Help with the Energy Screen
Discussion in 'Gen 2 Prius Main Forum' started by aubergaz, May 8, 2006.
  1. aubergaz
    aubergaz New Member
    28
    Phoenix, Arizona
    I'm sure the question has been asked many times and if there is the definitive thread, please lead me to it.
    Can I get a SIMPLE explanation of the yellow bars on the engery screen.
    I surmise that the vertical one is a current bar graph of 'instant' mpg. But I'm lost with the horizontal one showing 'minutes' and that some bars show the car icon and other don't.
    How can I manage it? What is it telling me about my driving tendencies? What should my 'goals' be as I watch it?
    Help educate this 10 day owner.
    Thank you.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    First, it sounds like you're describing the "Consumption" Screen, not the Energy screen. The Energy screen is the one with the ICE, motor, wheels, etc.
    The consumption screen is a little odd, but it can be useful in some situations.
    1)As you surmised, the bar on the far right is the instantaneous MPG...low when you're accelerating, high when coasting, somewhere in the middle at a stead cruise.
    2)Bottom has trip miles and MPG--that will be for that specific/current tank if you have an '04/'05, or for the lifetime of the car or since the last manual reset if you have an '06.
    3)Every 5 minutes of continuous driving a bar will appear. The newest bar always appears on the right side of the graph and pushes the previous bars over to the left.
    4)Each of those bars is your average mpg over that 5 minute period. Thus, it's most useful if you were going a steady speed...let's say 55mph for that entire 5 minute period. Where your instantaneous mpg may have jumped up and down during that steady speed drive due to hills and such the bar graph will show you what your average mpg was during that time. By the same token, in stop and go traffic and during a 5 minute block where your speed varied a lot the 5 minute bar doesn't tell you much. If you averaged 60mpg during 3 minutes of that trip and were at a stop for the other 2 minutes your actual mpg was 60mpg, but the consumption graph will say it was closer to 40mpg.
    5)The little leaf cars will only show up if you regenerated energy via the regenerative brakes. Thus, if you drive for 15min. on the highway without using your brakes to stop or coasting down any hills you'll have no regen leaves show up. If you're in stop and go city traffic you'll have a number of the cars or partial cars show up. Each one represents 50Wh of energy regenerated (enough to run a 50W light bulb for 1 hour).
    Hope that helps.
  3. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    Each bar represents the average mpg over the 5 min interval.
    The little green cars represent 50Wh (Watt-hour) regenerated.
    The screen basically tells you the mpg trend over the last 30 min.
    Edit: dang it, doc beat me to it. Don't u have ppl to save? :p
  4. aubergaz
    aubergaz New Member
    28
    Phoenix, Arizona
    <div class='quotetop'>QUOTE(efusco @ May 8 2006, 01:52 PM) [snapback]251605[/snapback]</div>
    Thank you so much. I hope it wasn't a stupid question.
    Another participant made a rather demeaning note about me and a previous question or comment of mine.
    I appreciate your patience with me.
  5. aaf709
    3,862
    2022 Prius Prime
    I understand that it's better to have little (or no) leaf cars. Is that true? If so, that would be a goal.
  6. jmccord
    jmccord New Member
    199
    San Diego, CA, Earth
    Evan,
    Doesn't being at a stop during part of the 5-minute interval cause your graph to display a higher value? I seem to recall seeing two maxed-out bars during a recent stop -and-go journey through a construction zone. It made me think, that with little or no fuel consumed, the computer is trying to divide by 0.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    <div class='quotetop'>QUOTE(aaf709 @ May 8 2006, 03:13 PM) [snapback]251617[/snapback]</div>
    Never having to brake or slow down is always better, but not always possible. The leaf cars are showing regened energy from braking, slowing down, or holding speed while going down hill. On a normal car, all of that energy would be wasted as heat, but on the Prius about 40% is captured and reused through regenerative braking. It's a good thing that the Prius regens that energy when it has to, but it's even better if it doesn't have to.
    Tom
  8. efusco
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(jmccord @ May 8 2006, 02:26 PM) [snapback]251626[/snapback]</div>
    That's why that graph is so unreliable/unhelpful in most cases.
    If you use even just a little gas during a 5 minute block you'll show nearly 0mpg, if you use no gas you'll show 100mpg, and if you're stopped part of the time it averages the mpg over that 5 minutes...just kinda weird, but amazingly it can be helpful. I find that over a routine/frequently traveled route I can/could make it a goal to get my mpg up over 50 or 75 or 25 or whatever for a particular 5 minute segment with the ultimate goal of improving my overall mpg.
  9. Kiloran
    Kiloran New Member
    1,225
    <div class='quotetop'>QUOTE(efusco @ May 8 2006, 04:59 PM) [snapback]251701[/snapback]</div>
    That's why I'd like to see Toyota switch over to (or have a selectable option for) reporting average mileage over distance rather than time (say 1, 5, or 10 miles rather than 5 minutes). If you don't move, the screen wouldn't update and when you looked at the bar graph, you could accurately estimate your overall average mileage.
  10. brandon
    brandon Member
    771
    Manhattan, KS
    But you could also be running the ICE when you are stopped (and not accumulating mileage), so those results would be skewed, too.
  11. Kiloran
    Kiloran New Member
    1,225
    <div class='quotetop'>QUOTE(brandon @ May 8 2006, 05:27 PM) [snapback]251720[/snapback]</div>
    Nope. The gas used would be used in calculating the next x-mile bar.
  12. darelldd
    6,057
    389
    Northern CA
    <div class='quotetop'>QUOTE(Kiloran @ May 8 2006, 02:42 PM) [snapback]251735[/snapback]</div>
    I'm not so sure that is happening. I can now switch the speed wire off that feeds my MFD while I drive, so it thinks I'm holding still. When I click it back on, it thinks that I just started moving and starts counting from the beginning. Doesn't seem to care what I was doing when it thought I was holding still and burning quite a bit of gas (65mph)
    <div class='quotetop'>QUOTE(qbee42 @ May 8 2006, 01:22 PM) [snapback]251669[/snapback]</div>
    Tom... curious where this number comes from. I've heard (and believe) a much lower value, though I have no hard numbers one way or another. 40% would be amazingly high for a system like this. The best EVs, that are tuned for max regen are only getting on the order of 50% - and that is with many more systems in their favor.
  13. darelldd
    6,057
    389
    Northern CA
    I'll give it my shot too.
    <div class='quotetop'>QUOTE(aubergaz @ May 8 2006, 11:24 AM) [snapback]251589[/snapback]</div>
    I'll try it with the fewest words I can muster:
    Each bar represents the average mpg for a given 5 minute interval of driving.
    All the bars are vertical. The 5 minute ones just march across the screen, moving one position over every five minutes of driving. Eventually, the first bar will fall off the left side of the chart as the next one comes in from the right. The far right one, is as you surmise, the instantaneous mpg bar. You can see a repeat of this in digits on the energy screen.
    After a couple of weeks, you'll have this all figured out, and won't bother looking at it much. ;)
  14. bgdrewsif
    bgdrewsif New Member
    497
    Phoenix, Arizona (formerly Bowling Green, Ohio)
    Just my two cents, but for in-town driving, I have found the Energy screen (the one with the car diagram) to be most useful for trying to keep myself on battery power if possible.
    On the other hand, I have found the Consumption screen the most useful for extened highway driving (which for me is usually from Bowling Green-Findlay or Bowling Green-Toledo or in the summer Bowling Green-Catawba Island/Port Clinton For me it is 25 miles south on I-75 to findlay, 15-20 miles north on I-75 to toledo and about 45 minues northeast on SR 105/163 to the lakeshore or an hour to cedar point amusement park (#1 amusement park on earth 8 years in a row!)
    Consumption screen below:
    [attachmentid=3332]
  15. Kiloran
    Kiloran New Member
    1,225
    <div class='quotetop'>QUOTE(darelldd @ May 8 2006, 06:51 PM) [snapback]251768[/snapback]</div>
    It's not. This is a wish-list item.
    <div class='quotetop'>QUOTE(Kiloran @ May 8 2006, 05:19 PM) [snapback]251712[/snapback]</div>
    Miles per gallon does not have a time dimension, just miles and gallons.
    That's why the current screen is problematic.
    When I look at the consumption screen, I want to see how far I've driven and how much gas was used.
    (I expect the current arrangement was dictated by the marketing division so most owners would occasionally get to see 100mpg bars when stuck in bumper-to-bumper traffic.)
  16. Sarge
    Sarge Senior Member
    1,302
    758
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(ScottY @ May 8 2006, 02:57 PM) [snapback]251607[/snapback]</div>
    It should also be noted that in countries that run on the metric system such as Canada (and other countries aside from the US), the consumption is measure in Litres per 100km, which is a measurement of how much gas is consumed for a set distance, rather than MPG, which is a measurement of how much gas it consumes for a set distance.
    Therefore, in this system, the bars are inversed - having NO BAR means you are burning zero gas, while having a full bar (10+ Litres/100km) means you are getting very low mileage - generally during warmup. In fact, the four Y-axis marks are 2.5L / 5.0L / 7.5L / 10L, so it numerically resembles the US system very closely with simply a shift of the decimal point, and readings often hang around the mid-mark of 5.0 (~47MPG).
    Otherwise, the car is identical. B)
    Kevin
  17. kfarad
    kfarad Junior Member
    56
    Palo Alto, CA
    Did you see the 2007 Camry hybrid screen? Looks like the have a per-minute graph. It's awesome![​IMG]
  18. Kiloran
    Kiloran New Member
    1,225
    <div class='quotetop'>QUOTE(beeri @ May 9 2006, 12:46 PM) [snapback]252192[/snapback]</div>
    Except that it's not per mile. :( :p
  19. mike0422
    mike0422 New Member
    83
    Northern VA
    Yeah, but look at the MPGs. 16.3 best and 26.8 average.
  20. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    <div class='quotetop'>QUOTE(Mike0422 @ May 9 2006, 10:03 AM) [snapback]252207[/snapback]</div>
    Cool...average is better than best. That makes no sense at all.
    Oh, yes, it does. If we're talking liters per km then smaller values are better. But then why does it say MPG?
