Help with A/C Compressor Replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Anthony845, May 3, 2018.
  1. Anthony845
    Anthony845 New Member
    New York Ny
    I have an 2004- Toyota Prius Gen 2 plan on changing my ac compresser but I would like to know where do I add the oil?? DOES IT GO IN THE HIGH SIDE , LOW SIDE THANKS AHEAD
  2. Tideland Prius
    16,626
    A more useful thread title will go a long way in getting people to help you.
    SFO likes this.
    52,433
    check the service manual, high voltage a/c; proceed with caution.
  4. Banksy
    Banksy Active Member
    415
    132
    Lancaster Pennsylvania
    Did you ever figure this out?
    Same issue
    There's high side
    Low side
    And that little screw thing that has the gasket that is a "service" hole or something
  5. davecook89t
    davecook89t Senior Member
    1,092
    826
    Washington State, Florida
    I did not see anything in the manual about where to put the oil, but assume either of the service valves illustrated could be used.
  6. Banksy
    415
    132
    So any hole will work?
    davecook89t likes this.
  7. Banksy
    415
    132
    So the compressor was empty
    I added 4ozs
  8. davecook89t
    1,092
    826
    Sounds about right. Manual says 3.52 + .53 = 4.05.
  9. Banksy
    415
    132
    Would you happen to know where I could find the torque specs for the high side , slow side and three bolts which hold the compressor in?
    Also use lock tight on the threads?
  10. davecook89t
    1,092
    826
  11. Banksy
    415
    132
    Thank you
    You've been a huuuuge help
