Hey, new guy here. Need some help about headlights.
Discussion in 'Gen 2 Prius Main Forum' started by Litt-G, Oct 11, 2020.
  1. Litt-G
    Litt-G New Member
    Harrisonville Missouri
    Hey all. New to prius. Newer to prius community. I recently was hit by a deer. Had to replace passenger fender, headlight and bumper cover. I got replacement headlight bezels on line. The kicker is the headlights I have were halogen and the new ones are "computer controlled HID type". Is there an adapter/harness/pigtail to convert my halogens to the factory hid bezel? I can't seem to find what I'm lookin for in my search engines
  2. PriusCamper
    PriusCamper Senior Member
    13,364
    5,399
    Pacific Northwest, USA
    While I did have an experience once where I slowly passed a deer and it got confused and ran into my right rear corner panel trying too quickly to cross the road after me, I don't believe that you had front end damage because the deer hit you. Obviously you're the one who hit the deer, not the other way around. So let's clear than up first...
    #2 PriusCamper, Oct 11, 2020
  3. orenji
    orenji Senior Member
    5,887
    3,488
    Are these JDM lights? If so your gonna need to locate a set in Japan.
  4. Litt-G
    Litt-G New Member
    I do not know what JDM is. The bezels i obtained came off a prius that was in a rear end accident in the United States. They are the computer controlled HIDs that were a factory option. I did not know at the time I purchased them. The bezels that came with my car are halogen.
  5. Litt-G
    Litt-G New Member
    Actually it truly hit me. Lol I understand from your perspective that you would assume so. But. The deer hit my passenger side front quarter panel at the wheel. The head hit my windshield and as it spun from the impact its nice person-end hit my headlight and front bumper. The gravel road i was on has a treeline not ten feet from the road and that is where the biggest doe i have ever seen trodded out and hit my car. I am yet to see how your intended correction of the incident has any relevance to my initial question. So if you have no answer... kindly I ask for you to carry on to some other thread and stop wasting my time. Thank you and please Stay Blessed.
    Danny13pruisc3 likes this.
  6. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    To me, a bezel is like a retaining ring, something that holds something down. Did you replace the entire housing that surrounds the bulb, all the reflective bits and the mounting that holds the bulb, or just something that holds the existing headlight in position?
    OK, the various Priuses have had three(?) different types of headlights. Incandescent, HID, LED. With each of them the bulb is a different size and shape, and has an exact spot where it needs to be mounted in relation to the headlight housing. If you throw the wrong bulb into a housing you will still get light coming out of it, but the beam will be all messed up and you'll be driving around thinking "Man, these headlights really S**&!"
    The HID bulbs are nice and strong, but they are part of a package where there is a sensor that checks the pitch of the car - how much the nose angles up or down - and physically adjusts the height of the beam so you don't blind people by shining it in their cabin when they go by. Toyota had to do this in order to be allowed to sell a car with HID bulbs.
    The simplest thing for you to do would be to buy housings that are the same as what you had, and just put it back like it was. You can sell on the HID housings, just be clear about exactly what they are. Trying to switch your car over to HID is humanly possible, but I would rate the difficulty as too high to be worth the fuss. It isn't just a matter of mating together two different wiring harnesses. You'd have to buy two HID bulbs (pricey), a ballast (pricey), a pitch sensor (pricey) the leveling motors (pricey) and find a way to mount the pitch sensor on a car that wasn't built for it.
    If you tried to run without the sensor you'd get people calling the cops about "some nut shining his high beams in everyone's car" and they would be very grumpy when they caught up with you.
  7. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Wow!! Triple triple triple post!! A little glitchy today?
  8. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Very nice, the third post, which was left intact, has disappeared, lol.
  9. PriusCamper
    13,364
    5,399
    I've found this happens to me whenever my internet connection is bad...
