Help with a 2011 Prius Three check hybrid system" light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tiffany D, May 10, 2015.
  1. Tiffany D
    Tiffany D New Member
    Gastonia, NC
    I am new to this forum but I have a 2011 Toyota Prius that just had it's 85,000 maintenance one month ago. On Friday, I was driving down the road going about 45 mph when a orange triangle, a check engine light and a check hybrid system light came on. The gas pedal wouldn't work, I dropped to 10 mph in a madder of seconds and coasted to the median. The car cut off and wouldn't come back on. I tried over and over to restart the car but it wouldn't work. I had to tow it to the dealership. The dealership has had it for two days and they say that "diagnostically it all checks out fine." They claim the hybrid battery and hybrid system pass and all diagnostics pass. They say that they have idea what is wrong with it and now have to wait until Monday to call Toyota technical support to get advice. First, I can't believe that the dealership where I purchased the vehicle four years ago has no idea what is wrong with it. Second, they say that "it is very expensive to diagnosis Prius problems."
    Does anyone have any suggestions or ideas what is wrong with my vehicle? I had to call out of work on Monday, they want me to rent a car for work, but I am scared that I am in for thousands of dollars in repairs once this is all over with. Has this happened to anyone else?
    52,363
    welcome! did they find any trouble codes? i suppose it could be almost anything, 12 volt battery, inverter pump, yadda, yadda, yadda. fortunately, you're still covered under the 8/100 hybrid warranty.
  3. JC91006
    16,827
    8,600
    Probably an inverter problem, there was a recall on this and failures are possible
  4. Tiffany D
    Gastonia, NC
    I hope that's it. They didn't say anything about a recall a month ago when I took it in for service. Thank you for the quick response.
    They said nothing came up when they ran the diagnostics so they are unsure of what is wrong. I'm hoping I won't be carless for much longer and that tech support can help them.
  5. Okinawa
    Okinawa Senior Member
    1,333
    320
    I had a 2011 Prius. I got a letter from Toyota concerning the inverter. If I remember correctly they extended the warranty on mine for about 15 years. You may want to check in to that when you can just in case you have an inverter problem in the future.
  6. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Tiffany,
    odd that they didn't find anything. for something as major as a hybrid check engine, loss of power, and all that jazz, you'd think that a bunch of Diagnostic Trouble Codes (DTCs) would have been saved. Those are pretty indicative of what dies, when something did die.
    If you ask, the dealership will give you those codes. And possibly a shifty look, related to what happens when one lifts up a rock and looks underneath.
    Based strictly on your story so far, I see two possibilities:
    First, there may have been no trouble codes. Weirdly enough, this points at something: A dead or dying 12 volt battery, the one in the rear of the car to the right of the spare tire. There have been a number of reports that when this battery goes bad, all sorts of bad behavior then ensues, up to and including what you've seen. And there have been further reports that some dealerships haven't caught onto this failure mode when it happens, either. The 12 V battery is a more-or-less standard lead-acid type and there's standard test gear that can determine if one is on its way out. But somebody has to actually hook up said gear and check, and that may not have been done. Ask.
    Second, there may very well have been DTCs, but the dealer did a controller reset after reading them and now they're gone - and they can't make them come back. As an electronics troubleshooter myself, I have a favorite saying: "I hate intermittents."
    The hybrid transmission train, including the inverter, is covered by warranty, true. But it's all pretty blame expensive and it's a good bet that Toyota wants specific documentation on what's wrong, both to drive replacement of the correct part and for the dealership to get reimbursed for the repair. A missing failure means the dealer can't do the troubleshooting they want to do and makes them mad, because they know you'll be back with a head of steam if they get it wrong. Under these circumstances calling in a senior Toyota troubleshooter is probably called for, both to identify and get permission to replace the likely failing part.
    If the senior techie is being called, then he/she likely knows about the battery issue, too, and can settle the whole business one way or the other. If it's the battery you'll end up paying since it's a standard wear item. And your car is about the right age to lose one, too: mine died last year, and I've got a 2010. If it's something else, you're likely covered by the warranty.
    Let us know how it all works out. Good luck!
    Kbeck
    sfv41901 likes this.
  7. Tiffany D
    Gastonia, NC
    Thank you! They claim so far all diagnostics are passed with "flying colors." Any idea how much the battery costs to replace that is a "standard wear and tear item?" I just need my car back and hope it isn't too expensive to repair.
  8. Okinawa
    1,333
    320
    I have heard about $300.00 for a battery at a Toyota dealer.
  9. JC91006
    16,827
    8,600
    I don't think a bad 12v battery would cause these symptoms. Either you ran out of gas or you had some other issue.
  10. Tiffany D
    Gastonia, NC
    I have 1/2 tank of gas in the car. I read up on the inverter recall and it sounds like that is it. I was on the highway for 45 minutes, a mile from getting off the highway it died. I just can't believe I never received anything on it and when they performed the 85,000 mile service one month ago, they never mentioned it. All they keep saying is everything is "fine", they have no idea what's wrong and they have to wait til tech support opens up on Monday.I honestly was at the point of writing this car off, cutting my losses and going back to a Honda. If it is a recall, I won't be as scared to drive it. I know had it happened on the highway, I wouldn't have had to time to get over and I would've died. In a matter of seconds I dropped from 45 mph to 10.
  11. JC91006
    16,827
    8,600
    I haven't read of too many failures on late model 2010+ Prius. Only somewhat more common (and this is a "rare" common lol) failure is the inverter, which has been recalled and offered an extended warranty.
  12. Tiffany D
    Gastonia, NC
    It can't be the inverter because the dealership is claiming that my VIN number was not part of the recall.
  13. bisco
    52,363
    going back to honda may be your best option if they tell you nothing's wrong.
  14. Tiffany D
    Gastonia, NC
    Thank you all for your help! They called tech support and is the inverter in the warranty enhancement program. Unfortunately now it will take 4 days to get the part in. I can't believe that it took them 2 days to find nothing wrong and thanks to you all, you solved the problem in less than an hour! Now it looks like I will be carless for 5 more days. They said I could get a rental for $30/day if I wanted to. After that, I am done with Toyota for good. Best of luck to all of you!
  15. Mendel Leisk
    41,876
    You should have gotten a recall notice regarding the inverter. And if you got lost in the shuffle, a responsible dealership should have checked for recalls, I gather you're getting the maintenance done by one. In your communication with the dealership did they mention the inverter recall, was it done?
    Not to freak you out, but there were a few instances, owners got the recall done, and found their mpg dropped. The recall is mainly a software update, with the aim to protect the inverter from sudden/extreme loads.
    FWIW, we had the recall, and the only thing I noticed was a slight increase in the car's willingness to shut off the engine, run on the battery only. If anything, the mpg went up a bit. The problems seem to arise from the software update process, it can go well, but not always. Just speculating though.
  16. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Our 2011 Prius 3 was included in the recall.
    Tiffany, it sounds like most of your problem is due to a poor dealer service department. It should not have taken several days to determine that your inverter had failed.
    Do you have another dealer in your area that you can take your business to after this problem is taken care of? This current problem should be covered under warranty.
    Also, check with your car insurance company/agent whether you have car rental included on your policy.
  17. Okinawa
    1,333
    320
    Don't give up yet. They will fix it.
  18. Tiffany D
    Gastonia, NC
    I have rental car coverage on my auto policy but it is for accidents only not service. Toyota Customer Service says that they will not cover a loaner car. The dealership will not either. I just can't believe that they spent 2 days trying to find trouble codes but found nothing and wasted all that time. I am so frustrated with Toyota and the dealership. I get all the maintenance performed at the dealership and I am supposed to be without a car for 7 days because of this issue. All I can say is be careful because this inverter can break on any of you. I am extremely grateful for all of you because with your help, I was able to locate the problem. I have lost all faith in Toyota at this point.
  19. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Tiffany,
    Now, that is a pile of horse****. You've got a 2011 Prius; the update didn't show up until 2014; of course your car was subject to the recall. The only cars not getting an update were (a) those on the dealer parking lot, which were updated by the dealers, and (b) those built after Toyota had changed the firmware. I hate to tell you this, but if they told you that, then they're a bunch of incompetents or worse.
    Let me give you a bit more detail on what all this was about.
    Under the hood, the inverter is the big electronics box directly to the right of the gasoline engine. This is the box with all the heavy orange wires going to it. In the basement of the inverter are a flock of big, high-power transistors. These transistors take energy from the battery and convert it into three-phase AC waveforms suitable for use with the two electric motors that live in the hybrid transmission. In addition, there's a few other transistors that can either pass the current to and from the big hybrid battery pack (that lives under the rear seat) at the same voltage as the battery, or can perform a "boost" operation that provides for a higher voltage and power, mainly when one is pushing the gas pedal down hard.
    These transistors pass large quantities of energy. As with all engineering, some of that energy ends up being dissipated in the transistors (losses.. engineers are always fighting losses. :)). In an effort to keep those transistors from turning into white-hot slag (no, I'm not kidding), they are mounted onto a pretty advanced heat sink that has coolant running through it; further, in a larger attempt to reduce heat, the naked silicon die are soldered directly to that heat sink and the whole business potted with insulating material. This is all clean-room stuff with people wearing bunny suits, and transistor bond wires going every which way. Advanced, like I said.
    In any case, Toyota discovered that a small but significant number of Gen III Priuses were having problems with that transistor mount. Based upon the documents Toyota gave to the US Government, it appears that under the right onset-of-high-acceleration conditions, the rate of thermal expansion (i.e., heat something up, it gets bigger, no joke) of the transistors and the underlying heat sink were Not Quite The Same, leading to cracks in the solder.. And eventually, a transistor might literally fall off. If one were lucky, the check engine light would come on but one would be able to limp to the side of the road. If one were not lucky, arcs and sparks would fly (we're talking up to 600VDC here) and the inverter would be kaput. In the middle of a road with traffic that's a serious safety issue, hence the recall.
    As near as anybody can tell, the recall changes the engine controller/inverter software in such a way to reduce the energy dissipated into the transistors in that onset-of-high-acceleration condition. People report not much of a change in driveability. However, it is possible that, even with the recall change, a transistor or two might have been on its way out before the recall change went in, so Toyota has graciously extended the warranty on the hybrid drive train, to, like, forever.
    Now, when this recall went out, everybody ran down to their Toyota dealers and got their firmware upgraded. (Except for you, apparently, no offense. :)) Part of the recall involved an inspection, which some of us believe was electrical in nature, the idea being to try and identify an inverter with damaged transistor/transistor mounts. Based upon the long wait times that swiftly appeared, it seems that a fair number of Priuses did have damaged inverters, and Toyota promptly went into overdrive trying to keep the supply chain full.
    There are also reports that the inverter repair has changed over time; initially, the entire inverter was apparently being swapped for a good one. As time went on, it appears that more troubleshooting steps were added and portions of the inverter, rather than the whole thing, were being replaced. This is all based upon peoples' reports here on Prius Chat; Toyota plays the cards close to the chest.
    In any case, once an inverter gets replaced (and there were some people who, at one point, were waiting a month for a new inverter!), the car drives as good as new. So, hang in there.
    KBeck.
    Tiffany, not that I want to support a large corporation (I usually say bad things about them), it sounds like your trouble is with that dealer. There are reports on Prius Chat of dealers who handed out loaners, gratis, when something like this popped up. I would suggest you call Toyota corporate and complain. And, if you have, already, my apologies.
    And while 7 days might sound like a pain.. There was at least one person on Prius Chat who, during the heyday of this recall, waited a month. So count your blessings, I guess.
    KBeck.
    #19 kbeck, May 11, 2015
  20. Tiffany D
    Gastonia, NC
    Thank you for explaining this. I found the Warranty Enhancement Notification letter but it said "if you have not experienced illumination of various system related warning lamps there is no action necessary at this time." I just filed it in my owners manual since it didn't say I needed to do anything and it did not say recall. I took the vehicle to the dealership on April 10th and they performed the 85,000 service and they never mentioned anything about it. The back of the notice tells you "No, you do not need to take your vehicle to the dealership unless your vehicle is exhibiting the conditions described in this letter." It all happened within seconds on Friday. I just can't believe that Toyota says it takes 4 days to receive a part and why the dealership didn't check the VIN number on Friday instead of attempting to run all the diagnostics and coming up with nothing. I am even more shocked that Toyota will not cover a loaner car and just leaves me without a vehicle for 7 days. This whole situation is very disappointing.
    That is crazy! I have called Toyota Customer Relations twice today but they say it takes 48 hours to get a response. The dealership just suggested that I pay them $30/day for a rental car. They are not helpful at all and they claim their service manager is on vacation all this week and there is no one else that I can speak to.
    #20 Tiffany D, May 11, 2015
