Hi Rev in Neutral gear
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by smokeGTI, Nov 17, 2008.
  1. smokeGTI
    smokeGTI Member
    61
    27
    Hong Kong China
    Hi all,
    I don't know if this is normal ,
    that the engine kicks in, and rev up when the car is in neutual right
    after down hill. The battery was in full (green), and the engine was fully warmed up.
    And sometimes it happened in nuetral right after climbed up the parking lot, and even in reverse when parking.
    The realtime fuel consumption bar was in full up, and the reading was
    99.9L/100km.
    It always go back to zero after few second or so.
    Any idea ?
    George
  2. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Smoke...,
    This is a technique used to pull the battery out of overcharged condition. The battery is used to pump the engine until its charge is at a lower level. Coming down the hill the regeneration charged up the battery too much. If you had continued on the electricty would have quickly been used pushing the car. But, if you get caught at a light, the battery will turn over the engine to run down the state of charge to an acceptable level.
    I am not sure what is going on in the parking lot.
  3. Bob64
    1,540
    92
    Virginia
    in neutral?
    don't you mean DRIVE? or PARK?
    Neutral is a whole different ball game, which prevents the engine from starting OR stopping.
  4. smokeGTI
    smokeGTI Member
    61
    27
    Hong Kong China
    Yes, in neutral!
    It did that just now when I came back from work.
    The battery was in half full. I've tried P and D, no different,
    it's back to zero after few seconds.
    I found that it always happen when it came to stop after up hill,
    50/50 chance.
    Weird enough ??
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Why are you using N?
    As the first responder said, this is normal and is used to reduce the State Of Charge (SOC) of the traction battery. It sounds like the engine is racing, but all that is really happening is MG1 is spinning the engine as a big pump. The friction of pumping air through the engine uses up excess electricity. Usually you see this sort of behavior at the bottom of a big hill. The engine will race, stop, and race again. The cycle will continue until the SOC is back at an acceptable level.
    Tom
  6. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I know what he's talking about, although it's not a particularly
    high "rev". In early warmup stages the engine is run in that
    ignition-retarded mode with a light electrical load placed on
    it, open loop, and that only works in P or D. Going to N or
    reversing out of somewhere lets go of this and the engine goes
    back to as close as it can get to "normal idle", but the parameters
    for that are all different and the closed-loop control isn't ready
    to kick in yet. So the ECM takes various wild guesses as to
    what it should do with mixture, throttle control, etc and the
    resulting RPM can be quite different from the controlled warmup
    run mode. If your throttle position sensor is very slightly
    off, the RPM can shoot up to around 1400 briefly. All this
    generally settles down once things get warmed up.
    _H*
  7. smokeGTI
    smokeGTI Member
    61
    27
    Hong Kong China
    Sorry for mis-leading~
    It was in "D", but all I wanted to say is that
    it won't go down even in Neutral.
    As for the "SOC",
    Do you think it also applied to up hill and battery in half full ?
  8. qbee42
    18,058
    3,074
    Northern Michigan
    No, the SOC issue is only applicable with a very full battery - all green. If it happens at other times, hobbit probably has it figured out, unless, of course, something is failing in the control loop.
    Tom
  9. smokeGTI
    smokeGTI Member
    61
    27
    Hong Kong China
  10. smokeGTI
    smokeGTI Member
    61
    27
    Hong Kong China
    I should correct this issue as "Engine Shut-off Delay" then.
    Anyone else experience this behaviour ?
    Or it's normal as it was running in S3 mode?
  11. Bob64
    1,540
    92
    Virginia
    Ok, If I'm understanding this right, your issue is "high idling rpm - even in neutral"? correct? Because the engine NEVER turns off while in neutral.
    If so, what rpm is it running in Neutral? How far into your commute does this happen? Are you in stage 4? Whats your coolant temp?
  12. smokeGTI
    smokeGTI Member
    61
    27
    Hong Kong China
    Yes, you are correct!
    I have no idea of what rpm it was running,
    or what coolant temp. it was,
    all I can tell is the "Current" bar was in full.
    Well, maybe it was just not very high rpm,
    but high enough to fill up the bar.
    It's been drove for an half hour before that happen.
    So I assumed it was in either S3 or S4.
  13. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    It sounds normal to me. I think you are misinterperating delayed idle shutdown in S2 or S3 at a stand still for high reving.
  14. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
    Tonight my ICE started racing in "P", after going down a hill then parking. The battery SOC was full green bars. It was revving at about 2500 RPM (per ScanGauge), which scared me, until I powered it off after about 10 seconds. Has anyone had theirs rev this high to discharge the battery? I have experienced the multiple starts/stops wating in traffic, but not this before.
  15. qbee42
    18,058
    3,074
    Northern Michigan
    Completely normal. The engine was not running, but simply being used as a drag to burn off excess charge. If the traction battery SOC gets too high, the control system will work hard to bring it back down. If the car is standing still, there aren't any good options for burning off charge, so the ECU commands the electric motor to spin the engine. Normally it does this in a series of bursts. It spins the engine , stops and checks the charge, spins the engine again, and repeats until the SOC is at an acceptable level.
    Tom
  16. maseace
    191
    Poulsbo, WA
    Thanks, it must be the cold weather allowing the battery to become overcharged more easily. This will be my first winter with the Prius.
