Hi from NZ, looking at buying a Prius C/Aqua
Discussion in 'Prius c Main Forum' started by Evo5RS, Dec 14, 2022.
  1. Evo5RS
    Evo5RS New Member
    Auckland, New Zealand
    2012 Aqua
    Hello,
    My name is Zee and I am from New Zealand.
    I am looking to replace my wifes car which was written off. She wants an Prius C/Aqua.
    Am i better off getting a
    2013 50kms or
    2016 90kms?
    I have tried to read numerous forums but with no luck to figure out whether age or mileage is better to purchase
    Anything else I should look out for when purchasing anPrius C/Aqua?
    Thanks
  2. Tideland Prius
    16,445
    I'm leaning towards the 2016 with 90,000km just because 50,000km on a 2013 seems a bit low. Then again, I'm using North America as a reference as I don't know the driving style/conditions in NZ and whether 50,000km is normal and 90,000km is excessive given their years.
    The 2016 would also have gone through the first mid-life update so you'd imagine there'll be some tweaks that Toyota need with that year vs the 2013.
  3. Evo5RS
    Evo5RS New Member
    2012 Aqua
    Thank you much for the reply Tideland Prius. Mostly where I drive it is flat and we do about 20000kms a years. All Aquas are imported from Japan and i think couple Prius Cs are NZ new (I think).
    Would you recommend a 2017 one over the 2016? Happy to stretch the budget for a better longer lasting car.
  4. Tideland Prius
    16,445
    Ohh so both were imported from Japan? Wow, that does seem high for a 2016 then! (at least from what I understand of the Japanese market and their driving habits). But either way, I'd rather a hybrid be used rather than sit parked to be honest.
    In North America, 2017 was our second refresh that added body cladding and I believe upgraded TSS-C.
  5. Evo5RS
    Evo5RS New Member
    2012 Aqua
    Thanks again for the reply! So better off getting a hybrid that is actually used and not parked up?
    It will be my wifes car so most likely short trips say 10kms and back maybe 5 times a week. Would this be ok or better off just getting a petrol car?
  6. Kerrynzl
    Kerrynzl Member
    New Zealand
    2016 Aqua
    Hi Mate! [from Tauranga NZ]
    Get the newest model you can afford. I have a 2nd Gen Aqua [or Facelift Aqua]
    These were face-lifted in 2014 then again in 2017
    Mileage is almost irrelevant for these cars if you're planning long term ownership, as these things can reliably travel 500k-600k [kms]
    So if you buy a 100k Aqua and travel 20k year it would 20 years to get to 500k [by then you'll be tired of it]
    I've driven mine all over NZ, around the south island etc etc
    One caveat though [seeing that you are in Auckland] the Aqua is the Number 1 "Ram-Raid" car of choice. The Aqua L spec does not have a transponder / chip key, and the thieves already know about this.
    These cars are very difficult to fit an immobilizer , so on mine I fitted a flashing LED next to the ignition barrel so thieves think it is immobilized.
    You won't regret buying one, just leave it alone and drive the wheels off it.
  7. Evo5RS
    Evo5RS New Member
    2012 Aqua
    Heya Kerrynzl! Nice to meet a fellow Kiwi!
    I would love an Aqua for myself but being 196cm the mrs is the lucky one to get one!
    Thats good to hear I will look for a newer one as we are defs planning to keep this long term.
    Would you recommend getting a push start one to keep the theives away? I was planning to get an alarm as wife sometimes parks in town.
  8. rjdriver
    rjdriver Active Member
    409
    170
    Rhode Island
    One thing to be cautious about if buying a high mileage C/Aqua is the condition of the hybrid battery. If possible, see if you can get a look at the battery cooling fan on each vehicle. It's under the rear seat behind the driver (or perhaps it's behind the passenger in a right drive version). There's a small removable panel that allows access. If the fan's air intake is clean you're probably fine, but if it's covered with dust/hair/dirt that would be cause for concern. Excess heat ages the battery prematurely.
    A way to get a definitive answer on the battery condition, if the owner or dealer will allow it, is to test it with the Dr. Prius app, or it might be called Dr. Hybrid now. The app for your phone is free, but they offer an extra cost software upgrade that can be used to run a test that shows the remaining life of the hybrid battery. When I bought mine 5 years ago that upgrade was $8.00. Might be a little higher now, but I think it's worth the money to give you peace of mind about how soon you might need to spend a few thousand on a new battery. You'll also need an OBD2 module to plug into the car's diagnostic port. They can be had for about $10-$15. The test takes 15 minutes to run.
    Tideland Prius and Evo5RS like this.
  9. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    Fantastic cars.
    When there is a big expensive traction battery involved, I always suggest getting the youngest one you can, and to **** with the odometer.
    Evo5RS likes this.
  10. Kerrynzl
    Kerrynzl Member
    New Zealand
    2016 Aqua
    I chose a basic Aqua L because being a car guy, I can't stop tinkering with them. It wasn't until after I purchased it that all the Ram-Raids started happening in Auckland.
    I am 1.88 tall and certainly don't have issues driving them. I drove from Tauranga direct through to lake Tekapo in one go and it only took 34.88 litres [the only stop was a "splash and dash" at Wellington and the 2am ferry]
    So I managed to travel 1080 kms on 35 litres of fuel in real world driving [this is 85mpg imp or 70mpg US]
    So technically I could have done this on 1 tank but that is only 35 litres
    My biggest complaint with open road driving is "road noise" from the Toyo high mileage tyres and the L spec Aqua lacks the sound insulation under the carpet.
    So an S spec or G spec would be better.
    Get a factory immobilizer transponder Key Aqua if you can [it will save you some grief]
    You can immobilize the Aqua so it doesn't start by putting a cut-off switch in-series to the ground wire of the primary circuit on the IGCT relay in the engine bay[ the normal fuel pump disconnect switches don't work for about 3 km range]
    But the IGCT switched off will throw a "check engine light" if you try to start it with the car being immobilized. But after a few starts the "check engine light" will eventually go out.
    If you remember to switch on the immobilizer switch BEFORE you start it, it won't throw a code.
    But a check engine light is better than getting your car stolen.
    @Leadfoot J. McCoalroller @Evo5RS There is an outfit in Auckland that rebuilds Aqua batteries for NZD $980 [USD $600] so I wouldn't sweat it too much.
    It would cost more to swap in a 2nd hand engine as a DIY project on any Japanese car.
    To give you guys an idea of what sort of "car guy" I am. I have a garage full of desirable cars [and a few more in storage]
    Unfortunately these cars OWN ME!
    The little Aqua is my car of choice for driving anywhere [open road or around town] These cars are hassle free ,easy to park , and you generally don't have to worry about them.
    So buy the best one you can, and don't tinker with it. And keep it for a few years
    The only thing worse than paying too much [where you risk losing a bit] is to pay too little [where you risk losing the lot]
    #10 Kerrynzl, Dec 15, 2022
  11. Evo5RS
    Evo5RS New Member
    2012 Aqua
    Awesome guys cheers for the tips to look out for, I think my friend has Dr Prius so will check out how to use it.
    Will try and get the newest year I can afford looking to spend around 12k after the clean car rebate ($1500 off). I noticed they have gone up in price since i last looked.
    I can't wait to see the fuel economy in person!! Wish i could fit one!!
    @Kerrynzl who is this outfit in Auckland that rebuilds Aqua batteries?
  12. Kerrynzl
    Kerrynzl Member
    New Zealand
    2016 Aqua
    Try this [for a $980 re-manufactured battery]
    https://hybridcore.co.nz/product/toyota-prius-c-aqua-re-manufactured-battery/
    They are located in Kelston [Westie territory]
    18 months ago I paid $9k + $450 on road costs for my 2016 Aqua L with 79,000kms on the clock from a wholesaler in Greenlane. [they should be cheaper now being older]
    Mine is white, colored cars will fetch a premium.
    I don't know if I qualified for the clean car rebate [I never looked into this]
    This wasn't a special deal, I responded to an Advertisement and negotiated a quick clean easy deal .
    The only thing I checked was the condition of the car, I went over every seam, and eyeballed it for damage and paint repairs [I have a good color matching eyes]
    To all you USA members $9450 NZD is the same as $6008 USD [todays exchange rate] For a 49,000 mile 2016 Aqua facelift.
    This is including all sale taxes. So I don't know how this compares to USA values
  13. Evo5RS
    Evo5RS New Member
    2012 Aqua
    That is so cheap! Ive been hunting around on trademe and they around the 13 14k mark in saying that the wife wants a black interior and I want to get a push start one to ward off the thieves but didn't think they would cost that much more?
    Im not in rush thankfully have my brothers Honda Fit too use. Maybe some boxing day deals
  14. Kerrynzl
    Kerrynzl Member
    New Zealand
    2016 Aqua
    It wasn't cheap at that time! I actually rolled over and paid more because the car was in tidy honest condition. I could have purchased an Aqua "S" for the same $$$ but it was "doggy around the edges"
    BUT one caveat here: It was between the 2 covid lock downs in Auckland and gas was cheaper back then. So a few dealers were hurting.
    Timing was perfect for me. [I managed to sell my XR6 2 weeks prior for good $$$]
    One thing in your favor now is NZ's compliance rules..........They simply wont allow a P.O.S on our roads now. If you put a fresh import on a hoist and look under, it will be really clean underneath [no underseal etc]
    When I purchased mine the clean car rebate wasn't available [I just checked and mine doesn't qualify because of the cut-off date]
    So if you paid $13,000 minus the $1500 rebate it would be $11,500 which is $2000 more than what I paid [under different circumstances]
    If you keep the car for 3 years [1095 days] you are only paying $1-82 per day extra to start reaping the benefits from day one.
    Consider the following; “The bitterness of poor quality remains long after the sweetness of low price is forgotten” a quote frequently attributed to Benjamin Franklin
    So buy the nicest condition car you can afford.........and keep it / enjoy it for a longer period
  15. Tideland Prius
    16,445
    That's my theory, yes. Hybrids do like to be driven rather than sat for weeks or months at a time. (or in the case of "regular" use, the low mileage one might be all short trips which will also "hurt" the engine more than the hybrid battery).
  16. Evo5RS
    Evo5RS New Member
    2012 Aqua
    You went from a XR6 to an Aqua! How was that??
    Cars seem to have gone up quite a bit since Covid lock downs. Im on the hunt! I was tempted to import one but guess no way to check the battery in Japan.
    How short of a trip is no good? Wife will be doing about 10kms (6.2miles) to work each way 5 times a week?
  17. Kerrynzl
    Kerrynzl Member
    New Zealand
    2016 Aqua
    I still have another Falcon as a tow-hack. So getting rid of the XR6 was a no-brainer for me. [it lived outside]
    You can see the Aqua hiding in the corner of the photo
    Don't bother importing one for yourself, unless you are a car dealer [that does this non-stop all year round]
    If you're lucky it will take 6 months to buy / import and jump through all the hoops to get a nice one [including paint touch ups etc etc]
    This ^^^ might save you $2000 NZD at the most [ dealer margins are getting thinner these days]
    You would be better off financially paying full retail, and taking an after hours job stacking supermarket shelves to pay the price difference.
    A total urban myth these days because of EFI instead of old manual choke carburetors.
    A car driven for 365 days will still need 365 cold starts regardless of whether it travels 10km's or 50km's per day.
    The clever lil' Aqua is programmed to automatically warm up on gasoline [which takes about 1 km] before it will drive on the electric motors.
    This ^^^ is the reason why converting Aquas to plug-in hybrids is very difficult [for a DIYer]
    Even if you run the battery down on short trips, the Aqua will automatically run on gasoline to recharge the battery.
    Understand the life expectancy of these cars are amazing. Not like in the 60's -70's where the engine needed a "ring and bearing" job at 100'000 kms
    Evo5RS likes this.
  18. Evo5RS
    Evo5RS New Member
    2012 Aqua
    Thank you so much for all the help and info Kerrynzl! Im going to go hunting tomorrow and try my luck.
    Will keep everyone updated when I find one!
    Have a good xmas team!
    Kerrynzl likes this.
  19. Kerrynzl
    Kerrynzl Member
    New Zealand
    2016 Aqua
    What part of Auckland are you in?
    Tauranga and Mount Maunganui is a nightmare during this time of the year. So I'm avoiding this Xmas this year by doing a disappearing act.
    Normally I enjoy cruising the "Mount Beach" getting whiplashed eyeballs from all the talent spotting.
  20. Evo5RS
    Evo5RS New Member
    2012 Aqua
    Im in South Auckland, Papatoetoe......near where the shooting today was....
    Bahahaha talent spotting!!
