Here's why Toyota Super Long Life Coolant is not so long lived
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Georgina Rudkus, Sep 4, 2022.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,353
    2,347
    Taylors, SC
    Keep it too long and gaskets and maybe including the head gasket might deteriorate.
    Toyota water pump gaskets, like head gaskets might succumb to deteriorated coolant.
    Doug McC likes this.
  2. johnHRP
    johnHRP Active Member
    579
    173
    KA, DE
    Excel
    Yes it is true that over extended interval of coolant can cause corrosion and becomes acidic. However, prius cooling system failure often caused by overheating from headgasket failure and cracked the nylon impeller coating.
  3. ChapmanF
    17,355
    Proving causality is harder than many armchair experts appreciate.
    There have been some threads presenting evidence that the causal arrow could point from coolant deterioration to head gasket failure.
    Doug McC, mikey_t and Georgina Rudkus like this.
  4. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
    No big deal. Changing coolant every 5 years or 50k miles is easy and inexpensive. My dad used to do it every 2 years in his old vehicles with the original green Prestone.
  5. Doug McC
    Doug McC Senior Member
    1,044
    396
    Midwest
    2022 Prius
    A wise man (from that evidence). A ounce of prevention is worth a pound of cure. I would say you were raised around some smart people.
    Georgina Rudkus likes this.
