here's a stupid question about magnets....
Discussion in 'Prime Main Forum (2017-2022)' started by snakeshoes, Dec 26, 2019.
  1. snakeshoes
    snakeshoes Junior Member
    34
    25
    Boston, MA
    OK, dumb question time. Every knows those "I love my...." magnets and different color ribbon magnets people put on cars. Well, given that the rear bumper of the Prime is plastic and the hatch is carbon fiber, nothing's magnetic back there. So I'm wondering how to go about putting such things (yes, my wife wants to put on the "I love my pug" magnet a relative gave us for Christmas) on my car without too much risk of damaging the paint. Any thoughts?
    The best I've come up with thus far is that the dealership put one of those annoying stickers on the back proclaiming the name of the dealership that's almost the same size so maybe I can find a decent semi-permanent adhesive to stick it to that - covering the annoying decal with my own but being able to remove it if I wanted without actually pulling at the paint. I just need something that sticks to the decale a little less strongly than the decale is stuck to the paint or to hear if there's already another solution out there.
  2. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    What’s that sticky stuff they use to attach credit cards to the mailing letters? Looks like snot but holds well and when you come to your senses you can just roll it off with your fingers.
  3. snakeshoes
    34
    25
    Boston, MA
    Yeah, something like that would work. Just need to find out what it is and how to buy it. Or, I could just tell my bank I lost my ATM card 17 or 18 times.... ;)
  4. VFerdman
    VFerdman Senior Member
    1,194
    1,218
    Western Massachusetts
    Regular old double sided tape will not harm your paint. When you want to remove it, use fishing line to cut through the tape and then goo gone to remove what’s left on the paint. Been there done that.
  5. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    That's "rubber cement" which is a paper-to-paper adhesive that has been around for many decades. It's made from latex and, I believe, acetone. You can buy it at craft stores, art supply stores, and office supply stores.
    I've never heard of it being used in an exterior/weather-exposed location, so I'm not sure how it would respond to road salt, car washes, and to summer/winter temperature extremes.
    Do not confuse "rubber cement" this with "contact cement" which is used for permanent bonding of things like laminate counter-tops.
    You might consider using automotive double-sided tape which is used by auto body shops for attaching exterior molding, trim, insignia, etc.:
  6. Leadfoot J. McCoalroller
    8,150
    7,654
    Pennsylvania
    2018 Prius c
    Use some trim glue. It's made to be safe on auto paint and it'll come off with ordinary solvents, heat & monofilament. It doesn't matter that you're using it to attach a magnet. 3M #3601.
  7. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    'Frig magnets on a Prius?! :eek:
  8. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
  9. snakeshoes
    34
    25
    Boston, MA
    Thanks everyone for the suggestions.
    Definitely! I've worked with contact cement before and definitely wouldn't want to use that for this sort of thing. But, this ^ is an important warning, just like the "always make sure of which color of Loctite is which and which you're using before you use it". Right up there with the measure twice...
    Yeah, I know. But my wife really wants the "I {hear} my pug" on there and a magnet is better than a sticker. Of course, now I've got to turn that magnet into a sticker thanks to the non-magnetic back end of the Prius.
    Yep, I'm familiar with Command Strips. They just seemed a bit too bulky for the use on the exterior of a car where the name of the game is keeping air streams from getting into gaps. Think I'm going to experiment with the double-sided tape options first and rubber cement as a second option.
    Thanks again all.
    Happy Holidays!
  10. Gayguy
    Gayguy New Member
    Boston (North Shore)
    2020 Prius Prime
    I had a similar problem, in my case i simply adhered the decal to the small window exterior facing the rear. My logic is anything can be scraped/cleaned off the glass. BTW, when i had the car windows tinted i did not have that one done fearing that sticking things my hurt the tint film. I attached a pic.
      File size:
      89 KB
  11. DavidA
    2,348
    1,823
    Chicago western burbs
    How about placing the message sign inside one of the back windows facing outwards? You wouldn't need to worry about paint, or it falling off while driving.
  12. schja01
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Avoid sticking it over the window defroster tracings.
  13. DavidA
    2,348
    1,823
    Yes, that too, I should have included that above.
  14. snakeshoes
    34
    25
    Boston, MA
    Yeah, definitely don't want to cover one of those. I went the 'double-sided tape over the dealer's logo sticker' route and it seems to be working well. It will also be the only sticker on the exterior of my car.
