Help with H11 to H9 mod
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Ginger Jay, Jun 21, 2015.
  1. Ginger Jay
    Ginger Jay New Member
    DFW
    Hello all,
    I have a 2015 Prius 2 and as you know the H11 headlight bulb is pathetic.
    I am attempting to upgrade to an H9 bulb. I picked up a H9 Philips off Amazon:
    I snipped off the inner plastic piece inside the socket but still cannot get the bulb to either lock in place or snap into the harness adapter.
    Is this the right type of H9 bulb or do I need a different one?
    Thanks.
  2. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Maybe you removed the wrong tab inside the socket? Double check, also you have to remove it all the way down to the bottom of the socket.
  4. xliderider
    7,869
    3,116
    Honolulu, HI
    You don't need an adapter, it might be your problem... Try fitting your modified H9 onto the oem headlight plug, I bet it fits (if you cut the right tab out of the socket properly).
    Someone else bought a harness/adapter and got a 9005 type plug with widely spaced sockets. The H11 sockets are spaced closer together. Maybe that is your problem?
  5. Ginger Jay
    DFW
    I am figured it out guys. Thank you so much for your help.
