Help with Insulation Test and DTC Codes
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Wardtp, May 20, 2017.
  1. Wardtp
    Wardtp Junior Member
    16
    Albuquerque, New Mexico
    I have been trying to track down an issue with my daughters 2005 Prius. Her mother gave it to her and she started to have some issues with it about three weeks ago. I posted a thread when it originally happened. I have more information now but that thread seems to be dead now. Anyway here is a short history of the issue,
    She had no problems with the car for about 8 months (since she received the car). It started throwing a code indicating there was a bad cell in the HV battery. A cell was replaced that had low voltage. The car ran for about two days with no issues. She drove it to a friend’s home and as she pulled into the driveway and the cars MFD and the instrument panel lights started displaying codes (MIL, triangle of death, ((!)) and a couple more. The car would not restart after this happened so she had the car towed to my home. The tow truck driver had a wheel lift truck and had to use a jump pack to get the car into neutral so it could be pushed into the street so it could be hooked up for the tow. It was towed ft wheels in the air, rear wheels on the ground.
    When the car arrived I put the code reader on it that I had at the time. I also checked the voltage on the 12v battery with a load tester. It was showing 4 volts and a bad battery. It was replaced with a new Optima battery. The code reader I had wouldn’t show me enough information to try and track down the new issues.
    I now have a better handle on the codes involved and they are P0AA6 with sub-codes 526 and 614 and C1310. From what I have found by reading posts this indicates the inverter might be bad but after putting an insulation tester on the circuits I am a little confused about what I am seeing.
    1. With the HV cables disconnected from the master relay forward to the inverter (unplugged at the inverter) I get an almost immediate >550 M ohms using 500 volts on both cables.
    2. All three terminals on the MG1, MG2 and A/C plugs (disconnected from the inverter) show > 550 M ohms but the ohms build slowly to that point.
    3. The 4 HV terminals inside the inverter all show > 550 M ohms but they build slowly to that point with the inverter isolated (at least I think it is). If the larger terminal with the large number of wires is hooked together then the reading goes to 2.9 M ohms and 3 M ohms at the HV terminals where the HV cables from the rear of the car enter the inverter.
    4. All four terminals of the main relay at the HV battery show > 550 M ohms when it is isolated from the battery ECU. However, if the red plug with all the sensing wires from the battery pack is connected to the ECU then I get a strange reading from the positive side of the main relay on the battery side. The reading will rise to a high M ohm reading but it is very very slow.
    Anybody have any ideas because the readings seem a little strange considering the trouble codes. I have three short videos of the Meg Test but I cant seem to get them to upload so they will play correctly. If it helps I'll try to upload them again.
  2. ChapmanF
    15,453
    In case you're new to using a megger, the slow rise of reading indicates you're testing something that has capacitance ... you are slowly storing energy in it until it matches your megger's 500 volts and then you have your reading.
    Do keep in mind that stored energy is also still there when you are done with your test. (A megger typically has a way to drain it slowly back off for you at test's end). An item with capacitance, charged to 500 volts, can bite you.
    -Chap
  3. Wardtp
    16
    Thanks for the information. I thought that was probably what was going on but I really did not expect to see it act that way because of the HV battery ECU and none of the Insulation test results match what the codes indicate as a problem.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    Thats a ground fault from the hybrid battery. From leaking batterys.
    #4 edthefox5, May 20, 2017
  5. Wardtp
    16
    I found the problem. It is the top battery cable from the HV battery into the inverter. There is a metal ring around the inside of the plug that fits inside a metal ring that is bolted to the inverter case. There is a fault between the cable wires and that ring inside the plug. Do you know if the cable can be repaired or not. If not I'll have to find another cable. I'll try an upload a photos of what I am talking about.
  6. ericbecky
    ericbecky Hybrid Battery Hero
    4,369
    3,217
    Madison, Wisconsin
    If the cable is truly damaged, you would need to purchase the entire frame wire.
    Check with the Toyota dealer to make sure you get the correct part number for your VIN.
    It is pretty involved procedure to replace it.
    Fortunately you are in a dry area, as compared to up here in the rust belt.
    Hopefully that lessens the number of snapped bolts/nuts that occur during replacement.
    You may want to buy access to the Prius repair manual so that can print out the steps involved.
    **Edit. Since the error occurred after you were "repairing" the hybrid battery, you may want to check it more thoroughly for problems. Leaking. corrosion, damaged wiring, etc. Just to be sure.
    Raytheeagle likes this.
  7. Wardtp
    16
    Thanks, I will check it out
  8. Wardtp
    16
    I have found by looking through a lot of the postings here that they never seem to have an end. Many times there is never a resolution to the problem and the thread dies. I wanted to end this one with a resolution.
    There was definitely a fault on the upper cable at the inverter, in the plug for the HV + side cable. This was a little tricky to find because if you tested the cable from the battery forward with the cable connected to the inverter there was a fault showing. If you disconnected the cable then again checked the cable there was no fault. This led me to start looking at the inverter itself because the cable by itself showed no fault to the frame of the car. But when I inspected all the HV avenues inside the inverter I could not find a problem. I am sure if I had taken this to a dealer they would have just replaced the inverter (both MGs checked out ok as did the A/C).
    This problem was caused because of a fault between the HV cable and the shield (I guess that is what it is) surrounding the inner wires at the inverter plug. After I replaced the cable with a new one (Actually a used one from eBay) the codes went away and the car runs fine. So if you run into these codes be sure to look at the HV inverter cables. The fault did not show up with a regular volt meter but using an insulation tester it showed right away. I updated the photo to show where to check.
    Raytheeagle, Patrick Wong and dolj like this.
  9. PeterJohn48115
    PeterJohn48115 New Member
    Virginia,USA
    Hi...as per my knowledge the slow rise of reading indicates you're testing something that has capacitance, you are slowly storing energy in it until it matches your megger's 500 volts and then you have your reading.Do keep in mind that stored energy is also still there when you are done with your test.
  10. ChapmanF
    15,453
    Good info ... seems like I've read that somewhere before too. :)
    -Chap
    padroo and m.wynn like this.
  11. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    Yeah, me too!:D
  12. tri4all
    tri4all Member
    98
    52
    Pacific Northwest
    hi I need to replace my frame wire and I haven't been able to find the steps in the repair manual. I have gone as far as removing the back seats only. please help.
  13. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    There are YouTube videos on how you go about removing the battery pack, and all that.
    1. Remove the safety switch first of, after removing the seat at the rear, and wait for 5 minutes for the high voltage capacitors to discharge.
    2. Unbolt all the 12, and 10 mm bolts and nuts, holding the pack down on the rear of the car.
    3. Use handgloves to bring the pack out of the car. The covering on the pack have sharp edges.
    4. Opened up the pack, and located the frame wire for removal.
  14. tri4all
    tri4all Member
    98
    52
    Pacific Northwest
    hi Dxta, I think you misunderstood me. I need to replace the long battery frame wire cable. the one that leaves the hybrid battery and travel to the front where the inverter is. this is part of error code p0AA6 and it looks lilke I will need to replace this frame wire and also the main relay and resistor. but this frame wire looks like a big challenge.
    my hybrid battery is actually in great condition and has no insulation voltage leaks or anything. I megger the whole system and finally narrow it to replacing this frame wire.... I really wish I could just replace the connector some how instead of the full wire. as I think that the connector is at fault.
  15. Elektroingenieur
    2,515
    3,258
    Three Touring
    For replacement of the frame wire (for future readers: the orange high-voltage cable that runs along the bottom of the car, from the system main relays near the HV battery to the inverter with converter assembly under the hood), see these topics in the Repair Manual (more info):
    Engine/Hybrid System: P112 Hybrid Vehicle Control: Frame Wire: Components
    Engine/Hybrid System: P112 Hybrid Vehicle Control: Frame Wire: Removal
    Engine/Hybrid System: P112 Hybrid Vehicle Control: Frame Wire: Installation
  16. Wardtp
    16
    I'll see if I can give you the reader digest version. I've done this once. The first thing is you have to pull the safety switch out of the HV battery to make it safe. You have to remove the cover from the battery so you can disconnect the cable. The rear seat needs to come out also. Then disconnect the cable from the inverter under the hood. You will need to get the car up on jack stands or a lift if you can get your hands on one, you will need to get under the car. On mine (2006) the cable runs along the bottom of the car covered by a black plastic skid plate from where the cable comes out of the bottom of the rear seat floor pan to where it runs up into the engine compartment on the drivers side. This is the most time consuming and frustrating part. There are a lot of small nuts and plastic retainers holding the skid plate on. I would suggest just spending some time looking at it and it will be apparent what you need to take off to get the skid plate off. The HV cable runs inside the plastic skid plate. Just take your time and buy a box of band-aides. PM me and I'll try to walk you through it. It is not too difficult but it will take a while and it does get pretty frustrating trying to feed the cable up into the engine compartment because there is not much room to work unless you take the inverter completely out. Good luck
  17. tri4all
    tri4all Member
    98
    52
    Pacific Northwest
    thank you Wardtp. I actually found the removal instructions. it starts on page HV-556. it looks very time consuming.
    1. do you really need to remove the silencer and the steering shaft?
    2. do you recall using a jack to SEPARATE FRONT SUSPENSION CROSSMEMBER?
    I have done everything else on the list but these two items.
  18. Wardtp
    16
    When I replaced mine I did not have to do either of those steps. I did not have access to a manual when I did mine. You also need to keep in mind the manual wants you to remove the complete front end of the car to replace the head light bulbs. I would suggest just studying the cable layout in you vehicle and see if that is really necessary. The 2005 that I replace the cable on that was not the case.
  19. tri4all
    tri4all Member
    98
    52
    Pacific Northwest
    good to know. getting ready to hit the junkyard...
    I have two different manuals, 05 and 08 I think, and they are not always the same. for the isolation voltage leak test that I recently did the older manual had more detailed info and the other one skipped some useful steps....
  20. ChapmanF
    15,453
    Hi @tri4all,
    Is this the thread your message about the megger was about? You said something about "a megger like the one I have", but I'm not seeing much information here about the specific megger you have.
    When you say you "could not get any readings" on the frame wire, what do you mean exactly? That the reading went offscale high? That actually is a reading, and it's generally the good-news kind. It means the insulation is so good there is not enough conductivity for the instrument to measure.
    What's your placement of the test leads when you get the non-reading reading? If I remember right, each frame wire should be tested from its inner conductor to its outer shield.
    The resistance unit is spelled ohm with an m. Named after Georg Ohm. Also spelled Ω (a Greek "omega", see what they did there?). A Mohm or MΩ is a million ohms.
