  1. tyler2013prius
    tyler2013prius Junior Member
    Nashville, TN
    I
    Help: 2013 with about 87k miles. No issues up until this point. Only routine maintenance. Car won't start and I've got the dreaded "Check hybrid system, Stop the vehicle in a safe place" message.
    49,433
    are you sure it isn't out of gas?
    start with a free 12 volt battery load test at an auto parts store, then if it is okay, you will have to read the trouble codes
    tankyuong likes this.
  3. tyler2013prius
    Nashville, TN
    I
    It’s not out of gas. I last drove it on Sunday and I had an estimated 20 miles of gas left in the tank. The car won’t start.
  4. tyler2013prius
    Nashville, TN
    I
    The 12v battery is at 11.3v.
  5. TheLastMojojomo
    TheLastMojojomo Active Member
    231
    162
    US
    How did you check the 12v voltage?
    If your gas was so low it estimated only 20 miles left in the tank, that is extremely low.
    What exactly occurred before those lights were activated and the check Hybrid System warning triggered...
    Did the engine idle at all before the dash lit up? Or did it go straight to dash lights?
    #5 TheLastMojojomo, Nov 10, 2021
  6. ASRDogman
    ASRDogman Senior Member
    6,084
    3,271
    Depending where you checked it, that's low. And since it won't start, I guess you check it
    at the fuze box under the hood, or on the battery, in the trunk?
    Maybe you can get a jump to get it going then get a battery.
    If you have 2013, and haven't changed the 12v battery, it's probably time for a new one
    seeing that it's 8 years old.
