Help with HV battery Install
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lengele103, Jun 17, 2012.
  1. lengele103
    lengele103 Junior Member
    Eugene, Oregon
    Had a couple bad cell in my 2006 Prius, with 151000 miles. Bought a re-con battery pack and installed it. Now the car wont start, it would reonize the key. It only powers up in the stanby mode when the key is inserted into the dash.
    Do I have to do some kind of system reset to get the car the repond?
  2. nh7o
    nh7o Off grid since 1980
    1,686
    339
    Hawaii
    There are a number of posts here about pushing the battery connector up to get it completely and finally locked into position. That last click is critical.
  3. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Yeah, I have to admit the not seating the connector got me too, but I would lay odds that's your problem!
  4. Flying White Dutchman
    4,374
    313
    the hv fuse handle!! push it down good!
  5. jdh2550
    jdh2550 Co-Founder, Current Motor Company
    317
    249
    Ann Arbor
    Yep - I had the same experience with that fancy fuse holder safety interconnect thing-a-majig.
    However, after that I also got error code AA4 which was "Negative Contactor Stuck". I took it out and put it on a 12 V battery on the bench and it clunked open and shut a couple of times. I put it back in and all went well...
    When you got a refurbed pack was it a complete package including all the battery Computer and SMR gubbins?
    What did you do with your old pack?
  6. lengele103
    Eugene, Oregon
    Okay, will try restting the plug handle, and I have my old battery pack. Trying to figure out if I will rebuild it and then sell it. Or maybe, add it back as an additional battery pack? I am sure someone has done this already? My son wants to modify the battery pack and then add it to his electric golf cart - ha, ha.
  7. lengele103
    Eugene, Oregon
    Cleaning out the garage and found the old battery pack. Any interested in it? As long as my latest issue is not a battery problem, I need to get rid of it.
  8. JC91006
    16,487
    8,401
    I would be interested in playing with this old battery pack. However not sure how I can get it from Oregon
  9. lengele103
    Eugene, Oregon
    You will just have to drive up sometime.....
