Help with 2002 NHW11 - DTC P3108
Discussion in 'Generation 1 Prius Discussion' started by Miga, Dec 2, 2017.
  1. Miga
    Miga New Member
    Ulaanbaatar
    2002 Prius
    I scanned 2002 nhw11 and i have p3108. Its told ac amplifier h/v ecu is abnormal but this prius problem is power steering, window, heater (A/C), emergency lights are totally don't working pls help
    51,140
    are you using tech stream? have you checked all the fuses?
    Raytheeagle likes this.
  3. Prodigyplace
    12,403
    11,681
    Central Virginia
    What is the age and voltage of your 12 volt battery? A weak battery can cause the confused computers to generate strange codes.
