community is usually quite supportive of that. I'm looking for the schematics for an '08 wiring block located at the air conditioning vent located to the right of the Nav system.
    Your comments are not really helpful or cute.
  6. cproaudio
    2,401
    759
    CA
    That's just it, I know what I'm doing. A lockpick won't work on GenIII. For Gen III, Prestigious Society is the only option. At $299.49, it's really steep. I'll stick to my own mod. It works exactly the same. As for the OP, build your circuit and test it out with an oscilloscope so you can see it on graph how the pulse look like. I think Gen II and Gen III's are the same, 4 pulse per mph.
    As for which wire it is, I can't help you with that. For Gen III is the violet wire. I would imagine the Gen II is the same. When you cut this wire, the speed info on the nav unit should show 0 even when traveling.
