Help with Rims
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Atchleyxx90, Apr 30, 2020.
  1. Atchleyxx90
    Atchleyxx90 New Member
    Hilliard,Ohio
    2015 Prius c
    I have a 2015 Prius C and I unfortunately bent one of the stock rims. I’m looking to replace the entire set, I also want to make sure they are light weight. Can anyone link me a set of good rims that will fit? I actually need new tires but I figured since I have a bent rim it’ll be good to just buy some rims and take them in when I get the new tires. I’m really bad with things like this.
  2. ETC(SS)
    7,334
    The lighter the rims, the more easily they are bent.
    Aftermarket rims will take you into a world of non-OEM tire sizes and bolt patterns that can lead to other problems - not the least of which if you go to sell your car some day - then somebody like me won't go near the car for fear that you've been tinkering with OTHER things besides just fixing a whammed rim.
    Since rim swaps are one of the more common mods for small cars, there is a large supply of homeless stock rims out there looking for a new forever home.
    I would get 2 OEM rims off of someplace like eBay, Amazon, etc and use one to make all four of your corners straight again.
    I would use the other as a full size spare for long trips or the next time you have a ramp strike. When you get new tires, see if they will put the best of the 4 old tires on the other rim.
    Good Luck!!
    iceman13 and dig4dirt like this.
  3. Atchleyxx90
    Hilliard,Ohio
    2015 Prius c
    I found these and I read that someone was able to pop these on, Konig Helium Silver Wheel (15x6.5"/4x100mm)
    Can anyone confirm if these actually do fit? And if so will I need any additional hardware?
    I’ve also heard things about different tire sizes? I was planning to use 175/65/15
  4. AlphaFox
    AlphaFox New Member
    23
    East Longmeadow, MA
    2018 Prius c
    Just have your one rim fixed.
