  1. Keith Miller
    Keith Miller New Member
    Missouri
    I have a 2011 Prius that just started giving me an issue. Yesterday it wouldn't start up, and after going through some things here I opted to change out the 12volt battery. Got that installed, but the car will still not start, and it's saying "check hybrid system". Called the dealership and they suggested changing the fob battery, still nothing out of it though. Where should I go next? This is my first hybrid.
  2. JC91006
    16,482
    8,400
    Bring it to the dealer, might be an inverter issue, which is covered under extended warranty
    Did you test the old battery?
    49,504
    did you test the new battery?
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    OP, did you try jumping the old battery? If you did, did you make sure that the polarity on the jump cables were correct?
    If you did a reverse polarity jump, a new battery will not help you.
  5. Keith Miller
    Missouri
    Yes, the old battery was tested and failed, new battery was tested twice, the yellow top. How can I test the inverter? I would still assume that the gas engine would turn over?
  6. Keith Miller
    Missouri
  7. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Well it doesn't quite work like a conventional car......in that the gas engine doesn't really "turn over" to start.
    All of the electronics must "come alive" to start and the gas engine "turns over" later as needed.
    The key to THAT, however, is the hybrid battery and it's control circuitry because it is the HV battery that actually turns over the gas engine.
    So......unless your new battery is not fully charged up (yes it can pass a load test and still have low enough voltage to fail in use) then your original assumption that the 12 V battery was the only problem has likely turned out to be false and you need to have it towed to a dealer for diagnosis.
  8. Keith Miller
    Missouri
    How does the hybrid battery come out to test the cells? I read on another post that there was a blown fuse, and I haven't gone through all my fuses yet. Quite honestly, this is the reason I feared purchasing a hybrid, guess that's why I was at a dealership looking at new trucks the night before it broke down.
  9. Keith Miller
    Missouri
    And really? This car is supposed to be super "smart" and it's not throwing me a code?????
  10. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Are you using the Techstream software? The Prius is actually smarter than most code readers and they can't read all the codes it can generate. The Toyota shop (or someone with the right equipment) can find out the voltage and internal resistance of each cell and should be able to tell you exactly what's going on.
  11. Mendel Leisk
    38,732
    If it's saying "check hybrid system" it's throwing a code. But you would likely need Techstream (Toyota specific software, on a laptop, with special OBD cable) to read it. Go with post #2. And #10: bring it in to the dealership, get it checked out.
    jerrymildred likes this.
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    It's always difficult to gauge a posters desire, knowledge, experience, and skill in regards to approaching Prius repair issue as a DIY task.
    Some want to obtain software, readers, obtain codes, and then go the whole...whatever it takes route.
    Which is fine...if you have the desire, knowledge, experience and skill.
    My warning would be a Hybrid Battery is a high voltage piece of equipment. Knowing what you are doing when dealing with it...is a safety issue.
    If you don't really have the desire, knowledge, experience or skill?
    Then my advice is to just not pass GO, and head directly to your Toyota Dealership Service Center and/or a qualified Hybrid Trained Mechanic.
    Well, I can understand the frustration if your vehicle is simply NOT working. BUT..
    The Prius I think has a well deserved reputation as being a reliable vehicle.
    That doesn't mean things don't wear out or break down or fail.
    But that reality can happen with a Prius or a Truck.
    Yes, you bought a Hybrid, which means it has additional hybrid components as a hybrid machine. And it may or even may NOT be a specific Hybrid Component that has failed... BUT...it didn't break down BECAUSE it's a Hybrid.
    PS.
    Given your admitted lack of experience with a Hybrid, I'm really recommending just going to a Dealership.
  13. Keith Miller
    Missouri
    Yeah but my redneck side is saying dive in and take the bull by the horns. I think I am going to download the software from Toyota for $55. If nothing else I can get the codes cleared.
  14. Mendel Leisk
    38,732
    Even when there's a good chance that it's a warranty repair, inverter related??
  15. Keith Miller
    Missouri
  16. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    I have worked on cars all my life. However I know very little about the prius mechanically. Take it to the dealer. The diagnosis will run about $55 or a little more, you will know what is wrong, and then you can decide options.
  17. The Electric Me
    9,083
    5,798
    LOL!
    I'm actually scared for you now.
    OK...but just remember...the Hybrid Battery is a HIGH VOLTAGE piece of equipment.
    In reality and even in metaphor...taking the bull by the horns is rarely a good idea.
    Strike That...Taking a Bull By The Horns is NEVER a good idea.
    Reconsider the safer Dealership route.
  18. Keith Miller
    Missouri
    I've worked on a lot bigger, the issue is finding where to start on this thing.
  19. The Electric Me
    9,083
    5,798
    I'm not going to talk you into just taking it to a dealership am I?
  20. Keith Miller
    Missouri
    Nope, I'm a stubborn SOB that likes to exhaust all possibilities
