Help with my fuel economyh
Discussion in 'Gen 2 Prius Fuel Economy' started by Craig Doucette, May 25, 2007.
  1. Craig Doucette
    Craig Doucette New Member
    I bought my Prius a few months ago. My morning trip to work one way is just over 1 mile. My fuel economy is therefor in the low 30's. I believe this is because my batteries state of charge is not high enough to benefit the economy. The mileage improves as the engine warms up and the batteries charge up. Is there an answer to improve my fuel economy, without driving farther?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(Craig Doucette @ May 25 2007, 08:00 AM) [snapback]449704[/snapback]</div>
    No, that trip is too short to allow the system to get fully warmed up and you're going to have lower mileage. If you're the sole occupant for a trip that short you should consider walking or riding a bike. Otherwise you'll just have to accept that your FE will be pretty low.
    One other alternative to consider is a NEV (neighborhood electric vehicle)...these are small EVs that are ideal for very short commutes like yours.
  3. jdenenberg
    jdenenberg EE Professor
    3,926
    1,925
    Trumbull, CT
    2020 Prius
    LE AWD-e
    <div class='quotetop'>QUOTE(Craig Doucette @ May 25 2007, 09:00 AM) [snapback]449704[/snapback]</div>
    Craig,
    Evan is correct (as usual), but you can slightly improve your MPG on short trips by installing (and using) an Engine block heater (EBH). They are sold as an option in Canada (and EBH shows a larger effect in cold weather) and can be purchased on the web. Installation instructions are also on the web and any decent mechanic can install one.
    The problem has little to do with battery charging, it is just that during the warm up cycle, your Internal combustion engine (ICE) runs continuously to get the system up to temperature. This is also a primary reason for lower MPG in very cold weather.
    JeffD
  4. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    I agree with efusco!
    If your commute is 1 mile then please consider walking, biking or buying a NEV golf cart.
    The prius will always warm up the catalytic converter as this over-all reduces emmissions. This takes more then a mile or several minutes. There is nothing you can do about it.
    If you installed the EV switch you would be able to quickly drain the battery but have no way of charging it.
    I wish I had 1 mile commute!
  5. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(SomervillePrius @ May 25 2007, 05:46 AM) [snapback]449730[/snapback]</div>
    I'm sort of joking, but since your commute is so short you (Craig) could convert to a plug-in without adding more batteries. If you topped off your batteries to SOC 80% everytime you parked, using a plug-in design, and of course installed an EV mod, you could get terrific mileage. Of course, you'd have to let your engine spin up every once in a while to keep the engine lubed. You'll have to ask others for details. Some are doing a legitimate PHEV conversion for commutes of up to 30 miles.
    Dave M.
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    <div class='quotetop'>QUOTE(SomervillePrius @ May 25 2007, 06:46 AM) [snapback]449730[/snapback]</div>
    I agree! :)
  7. Vic Doucette
    Vic Doucette Junior Member
    Michigan
    You should listen to your big brother more often!
    I listened to you and bought a Prius. I am getting an average of about 53.5 mpg on my second tank, what with my 20-mile trip to work every day. You got great milage on your trip to Lauderdale, but are disappointed with the trip between your house and work.
    I've said it before, Craig -- ride a damn bike! <_<
  8. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    <div class='quotetop'>QUOTE(jdenenberg @ May 25 2007, 09:30 AM) [snapback]449721[/snapback]</div>
    Does anybody know the OEM Toyota part number for the engine block heater?
  9. priussoris
    priussoris New Member
    1,005
    <div class='quotetop'>QUOTE(bestmapman @ May 26 2007, 06:45 AM) [snapback]450345[/snapback]</div>
    Toyota of Canada Inc.
    p/n CO140-00889
  10. bestmapman
    1,289
    242
    <div class='quotetop'>QUOTE(priussoris @ May 26 2007, 08:50 AM) [snapback]450346[/snapback]</div>
    I called my dealer and they said it was a Canadian part and they couldn't order it. Any ideas here?
    Any Canadians out there that would order this for me?
  11. Darken
    Darken Active Member
    553
    49
    PA Dutch Country
    <div class='quotetop'>QUOTE(bestmapman @ May 26 2007, 09:09 AM) [snapback]450351[/snapback]</div>
    One option would be to order it from this site:
    http://www.metrotpn.com/ProductDetails.asp...mp;SortIndex=22
    I've used them and was very pleased with their service.
  12. dmckinstry
    1,034
    <div class='quotetop'>QUOTE(bestmapman @ May 26 2007, 06:09 AM) [snapback]450351[/snapback]</div>
    You can order one through Jesse Wright of Metro Toyota.
    The info is below.
    Jesse Wright
    Internet Parts Sales
    Metro Toyota
    Cleveland, Ohio
    1.877.885.2900
    [email protected]
    www.metrotpn.com
    Dave M.
  13. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(Vic Doucette @ May 26 2007, 07:17 AM) [snapback]450338[/snapback]</div>
    LOL!! Sibling rivalry on PC...gotta be a first! :D
