Help
Discussion in 'Gen 3 Prius Main Forum' started by jepsprius23, Apr 19, 2018.
  1. jepsprius23
    jepsprius23 Member
    77
    78
    orange county
    whats that number for? all 4 wheels has different number...its stocks factory wheels..
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,193
    5,889
    Columbia, SC
    maybe it's a number to track what casting mold was used for that rim?
  3. jepsprius23
    jepsprius23 Member
    77
    78
    orange county
    hmmmmm
  4. BZzap!
    BZzap! Senior Member
    1,607
    877
    Probably just production information codes
  5. RRxing
    RRxing Senior Member
    2,519
    1,790
    NEPA
    I'll second casting numbers.
  6. BZzap!
    1,607
    877
    After doing some research I’ve found that these numbers have to do with DOT specification codes for wheel dimensions. They designate wheel size, offsets, hub diameters and a host of other wheel attributes.
  7. Johnny Cakes
    Johnny Cakes Senior Member
    1,010
    761
    Virginia, USA
    That sounds logical, but the fact that the OP said that "all 4 wheels has different numbers" seems odd. The wheel size, offsets, and hub diameter should be the same for all for wheels.
  8. BZzap!
    1,607
    877
    I would guess that the different numbers would indicate time stamp information.
  9. StevePrius321
    StevePrius321 New Member
    South Gate
    Hello guys I’m new to this and have been having installing this aftermarket radio on my 2010 Prius I’m not sure what I would need because the cables don’t connect well and it seems to be for the model with the GPS which I do not help. If you guys can do a big favor in helping me out !
