Help with debadging
Discussion in 'Gen 2 Prius Accessories & Modifications' started by griffin911, Jun 17, 2007.
  1. griffin911
    griffin911 New Member
    I went to debadge my '07 today and had no trouble at all today with the rear badges...they came off fine.
    However when I went to take off the hybrid badges on the front sides I found that there is a single hole underneath.
    For those of you who have removed these what have you done? Have you just left the holes open? Have you covered it with something else?
  2. pingman
    pingman New Member
    124
    <div class='quotetop'>QUOTE(griffin911 @ Jun 17 2007, 12:21 AM) [snapback]463327[/snapback]</div>
    why debadge it ??? :blink:
  3. TurkeyButt
    TurkeyButt New Member
    31
    I don't get why you want to take off the badges. I get the dealer stickers/badges but why the Hybrid?
    Sorry I can't help you out though...
  4. mini2prius
    mini2prius Junior Member
    72
    That's interesting - I "debadged" my '06 of all but the Toyota logo (centered, front and rear) and found no holes. Maybe Toyota doesn't want you to debadge it?
    TurkeyButt/pingman - I can't speak for others, but I debadged mine because I think it looks so much better without them and it even makes it slightly easier to wash!
  5. h2photo
    h2photo Member
    432
    Chandler, AZ
    I dont have any opinions, but thanks for the heads up about the holes. I was still debating whether or not to remove the Hybrid ones on the sides. Guess I wont be!
  6. treehggr
    treehggr New Member
    230
    <div class='quotetop'>QUOTE(h2photo @ Jun 17 2007, 12:20 PM) [snapback]463473[/snapback]</div>
    I have verified that the front Toyota symbol on the 07 does in fact have a hole underneath. I reinstalled this badge as soon as I saw the hole earlier today. I did not end up checking the back Toyota emblem.
  7. YoDaddyAlex
    YoDaddyAlex Member
    271
    i removed the "toyota" and "prius" badges from the back but was debating whether I should remove the hybrid from the front sides. thanks for the heads up, I will keep them on. IMO it looks really good in the rear with only the "synergy drive" logo
  8. TheAnnoyingOne
    TheAnnoyingOne New Member
    318
    -118.15476, 34.112134
    “Fixing†dogs and cats, I understand; “Fixing†the Prii?
  9. darelldd
    6,057
    388
    Northern CA
    As I replied in email... it must be different on the 07. In 06, there were no holes under those badges on the side.
    For those of you who ask why... I ask, "why not?" I don't like extra, usless crap on my car. So I take it off. Ends up looking slightly different, and quite a bit better than how it comes from the factory. YMMV.
  10. Compfool
    Compfool New Member
    <div class='quotetop'>QUOTE(darelldd @ Jun 18 2007, 02:24 AM) [snapback]463842[/snapback]</div>
    I concur that the 06 does not have the holes under the side hybrid emblems.
    IMHO I thought the side badges looked out of place and I like the look of the back without all the lettering. I left just the Toyota symbols Front and Rear.
    -=Adam=-
  11. rep308
    rep308 Junior Member
    71
    suburbs of Boston
    The 2008 have holes under the side "Hybrid" badges as well. I was able to stick it right back on. I think the badges look tacky and they are a pain to wax around.
    I used a hair drier, goo gone and wood shim as the putty knife to wedge it off. It took less than 5 minutes
  12. Doc Willie
    1,717
    142
    Out there, somewhere
    I removed the side ones from my '07. I am still learning the best way to fill and paint the TWO holes on each side.
    Why remove them? They did not look right and are not Starfleet issue.
  13. prius729
    prius729 New Member
    120
    Hobbs, NM
    Depending on the size of the holes, I'm guessing it can't be that big, get some green vinyl stickers and cover up the holes.
  14. tkil
    tkil New Member
    158
    It would be spiffy if you could use the holes to install turn indicators...
    robertmaria likes this.
  15. Doc Willie
    1,717
    142
    Would have worked if I had removed the badges BEFORE I had the stripes put on.
  16. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    Why remove badges?
    I removed my badges and instantly gained 10 mpg. Plus, my Prius gained 15 hp, easy!
    It must have something to do with the aerodynamics/weight ratio frequency thing.
    Daves09prius and PriusCamper like this.
  17. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    what i would do, is put some fiberglass where the hole is and use glazing filler, if its a small hole, if its kinda big you would have to slap on some filler, i would get some lightweight filler as it will help.
  18. Doc Willie
    1,717
    142
    I got the filler part. It's getting the courage to grind enough away, including the surrounding (gasp) paint job to be able to prime and paint and have it all come out smooth. This is why one usually has professionals do this stuff.
  19. Hybrid Effects
    Hybrid Effects Junior Member
    97
    Orlando, Fl.
    Just get what they call small plastic nails or small hole plugs that is your best option.
  20. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    all,
    In photos of the European or Japanese island Priuses, don't they have side marker lights at that location? That may be what the holes were originally intended for [with any Hybrid/HSD emblem simply re-located within a few inches (if THEY even use them)].
    Maybe Toyota decided to stop making 2 kinds of fenders for the production lines [those without holes for the USA/Canada market & those with holes for the rest of the world (if they need them for the lights?)], but as far as replacement crash parts for our '04's & '05's in North America (& anywhere else?), they would still have to provide fenders without holes until 2014.
    I've heard that the ultra high tinsel strength steel used in the Prius requires body shops with special weld'g equipment, so if Toyota only provides the fenders with holes as crash parts then they would have to have plugs made of the same material of the right size for those specially equiped body shops to weld in place to mimic a stock hole-less fender for the North American '04 & '05 models.
    As an alternative the body shops could just order a pair of Hybrid/HSD emblems to cover the hole(s) on the fender(s), but the insurance companies probably wouldn't want to pay for 2 of the approx $30 emblems to be added to a car they weren't stock on. Yet if the hole-less fenders become unavailable in the future, I think the emblem addition will be a cheaper solution for the insurance than paying the shop to obtain/cut a plug, prep the metal for weld'g, do the weld'g, grind the weld bead flush, & then prime it (a lot of extra work before the color coat).
    Of course whether weld'g is necessary instead of plastic body filler (Bondo), would depend on the size of the hole (which nobody has measured & reported yet). I know some of you don't approve of the emblems but I think I would rather have the factory hole covered by an emblem than have a welded plug maybe blister underneath the paint (as I had happen to a welded fender on another car years ago) or a plastic Bondo plug break loose & fall out due to road vibration.
    Back to you who already have the holes & want to remove your emblems, see if that parts/accessory site that has the Japanese only parts has the side marker lights that I think I remember seeing. If you're good with electrical wiring you can tie into the regular light'g wiring & set them up as simple side markers or make them into side signals by tying into the signal light cicuits. Just some thoughts, crazy as they may be.
    Ken (in Bolton,Ct)
