  1. JuanGimenezpy
    JuanGimenezpy New Member
    Asuncion - Paraguay
    Good morning !
    Please I need your help to solve the problem of my Toyota Prius car in 2008. The car is cold while working well for a maximum time of 1 hour, the first symptom is to stop the air conditioner to cool, then turn on the light triangle warning, after driving a little longer for the vehicle and no more moves. If you wait until the vehicle returns to work for a few minutes to cool, then everything fails again with the same symptoms. And you change the battery 12 Volt, and you change the water pump hybrid system and I can not solve! Please I ask you to help me to run my car .... thank you very much!
  2. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Juan, you will need to pull the DTCs for anyone to offer coherent assistance even if this means paying a diagnostic fee at a dealer. Or conversely you could purchase a mini VCI mated to a computer and retrieve your DTCs yourself. Either way the community needs more information to help you in my opinion.
    valde3 likes this.
    49,432
    have you cleaned the hybrid battery cooling fan?
  4. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Moderators. This person gets his/her kicks out of copy/pasting the same inverter pump failure symptoms in various threads, or the various on-line translators are mis-translating what everyone has been telling him/her to do.
    Patrick has already provided the sound solution to the person in this thread. Code P0A93 | PriusChat
    The only remaining solution is for OP to fly someone out to him/her, for the repair. I guess he/she can not find a competent Prius mechanics out in Paraguay, as the Prius may have never been meant to be sold there.
