Hesitation in acceleration
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tariq87, Aug 31, 2016.
  1. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Hi..i have a Toyota prius 2010..
    There is an issue with it recently..
    When i start the car after rest for 2 or one hour ..it's starts mormally but the gas motor keeps running with low sound and won't to turn off..
    When start my spin i kick the gas puddle the car won't response as normal..because the gas motor statrs after 3 seconds with low power and loud sound..
    and if i start the car after full night rest the electric motor starts then the gas motor starts normally , but the gas won`t stop it`s keeps running with low sound like it`s goinig to shut off and just keeps running with little power from it and with loud sound if i push the puddle
    please i need help
    #1 Tariq87, Aug 31, 2016
  2. Mendel Leisk
    38,726
    How many miles on the odometer?
    1. Check oil level.
    2. Check muffler condition.
    3. Test 12 volt battery health.
    4. Check hybrid battery ventilation fan is clean.
    Might also be Exhaust Gas Recirculation circuit clogging? This goes all the way from the exhaust manifold to the intake manifold. The main components are along the right side of the engine.
    #2 Mendel Leisk, Aug 31, 2016
    Tariq87 likes this.
  3. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Around 70000 mile
    And i change the oil 3 days ago
    I will check rest of it and i will back to you..thanks alot..
  4. JC91006
    16,482
    8,400
    If this all started after the oil change.......then that's where you need to investigate. Is there too much oil?
  5. Tariq87
    Tariq87 Member
    87
    28
    jordan
    No there is no much oil..i changed the oil filter then i added 4.5 liter which is normal..
  6. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    How long have you had this car? How many miles have you put on it?
  7. Tariq87
    Tariq87 Member
    87
    28
    jordan
    I bought it in 30th of sep 2014
    And its now with 70000 mile
  8. Mendel Leisk
    38,726
    It's a little over, spec is 4.2 liter. But not bad.
  9. liskipper
    liskipper Member
    373
    79
    Long Island, NY
    Toyota has issued a free extended warranty on the EGR valve. A defective valve can cause these symptoms.
  10. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    sounds like hybrid battery issue... Do you have pets in your car? check your hybrid fan and see if its causing an overheat or some sort... any check engine light? hows your battery charging? is it full bars or 2 bars? when have you noticed this started happening? any major damage? did you bought it new or used?
  11. Tariq87
    Tariq87 Member
    87
    28
    jordan
    Hi NutzAboutBolts..
    No i don't have pets..but i will check the fan (already downloaded your video from youtube for cleaning hybrid fan)
    The battery charging to full mormally..and there is no any damage or accident..i bought it used with 39375 miles done with it..
  12. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
