Hi everyone just bought 09 prius no stars n o crank and won't shift into reverse or drive. Battery'
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by James Eagan, Mar 2, 2021.
  1. James Eagan
    James Eagan New Member
    Sacramento,Calif
    09 prius no crank no start. No shift. Battery's. Good. And checked break light switch. Tests good....need help....thanks....
    James.....
  2. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Welcome to PriusChat!!
    Do you happen to have any OBD2 codes (DTCs) that you could share with us?
    PriusCamper likes this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,967
    4,709
    Texas Hill Country
    How do you know the 12v battery is good? Measurements? Does the keyfob do anything to the car? What exactly happens?
    Without much more detail all the internet can do for you is suggest towing it it to a dealer.
  4. PriusCamper
    PriusCamper Senior Member
    11,095
    4,515
    Pacific Northwest, USA
  5. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Did you get a smog cert with the car so you could legally transfer the title?
  6. Wali
    Wali Junior Member
    renton
    Hello, I was wondering if you solved the issue.
    SFO and PriusCamper like this.
  7. Mendel Leisk
    38,710
    He may not be back, that was his one and only post, nothing since.
  8. bisco
    49,448
    sorry
  9. PriusCamper
    11,095
    4,515
    You could of prevented this from happening @bisco
  10. bisco
    49,448
    believe me, i tried. but it's like talking to a wall
  11. Wali
    Wali Junior Member
    renton
    Hello all, I had the same exact issue on my 2009 Prius. Mine was parked over 2 months without starting. Followed sum of your advices on other trades I end up removing the HV battery, run same test found, cods POA7F H, battry deterioration and cod P0AFA Hybrid. battery voltage low, three very low 6.4 volt cells the others were around 7 so I charged the battery and bring all the cells to 8.5 v, and the small battery12.6v. connect everything back together, but then I found out no voltage at the end of the two wires that coming out of the HV battery so I removed the orange fuse again and run some further tests, I found some burned marks by the battery control module I tried to disconnect the wiring on the module you wouldn't believe what happened the module start smoking, finally Removed the module, im still not sure wate cause the module to shorOut like that.
    Will jump starting with crose wire couldcause somethinglike that?
    Would any one by chance have daiagram of the rely by the module or resestinse Test presitures?
    So I will need new battrey control module and wiring conecter assy from hv battery To module. And a posible relay.
  12. PriusCamper
    11,095
    4,515
    Got pictures of the burned part?
  13. Wali
    Wali Junior Member
    renton
    Uploading photos.
  14. PriusCamper
    11,095
    4,515
    Yep, most common failure of a battery pack in areas with lots of wet weather. Fortunately a wire frame no. 2 is only $50-$90 depending on what stealership you go to and a used ECU on ebay is less than $100 and you'll be good to go... I'm south of you in Olympia if you need any help. Also @fach is even closer to you and if you can source a replacement 22-pin socket he might have time to solder it to your existing ECU board so you don't have to replace it. We're planning to gather up these fried ECUs and plug solder new sockets into them, but haven't sourced the socket yet.
    SFO and fach like this.
  15. Wali
    Wali Junior Member
    renton
    Thanks gentlemen, I really appreciate the offer.
    I still need wiring diagram for the really. And test presiture. Hopefully I will find It on line.
  16. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    I've never used the following link, but it should contain *everything* you need : Service Manuals - Google Drive
    It would be great if you could extract the manuals from Gdrive and back them up on http://mega.nz/, then post the link here afterwards.
  17. Wali
    Wali Junior Member
    renton
    Thanks alot. Very helpful information..
    So do I need to reprogram the used battery ecu?
    Haven't order one yet. Saw afew in eby, they ware suggesting that.
  18. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    No.
    Not sure why a seller would suggest that either.
