Tags:
  1. sangar
    sangar New Member
    luton
    hi can some one help me if got toyota prius 2004 1.5 left front window do up but dosnt go down,,, i check moter ok swtich fine,, can somee one hlep me thnx
    49,728
    hey! welcome. maybe something caught, pull the door panel off and look around.
  3. sangar
    sangar New Member
    luton
    i look all day i cant find any thing
    49,728
    when you press the down switch, is there any movement or humming of the motor?
  5. sangar
    sangar New Member
    luton
    not put i have power brob i did test manul ,,also when i put my test i press red light flashing swtich ok motor work by manul up dowwwwwn
  6. bisco
    49,728
    can you re word that please?:)
    hotelprisoner likes this.
  7. sangar
    sangar New Member
    luton
  8. bisco
    49,728
    okay. can you do a continuity test on each wire?
  9. sangar
    sangar New Member
    luton
    can i get wiree diagrm forrrrrrr windows thanks
  10. sangar
    sangar New Member
    luton
    yes tomorrow i take pic i send uk my frd thanks so much
  11. sangar
    sangar New Member
    luton
  12. sangar
    sangar New Member
    luton
    Hi
  13. bisco
    49,728
    you can get the wiring diagram at toyotatechinfo.com or something like that.
  14. hotelprisoner
    hotelprisoner Member
    101
    85
    Ontario, Canada
    Technology
    Had same problem. Followed wires back to drivers door where main box is and I found a broken connector wire on the back of the plastic connector. Soldered it back together, problem solved.
