Hi there,my prius v has the ABS warning lights and the scanner showed the C2152,C2152 and C2156 code
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Eric mbaabu, Jul 16, 2020.
  1. Eric mbaabu
    Eric mbaabu New Member
    Mombasa kenya
    2012 Prius Alpha
    : Hi there,my prius v has the ABS warning lights and the scanner showed the C2152,C2152 and C2156 code,we also noticed that the booster pump is not pumping breakfluid to the rear tires,when we tried to do some bleeding,is there a way i can repair the accumalator since we do not have technical support here in mombasa kenya?any other help or advice would be highly aprecated
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,030
    6,202
    Texas Hill Country
    There is a special way to bleed these brakes using the Toyota scanner, Techstream, especially when its not working right. If there is no air in the system you can use the “invalid mode”. While we have a guy or two that apparently don’t like to discuss it, the brake booster assembly on these cars is known to fail. The only real solution is replacement of the parts.
    Tim Jones likes this.
  3. Tim Jones
    Tim Jones Senior Member
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    Your most likely going to need the pump and master cylinder. OUCH..... and it has to be off a v only!
  4. rjparker
    10,030
    6,202
    Texas Hill Country
    In the US versions a 2012 needs:
    47070-12020 pump $913 mcgeorge 696 ebay used 164
    47050-47110 Cylinder Assy $1405 Mcgeorge 1072
    44785-02060 Gasket, Brake Booster $5 mcgeorge $3.60
    00475-1BF03 Brake Fluid $22
    The sequence with Techstream is RR, RL, FL, FR. Techstream guides you the step by step procedure. See the ABS ESP VDC menus for Utilities Air Bleeding.
    An alternative without Techstream which is best used when there is no air in the fluid:
    Invalid Mode:
    1. Press parking brake
    2. Power Button twice
    3. Press brake petal and go into Neutral
    4. Press brake x8 in 5 secs
    5. Press Park
    6. Press brake x8 in 5 secs and release
    7. Press brake petal and go into Neutral
    8. Press brake x8 in 5 secs
    9. Press Park and note Blinking brake light
    10. You are in invalid mode
    Bleed rear brakes by holding pedal down
    Bleed front brakes by pumping brakes
    Power down to exit invalid mode
    Consider using charger on 12v battery to ensure low battery does not disrupt bleeding
    Eric mbaabu and Tim Jones like this.
  5. Tim Jones
    1,753
    564
    SE Texas
    2011 Nissan LEAF
    Parts off a Lexus CT200 also work...
    Eric mbaabu likes this.
  6. Eric mbaabu
    Mombasa kenya
    2012 Prius Alpha
    Well,the interesting part is that the break master cylinder is separated from the booster accumulator, so i don't understand how to go about it, and now you can't hear the pump sound ,it has 121788 miles on it,so how do I know what exactly is wrong,is it the master cylinder or the break accumulator booster?the codes c2153 ,c2156 C2152 all talk about pump motor relay,is it something that can be serviced or repaired? I have noticed that the break pump accumulator had a warning that it should not be replaced,I read somewhere in a repair manual that only a few of these prius that don't require replacement of this component, so what does it mean,I really need help, and please someone please explain more about how the rear breaks fluid is pumped electronically since my real breaks aren't working only the front but with a lot of effort and the stopping distance is dangerously very bad. 20200716_155107.jpeg 20200717_080455.jpeg
  7. rjparker
    10,030
    6,202
    Texas Hill Country
    Normally this system is brake by wire only. The brake pedal combined with other ecus just tell the brake ecu how much pressure to apply via the master cylinder. As a result it is possible to apply traction control braking without any brake pedal application. Or no braking because of regen. Or some braking combined with regen. Prius gets much of its braking from regen so you may be pressing the brake but the car is often just slowing based on electric motor regen resistance.
    How it works is a long story but to give you the general idea, the pump/accumulator builds up pressure which the master cylinder/abs/brake ecu directs individually to each wheel. The pump assy has an accumulator tank that is nitrogen charged pushing a diaphragm pushing the brake fluid. That diaphragm fails and leaks nitrogen into the brake fluid. When that happens the pump runs more often and eventually fails. That nitrogen gas gets into the very complicated master cylinder assy and usually causes it to fail. The only way to completely exercise and flush every passage way is with the Toyota Techstream scanner.
    If your pump is not running and its getting power you could try replacing just it and then do the full flush procedure. Initially Toyota was doing this on recall service for these failures. Then it was determined the master cylinder was often defective as well so now the recommendation is to change both. It is difficult access which means its easier to do it once than twice.
    These systems fail routinely on gen3 cars. It is very important to get the right parts, many sellers don’t know a v wagon is different parts than a regular hatchback. If you have power to the pump and its not running its the critical failure. I would and did change the master cylinder also using used lower mileage parts. If you want to keep the car another 100k miles or more, I would use a new pump assy at least.
    Finally the warning is saying do not try to disassemble the accumulator because it would be a waste of time and could hurt you because of the nitrogen pressure blowing parts at you. It does not mean you can’t replace the pump/accumulator assembly.
    #7 rjparker, Jul 18, 2020
  8. Eric mbaabu
    Mombasa kenya
    2012 Prius Alpha
    Thanks for that important information, so for starters i need to get the techstream software in my laptop so that we can trace what's exactly is wrong or needs replacement, where can you recommend that i can buy the right booster pump and the master cylinder for the 2012 prius v, note that these arebtwo different parts,the master cylinder is on the passenger side while the pressure accumulator is on the passengers side both linked by pipes, how do I go about it,and does it matter if the car is a right hand drive when looking for the right replacement of these two parts?thanks
  9. ChapmanF
    17,974
    That is one of the failure modes that has been seen, and was subject to a recall. It was happening especially often in a run of accumulators where the 'diaphragm' (really a metal bellows) was slightly undersized, and on bumpy terrain it got banged around inside the accumulator canister, and developed cracks, leaking nitrogen gas.
    Another, different, failure mode, also the subject of a recall service campaign, happens in the actuator assembly, which contains many small valves directing brake fluid. If one of those valves fails to seal completely when closed, there can be a leak of brake fluid (not nitrogen gas) back into the fluid reservoir. In that situation also, the pressure in the accumulator does not hold, this time because the fluid isn't staying there, and the pump has to cycle frequently to maintain the pressure.
    The Gen 2 Prius was the one where the braking was most completely "by wire". In every other generation, the pressurized fluid does act partly through the master cylinder in concert with your foot on the pedal; there is a chamber behind the master cylinder piston where pressurized fluid enters, pushing the piston in the same direction your foot does. (When you see the Prius term "brake booster" without the word "pump" attached, it means that chamber, and not the pump.)
    That really only makes a difference in cases where the electronic controls have failed (or detected a problem and recused themselves); in a Gen 1, or Gen 3+, you still have power-assisted hydraulic brakes as long as there is stored accumulator pressure to assist you (20 to 30 strokes or so). Gen 2 really did depend more on the computer seeing your braking as an input and doing the control itself, and for that reason Gen 2 had an extra box of capacitors in back just to supply reserve power to the brake electronics.
  10. Eric mbaabu
    Mombasa kenya
    2012 Prius Alpha
    Wow this information keeps on getting more technical, so how do i tell of my 2012 prius v is a Gen 1 or 2? If you were the one who experienced the hard breaking and ABS and skid control warning lights and the continouse buzzing warning sound and when you check the breaks you notice that no break fluid is getting to the rear tires,what would be your next course of action,I have attached the photo of the scanner.please note that here in mombasa kenya we have no technical support for this model of prius so any technical advice would be of great help.once more thanks everyone 20200716_155106.jpeg
  11. Eric mbaabu
    Mombasa kenya
    2012 Prius Alpha
    Correction, the master cylinder pump is on the driver's side while the actuator booster is on the passenger's side
  12. rjparker
    10,030
    6,202
    Texas Hill Country
    Some of the “chaps” around here are sometimes more confusing than useful. All Prius v and alphas at least through 2017 are gen3. Even the American left hand drives have two parts with “hoses” connecting them. The best way to know exactly which part number you need is to ask a dealer what the part number is based on the unique vin of your car.
    Some of the online dealers like McGeorge will help. Chances are good it will be the same parts as I listed above. There is nothing communicating or networking on the pump/accumulator which you indicate does not run. Verify it gets no power, determine if the cost of the parts makes sense to you and go from there.
    #12 rjparker, Jul 18, 2020
