Hesitation in acceleration
Discussion in 'Prius c Technical Discussion' started by AbdelRahim, Dec 26, 2023.
  1. AbdelRahim
    AbdelRahim Junior Member
    22
    Jordan
    2014 Prius c
    Recently I started to notice a small hesitation during accelration, epically when shifting from full elect to hybrid drive (engine + elect) or when going from the first half of the Eco bar to the second bar
    I tried to drive using normal and Eco mode same things happens,
    Checked my Car using OBD also there is no code
    Today the hesitation was noticeable like the car is losing power to move, it was during a traffic jam, and I was driving below the in the first half of the Eco bar, and after the battery left with 2 bar this happened when the car started the engine to charge the battery
    Car odo meter is 115k mile
    Changed the spark plug last year with oem ones
    Oil changed before 3 months
    49,488
    sounds like a fuel/air problem. i would check the battery health with dr. prius, then move on to the air filter, throttle body and etc.
    AbdelRahim likes this.
  3. AbdelRahim
    22
    Jordan
    2014 Prius c
    Battery health is good, Air filter changed last year, how to check. The throttle body,
    By the way never did a fuel system cleaning before which includes the injectors, throttle body and etc
    49,488
    you can just pull the air filter, tap it out, and make sure you can see light through it.
  5. AbdelRahim
    22
    Jordan
    2014 Prius c
    I already used last Thursday compress air to clean it, and it was soooo dusty
  6. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    Battery cooling fan? Have you checked/cleaned it?
    You're certain the plugs weren't counterfeit? Fake ones usually work great, for a little while.
  7. AbdelRahim
    22
    Jordan
    2014 Prius c
    got them from the service center (official one for Toyota in country) battery cooling fan to be honest no i haven't checked, during this summer i have noticed that there's a hovering sound from the engine when i am climbing a long steep road, and when i remove my feet from the pedal the sound like the engine is calming down
  8. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    The sound you describe is pretty normal behavior.
    The battery cooling fan is under the left rear seat. Look at the intake in the plastic panel down there. The panel comes out pretty easily, and you can clean the intake to the battery cooler fan right there.
    There are youtube videos that show how to do the whole thing very well with a vacuum cleaner.
