Hey kids! New acquisition.
Discussion in 'Gen 3 Prius Main Forum' started by Ianmeister, Sep 16, 2020.
  1. Ianmeister
    Ianmeister Active Member
    304
    311
    Meridian Idaho
    So this morning my wife (god bless the woman) came across a gen3 in Facebook marketplace for a paltry $1000. Seller seemed to think the cylinder was cracked. I went to check it. It seems a local mechanic here in Boise said there’s a little overheating so it’s probably a cracked block. looking it over it had sat for many months, but after charging the 12v battery all day it fired up. Ran really rough at first but smoothed out perfect after 2-3 minutes. It reminds me of a Jeep Liberty I had a few years ago. Mechanic said the engine was blown, turns out it needed new spark plugs and that’s it. Anyway I’ll do the chemical test on the fluid and see if I’ve got combustion gasses in the coolant. Drove it 30 minutes with no trouble. I’ll hookup torque-pro and see engine temps too. If I’m lucky it just needs TLC. Anyway now I need to figure out the gen 3 quirks!
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Congrats(y).
    Now change your location as it sounds like Fremont is further south these days;).
    More specifics when you got them:).
    Read up on the Gen3 maintenance of the egr circuit. We did that job in your driveway, so you have experienced it if nothing else (y).
    Mendel Leisk, Ianmeister and Grit like this.
  3. Ianmeister
    304
    311
    Meridian Idaho
    Looks like it’s a package II.
    Raytheeagle likes this.
  4. Ianmeister
    304
    311
    Meridian Idaho
  5. bisco
    49,380
    sharp looking car, how many miles on her?
    Data Daedalus likes this.
  6. Ianmeister
    304
    311
    Meridian Idaho
  7. Ianmeister
    304
    311
    Meridian Idaho
    So I checked the reservoir today. Yesterday before driving it it was about half full. Now it’s almost empty from an 8 mile drive. Time for a head gasket.
  8. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Didn't want to rain on your parade but I thought so. New plugs just masked it for a short time.
    Now to decide in what direction to proceed....
    GOOD LUCK!
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    What reservoir.....coolant ?
    If there really is that much loss through a head gasket leak, there should be ample evidence of white foam in the oil too.
    Coolant can leak out in other places.
    Sounds like you might be making a mistake similar to the other two quoted "mechanics".
  10. Ianmeister
    304
    311
    Meridian Idaho
    Yes engine coolant. Isn’t it possible that the gasket is blown between the water passage and the cylinder?
  11. sam spade 2
    7,035
    2,788
    2017 Prius c
    Yes, of course.
    But that will make at least one cylinder misfire almost all the time.
    And it will put some of the lost coolant into the crankcase as it leaks by the rings.
    And it will probably also cause a pretty steady stream of white "smoke" out the tailpipe.
    Point IS: Do not ASSUME a head gasket and pay a lot of $$$ for a new one without a definitive test.
  12. Mendel Leisk
    38,649
    Leak-down test is a good next step.
  13. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Given the coolant reservoir is empty, my bet is it fails ;).
    The question is will it be head gasket replacement or gen4 engine swap:).
    Get your popcorn ready(y).
    SFO and Mendel Leisk like this.
  14. royrose
    royrose Senior Member
    1,389
    949
    Foot of Pikes Peak
    Or you could part it out and make a good profit on your $1,000 investment.
    Tyfly likes this.
  15. fotomoto
    5,602
    3,778
    So. Texas
    TLDR: Hard no on this option.
    Crazy amount of competition from every salvage dealer in the country who not only have more resources of a nationwide network but can ship cheaper from their commercial accounts. Can the OP ship a Prius hood across the USA for $200 total? Ebay vendors will.
    Parting out an entire car is a lot of work. Buyers want instant communication. Buyers want good pictures. Buyers want immediate shipping. Buyers want free shipping. Buyers want parts from low miles vehicles (OP has 227k).
    Parting out works best for vehicles whose OEM parts are no longer available. Simply put: supply and demand.
    Finally, just check out a rare part-out threads in the for sale forum and see how those turn out. Here's one: For Sale - Parting out my Gen 3 2010 Prius (Zip 49274) | PriusChat
  16. Ianmeister
    304
    311
    Meridian Idaho
    Ok. I’m still on the fence but I’m still studying it. What we know
    1 I’m getting a misfire code on cylinder 2
    2 the engine shakes like a belly dancer for 10 seconds after startup then runs smooth and quiet WITHOUT white smoke
    3 the HV system seems to run flawlessly.
    4 I’m not EXACTLY sure about fluid consumption. I need to make sure I’m looking at the same mark and really quantifying what’s happening. THE ENGINE RUNS AT 190F as per torque pro F404BA89-CAB5-4B71-96A7-7004692A9228.jpeg
    5 here’s a picture of the dipstick. Before and after wipe. I’ve seen water in oil before and this doesn’t really look like it but what do you think? image.jpg
    6 my brain is telling me to pull the head check that all cylinders have the same depth (to make sure there’s no bent rods) And send out the head for a valve job, clean and replace everything that’s in there (egr, water pump, belt, PCV) while I’m at it and call it done...
    7 unless!!! The engine or head is bad, then look into a gen 4 swap.
    this may be an epic tale, but we’ll see.
  17. Ianmeister
    304
    311
    Meridian Idaho
    Just went for a 45 minute drive. Still shakes on startup. No loss of fluid. Dipstick looks the same.
  18. ttou68
    ttou68 Active Member
    345
    203
    I have replaced head gasket in a 2010 with 208k recent months back, and dip stick look just like yours.. hard to tell at glance, but I'm guessing you're having a leaky head gasket...
    So, I would suggest to drain the motor oil and see what comes out...
    #18 ttou68, Sep 19, 2020
  19. Mendel Leisk
    38,649
    Some stratification evident?
  20. ASRDogman
    ASRDogman Senior Member
    6,060
    3,253
