Help with Occupant Detection Parameters
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by SamanthaC0716, Jun 16, 2018.
  1. SamanthaC0716
    SamanthaC0716 Active Member
    333
    115
    If anyone has Techstream, can you please tell me what your Occupant Detection Parameters are?
    My Passenger Airbag ON / OFF is not working, and the values I’m seeing in TechStream seem quite off... I’m showing around -166 pounds for both sensors. I have no idea how to reprogram these, but I need to confirm that what my parameters are set at are incorrect first. I looked all over the darn internet and could not find what the values are supposed to be, so anyone that has TechStream and can post their’s, I’d appreciate it so much.
    iPhone ?
  2. ChapmanF
    15,663
    Looks like you'll probably want to look up the recalibration procedure in the repair manual on techinfo.toyota.com and go through it. For some cars, you need a certain set of weights to place just so on the seat; I don't remember if that's part of the Prius procedure.
    Has that seat ever been removed and reinstalled? Before you get too deep in, is there anything wedged up underneath it, or leaning on it from the back seat area?
    -Chap
  3. SamanthaC0716
    333
    115
    Thank you so much!!!
    Yes, it’s actually a Toyota FRS seat. Another member installed the same seats without issue. The shop that did the install messed something up. My driver seat slides freely, but the passenger does not. I think the rails need to be drilled out a bit more. That’ll be my next move now that I know the values are definitely off. I’m thinking the seat is “pinched” in the rails, and that’s making the sensors read the weight incorrectly.
    iPhone ?
  4. SamanthaC0716
    333
    115
    Looking back through my messages with the other guy on here that installed FRS seats, I’m recalling that my last working hunch was that the sensors were in the wrong place... I’m taking the seat out tonight and solving this. It was over 6 months ago that I had them installed. Gotta love paying someone to do something you then have to fix...
    In looking at your data, I notice that it looks that you have readings from 4 sensors. I only had readings from 2. Hmm... The plot thickens. I’m out now and not back until late tonight, but I can’t wait to get the passenger seat out and see what those fools did.
    iPhone ?
  5. ChapmanF
    15,663
    Yes, there's a strain gauge at each of four locations where the seat bottom attaches to the carriage. Any installation issue that keeps those parts under stress will make the OCS difficult (or impossible?) to calibrate....
    -Chap
  6. SamanthaC0716
    333
    115
    So, we took the seat out and redrilled the rails to not place tension on the sensors. (The IDIOTS who installed them had the rails and bolts flexed so badly that the one bolt is still in. We cut the head off. They had stripped the Torx shape completely off.)
    The seat now slides freely when installed. I tried to recalibrate, and it still failed! Both sensors are reading the same astronomically-off values... Any ideas?
    iPhone ?
  7. ChapmanF
    15,663
    You're still saying "both" and not "all four". Are two of them missing? Did the whole kit and kaboodle get transplanted from some other car?
    I guess it could be a c thing ... I've got four, but that's in the liftback.
    -Chap
  8. SamanthaC0716
    333
    115
    Hey, Chap... What year is your car? I’m wondering whether different years have 4 sensors versus two. I believe that 2 is correct, one on each side at the rear of the rail, but your printout has 4 readings, and you reference 4 locations.
    iPhone ?
  9. ChapmanF
    15,663
    Well, I'm just visiting the c forum to answer your post; you've got a c and I've got a liftback.
    -Chap
  10. SamanthaC0716
    333
    115
    That must be the difference... Ok. Well, I have no idea then, but thank you for chiming in!
