help
Discussion in 'Gen 2 Prius Technical Discussion' started by Christa3536, Mar 18, 2018.
  1. Christa3536
    Christa3536 New Member
    Ohio
    I bought a used 2007 Prius 136,000 miles dash lights came on the next day. The big red triangle, the check engine light, the vsc and the (!). I have replaces the 12v battery. No changes. My car runs on the gas engine all the time. From start to shut off. trying to figure if the charging system is working or not. Took it to airport Toyota they said I need a new HV battery.HV failed block 5. Is it safe to drive? Is the car worth fixing or should I sell it? Thanks in advance.
  2. k1ngn0thing
    k1ngn0thing Member
    205
    49
    MA
    2016 Prius c
    You can also just replace block 5 with 2 new (used) modules. Less than $100 in parts, not sure about labor. I'm pretty sure Toyota won't do it though. Probably shouldn't keep driving if you can help it to avoid potentially degrading surrounding cells.
    I'm in a similar situation, with one of my blocks being out of balance. I'm hoping the Prolong kit will fix it so I don't have to tear into the battery.
    I would get a cheap OBD bluetooth scanner and use the Torque Pro app ($5) to see all the voltages and codes for yourself. I use this one. I also tried a cheaper one (orange and black sticker) but it was unable to read the voltages.
  3. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Hope you didn't overpay for this car. It's risky buying an older Prius - as you have just found out.
    The fact that you took it to a dealer indicates that you might not want to do a repair on your own.
    The dealer price for a new pack looks pretty good if it includes installation. If not, you have
    a more difficult decision to make.
    How did you find out about Priuschat? I know it's no help now, but you should have searched
    on this site or asked us about the risks of buying an older Prius before you did.
  4. jadziasman
    1,355
    487
    District 6
    Priuschat regulars know for a fact that Toyota won't do it.
  5. k1ngn0thing
    k1ngn0thing Member
    205
    49
    MA
    2016 Prius c
    I'm guessing they salvage your old battery and sell as a reconditioned unit?
  6. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    The best option is a new batt from Toyota or on this site we have a seller of a clone, shall we say.
    Assuming you are not a car geek you will need to find someone to help install.
    One approach if you have time is to call Toyota USA for goodwill assist on price. Worth a shot but no guarantee.
  7. JC91006
    16,482
    8,400
    I would not buy a prolong kit with the new prices of batteries now. The kit is nearly half the cost of the new battery and you'll have to "hope" it keeps your battery healthy or you'll still end up buying another battery. A new battery however will last 10 years without any maintenance. A no brainer.
  8. Christa3536
    Ohio
    Thanks for the help. Can anyone tell me why the engine is always running? From start up to shut off.
    #8 Christa3536, Mar 18, 2018
  9. jadziasman
    1,355
    487
    District 6
    Because your HV battery pack is too weak to permit it to start the gasoline engine every time your Prius is at a stop. The stop-start feature will work again once you get a remanufactured or new pack (that latter is the much better option).
