Hesistation/Pulling at 14 to 16 hundred RPM
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by johnnychimpo, Jan 23, 2021.
  1. johnnychimpo
    johnnychimpo Active Member
    512
    111
    Monterey
    I got the head gasket replaced on my prius after had an issue with a fuel injector stuck open threw me for a loop
    but is resolved now.
    I have replaced head gasket
    oil
    coolant
    fuel injectors
    ignition coils
    spark plugs
    seems to run fine but around 1400 to 1600 depending on the load, it kinda struggles feels sluggish sort of a pulling and letting go sensation.
    Any thought's??? there are not error codes or misfires.
    I checked the head and cylinders all seem normal I dont think it is a bent rod
    anyone else deal with something like this before??
  2. Peter123
    Peter123 Active Member
    131
    128
    Have you cleaned the throttle body?
  3. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    Have you cleaned the EGR circuit?
    moto g power ?
  4. johnnychimpo
    512
    111
    Monterey
    Yes both have been cleaned.
  5. rjparker
    rjparker Tu Humilde Sirviente
    9,597
    5,893
    Texas Hill Country
    I was going to offer free advice on one of the many threads you are posting on and often in the middle of other's problems, but you have made it clear that free advice is only welcome from experts and then only a subset that agree with your current thinking. For anybody else, I would suggest checking all connections for full seating.
    #5 rjparker, Jan 24, 2021
  6. johnnychimpo
    512
    111
    Monterey
    I didn't mean it like that I was looking for definitive answer.
    #6 johnnychimpo, Jan 24, 2021
  7. johnnychimpo
    512
    111
    Monterey
    Sorry I did not mean to offend you I hope folks did not take it in a bad way sorry about that.
  8. dbstoo
    dbstoo Senior Member
    1,380
    745
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I thought about this post for a bit, but could not imagine a circumstance in which I would be looking at the engine RPM as opposed to the power splitter, MG1 or MG2.
  9. johnnychimpo
    512
    111
    Monterey
    Well worst case scenario is taking the trimming chain cover off and confirming the trimming marks.
    Now if they are correct as I think they are, can it be the cam position sensor being bad?
  10. Dilbone
    Dilbone Member
    76
    58
    Northwest Ohio
    I have had a similar thing happen with my prius, but it has happened both pre and post HG replacement. I have no idea what rpm it's happening but it feels like a dead zone falling flat then it recovers. It only does it occasionally, but it feels strange when it happens.
    SM-G981V ?
    SFO likes this.
  11. PTS
    PTS Member
    78
    35
    Austin, Texas
    2013 Prius v wagon
    Did you figure out the problem?
  12. johnnychimpo
    512
    111
    Monterey
    You have same issue? Answer is no.
    New head gasket new plugs new injectors just waiting on coil packs hope that fixis it.
