help with weak FAN
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nonamebrand, Sep 30, 2013.
  1. nonamebrand
    nonamebrand Junior Member
    canada
    Hi we have 2 prius in the family :)
    i noticed that my 2007 prius fan blows weaker than the other 2005 prius.
    even with the ac on its weak in comparison to the other car. Any advise what the culprit could be?
    i opened the hood and check if there were any leaves blocking any holes and didnt see any.
    thanks in advance!
  2. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Have you checked the cabin filter?
    cwerdna likes this.
  3. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    223
    Nature coast, Florida
    Three Touring
    It could be the blower fan located behind the glove box on the bottom. Since you have two Prii, you could remove the one from the 05 and put it in the 07 as a test. I had to replace mine after 6 years. Worked great after that... It is held in by four screws and a wire harness/clip. Not a difficult swap!
  4. nonamebrand
    canada
    the cabin filter is fine, theres no leaves there. will see the blower fan today. thanks!
