Help With Air Bag
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DOLPHINS FAN, Apr 21, 2008.
  1. DOLPHINS FAN
    DOLPHINS FAN Junior Member
    south bend, i
    HELP,WE HAVE A 04 PRIUS WITH AN AIR BAG LIGHT THAT WILL NOT GO OUT.I HAVE USED A MODIS AND A MASTERTECH SCAN TOOL AND HAVE NO CODES.I CAN INDUCE A CODE ,SO I KNOW THAT IT IS A WORKING SYSTEM. I HAVE REPLACED THE COMBINATION METER IN HOPES THAT IT WAS MAYBE SHORTED INTERNALLY,BUT NO DICE,STILL ON.:confused:
  2. wchardin
    wchardin Senior Member
    2,055
    Nashville, TN
    If your plug in tools aren't working on the car, your best bet is to take the car to a Toyota dealership, they can find out what is wrong with the airbag, and fix it, with you incurring a cost probably.
    You might want to take off the CAPS, its like you are yelling.
  3. EJFB1029
    EJFB1029 New Member
    4,726
    206
    Corpus Christi, Republic of Texas
    I think that the airbag system has a 60 mo/60K warranty, check your manual, if it does, it should be under warranty, unless you are over the miles.
