  1. Mason
    Mason New Member
    Hardy, VA
    My AC in my 2010 Toyota Prius doesn't blow very hard(it never really has). It's got 250k miles on it(I bought it a year ago with 207k) and my parents(2011) and GF(2007) each have a Prius and their AC blows way harder and colder than mine. How do I fix this?
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    This is NOT meant to be a mean or nasty comment, just the truth:
    If you have to ask, then YOU probably can't fix it........beyond checking the cabin air filter, the air inlet by the base of the windshield and the radiator to be sure it isn't plugged up.
    Call around to some dealers in your area and ask what it would cost to have them diagnose the problem.
  3. Mason
    Mason New Member
    Hardy, VA
    I'll do it myself. Get lost
    49,466
    air pressure is one thing, and cold is another. make sure you're not in eco mode.
  5. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    ...or in Auto. Auto will adjust fan speed automatically, depending on outside air temp, cabin temp, and amount of sunlight hitting the solar sensor.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,910
    Columbia, SC
    This sounds like the most common solution. It's amazing how clogged they can get. It's like trying to breathe through a triple layer face mask...
  7. TMR-JWAP
    6,225
    5,910
    Columbia, SC
    In the big scheme of things, the quantity of air being moved by the blower depends on a suction path, a discharge path and blower speed. Temperature of the air is a completely different consideration.
    Determine which of the 3 areas is the cause of the 'reduced' flow and correct it.
  8. pjksr02
    pjksr02 Active Member
    532
    225
    Connecticut
    Can you hear the fan running faster as you set the speed higher?
    If there's a problem with the mixing servo, that will set a code, readable with Techstream (or other high-level code readers). It's not uncommon for a servo to get "stuck". Mine got "stuck" for some time, and I almost decided to replace it, but then fortunately it "unstuck" in hot summer weather, two years ago - it still is working OK, knock on wood.
    PS - Do you know about the EGR system clogging issues in these cars? Has yours been cleaned?
