Hep me fix my windows
Discussion in 'Gen 2 Prius Accessories & Modifications' started by fruzzetti, Dec 21, 2007.
  1. fruzzetti
    fruzzetti Customization-Obsessed
    377
    California (Pulled over 6x, ticketed 2x for tint)
    Hah; I suppose it's not actually broken. But I think this is something that was considered and they took the cheap route. I -hate- that. And I seek to remedy it.
    Has anyone looked into or devised an easy way to change the behavior of the power window lock-out? I used it today, which reminded me:
    I want the lock-out switch to prevent the switches in ALL OTHER DOORS from functioning, without preventing MY DOOR from controlling them.
    Anyone got an idea?
    ~ dan ~
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    I thought that was how it worked? When my lockout is activated the other doors window controls are deactivated.
    How does yours work?
  3. fruzzetti
    377
    If I lock out my windows, two things happen:
    (1) The passengers lose control over their windows (the desired effect);
    (2) I also lose control over the passengers' windows, but of course not my own (not how I want it).
    ~ dan ~
  4. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    This is interesting.
    I don't have my Prius with me today at work.
    I just went out to try this in my BMW, the lockout only applies to the
    rear passengers' window controls. I guess some automakers designed it differently.
    I must say that I think BMW's makes sense. Front passenger should be
    an adult, and there is no reason is lock out his/her window control.
  5. Tideland Prius
    16,072
    Unfortunately, that's how ALL Toyotas work :(. Other manufacturers have it they way you've described it which makes a whole lot more sense.
  6. nwprius
    nwprius Member
    227
    35
    Lacey, Washington
    Just unlock them briefly when you want control and then relock them immediately afterward.
  7. fruzzetti
    377
    Too many button presses.
    I think the fix for this would be very complicated, which irritates me. I don't see a cheaper way than running a dupilcate, unswitched circuit from the driver's control panel to each other door. And I don't see an easier way than changing the nature of that switch so it controls relays that switch the other doors' controls out of the circuits for each of their doors, which is going to be a costly and hassling endeavor.
    ~ dan ~
  8. Pingman73
    Pingman73 New Member
  9. fruzzetti
    377
