Hi!
Discussion in 'Gen 2 Prius Main Forum' started by hisshers, Mar 14, 2007.
  1. hisshers
    hisshers New Member
    Hi gang,
    Let me start by saying that I just found this site today and am just now starting the navigation of it and apologize if I am in the wrong place. I drive a Honda Element and my wife drives a Subaru Forester. She and I were out one day and saw this neat little space ship like car and thought it would be fun to test drive since my car gets an average of 20-22 mpg.
    We got into it and it was a completely different world. I must admit that I was really attracted to many of the gadgets and blown AWAY with the mpg!
    My question for you is, can you refer me to a pros/cons list to help me decide. I am 6'5 so space is always an issue but in test driving there seemed no issue. I live about 15 miles from work and run quite a bit in town so is this the car for me?
    Again I am sorry about all this but I am completely floored by this neat little machine and just don't know where to turn. I've checked reading reviews on Epinions and Edmunds and other sites but they are very limited!
    -hh
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    You won't find many people here giving you a lot of minuses, but lots of pluses!
    At 6'5" you should take at least one more test drive, maybe even see if you can borrow or rent one overnight to be sure you're comfortable. I'm only 5'11" and find the Prius fairly uncomfortable on longer drives and have a wedge shaped cushion that I use for added thigh support. Other tall drivers have had complaints but I think a lot depends upon how long your legs are.
    Other than that there are few 'minuses'...it's not a race car and won't win you any drag races, but it's quite adequate for any reasonable driving under any conditions. As you noted it's full of gadgets and that's quite fun. It's very reliable and satisfying to drive.
    If you've got specific questions or concerns please let us know b/c it's easier to pick those off one by one than to elaborate ad nauseum about how much we love the car.
  3. hisshers
    hisshers New Member
    Fairly stated and thanks for your comments! I have heard that the car does not really get the mileage that is listed on the window but even if it isn't the numbers they tell me are still better than what I am getting.
    I don't know that I have specific questions really because this car is so out of my range of understanding BUT:
    Is the mileage all that?
    Good for the mileage I am driving daily or is it better to get a better mpg regular car?
    Any problems with the 2007, mechanical or otherwise?
    I have also heard about a lot of modifications one can make to the vehicle to "improve performance"...shed any light on that for me?
    Thanks again,
    -hh
  4. efusco
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(hisshers @ Mar 14 2007, 08:54 AM) [snapback]405342[/snapback]</div>
    For some yes, for others no. Realize also that the EPA has changed its means of determining a vehicles MPG ratings to make them more realistic and the Prius should easily meet or exceed those numbers for almost all drivers. Take a look at greenhybrid.com and their log of Prius mpg....It's a pretty good bell curve that should give you some idea of what 'real world' drivers get as well as high and low.
    A 15 mile commute is about what I have (14 to be specific) and that's pretty ideal to allow for full warm up and such. You don't say if it's freeway, rural, city or what % mix of each so it's a bit hard to say exactly what you'll get and a lot depends upon how you choose to drive the car....if you race to stop signs/lights and brake hard and late and jack-rabbit start when it changes. If you speed and pass and are and aggressive driver you'll be at the lower end of reported MPG (maybe 45mpg). If you're a cautious, speed limit obeying driver who anticipates and coasts to stops and doesn't follow other cars too closely and moderately accelerates from stops you could be in the 55mpg range.
    Individual cars, of course, have had problems, but many of the 'kinks' of the '04/'05 MY Prii have been worked out.
    There aren't really many mods to improve performance. Some of us have engine block heaters (EBH) to pre-warm the Internal Combustion Engine (ICE) on cooler days to shorten the warm-up period and improve fuel economy (FE) during the initial few minutes of the morning drive. Some of us have used foam pipe insulation to block off the grill to reduce air flow through the engine compartment to assist in heat retention in the winter. There is an EV mode modification that can be done, but I don't really consider it a mod to improve performance...I use it to do so, but in a very limited fashion.
    There are also lots of driving techniques that can help...but you really don't need to worry about those...esp. since you don't even have a Prius yet....and even after you get one I say just drive it for 15k miles or so before you worry about getting fancy.
  5. hisshers
    hisshers New Member
    Well much to my wife's chagrin, I never go over the speed limit. I am a grampa driver and proud of it! :p
    I have also read that these cars can get far more miles in the life of the car than most. Also, and this seems really stupid, but I see pics online of some major darkened glass. Is this an option Toyota offers?
  6. efusco
    19,891
    1,192
    Nixa, MO
    No tinting is all after market...your dealer might offer it as an option but having it done yourself is probably cheaper.
  7. richard schumacher
    7,663
    1,038
    United States
    In my experience, with outdoor temps between 40F and 90F city (short trips) fuel economy is >45 MPG, hwy MPG > 50. Colder and hotter weather reduces economy.
    If you buy you must remember:
    0. Read the owner's manual and heed it carefully.
    1. When the last pip on the gas gauge flashes it means "buy gas now, dammit". You *cannot* reliably estimate how much gas is left in the tank based on your last fill amount and the distance travelled since. Many tales of woe are posted here by those who did not know or chose to ignore this basic fact of Prius life.
    2. The main ("traction"/drive system) battery is cooled using cabin air. Do not shut off the A/C in hot weather in a mistaken attempt to improve fuel economy; it can actually hurt fuel economy because a hot battery performs less well.
  8. hisshers
    hisshers New Member
    OOOh that is good to know. I don't tolerate heat real well and always have AC on. Must also say that rarely does my gas light even come on so that should not be a problem!
    Great comments, all!
    -hh
  9. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    Short trips do tend to reduce fuel efficiency, but FE should still be well above almost any other car you could buy.
    No mods are necessary to get a good experience from a Prius. I've considered the EV button mod, and will probably do it eventually, but only use it for very limited things like moving in a parking lot, or cruising the last few hundred meters to my house when I take the uphill approach.
    I'm 6' tall and don't find the car uncomfortable. I did add a simple over-the-fabric lumbar support to the driver's seat, but I would do that in almost any car. For comparison, I feel just a little cramped for headroom in my Camry.
    Pros:
    Low emissions
    CVT Transmission
    Smart Key (one of my favorites!)
    Good fuel economy (I still wish for better though)
    Lots of fun gadgets, mostly well integrated and non-distracting to the driver... for example, the A/C system is more advanced and easier to operate than any other car I've seen, right from the steering wheel.
    Cons:
    umm....
    ummm.....
    I know there are one or two things that have bothered me momentarily, but no more little quirks than any other car I've driven.
    Oh yeah, and one person mentioned the funny old-school clock in the dash, rather than integrated into the display screen. I guess that's a con :)
  10. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    I'm 6'4" and have a 34" inseam, so leg room is a potential issue for me. But the Prius' is adequate. My only complaint about seating comfort is the same as Evan's: suboptimal thigh support. I haven't gone as far as using an extra cushion like he does because it doesn't cause a problem in daily driving. It's more an issue on long trips, but breaks every hour or two help. I just wish the car had a vertical adjustment for the seat bottom, even if it's a simple mechanical one like my fiancee's Corolla has.
    You've gotten good information from Evan and others on fuel economy. Also like Evan, I have an engine block heater and I've blocked my front grill. The grill has been blocked throughout the winter, but the heater was just installed 10 days ago. I've maintained FE in the mid-50s and higher through the winter mainly by modifying my driving technique to take full advantage of the Prius hybrid system.
  11. Priapus
    Priapus Alter Ego
    Far-North Chicagoland
    Hey, welcome to Priuschat. So far you've picked up a few good tidbits. For an example of real-world mileage, please check the mileage logs availble at http://www.chicagopriusgroup.com. You will find other things about the Prius there as well. I've tried to make the site enlightening for both Prius owners and people smiply interested in the Prius without bombarding the reader with details.
    Additionally, depending on where in Ohio you live, perhaps a Priuschat member would be willing to give you a test drive and more hands-on opportunities.
  12. MacDude
    MacDude Junior Member
    71
    Bonny Doon, CA
    Hi there and welcome!
    I'm just shy of 6'5" and the only thing that I can say is that occasionally I have to lean forward a bit to see overhead stop lights if I'm first or second in line. I even fit in the back seat (important because my 14-year-old son is closing in on 6' and already has bigger feet than I do.)
    I tried to fit in the Honda hybrid and there was no way I was gonna last more than an hour or so. My son wouldn't fit in the back and neither would my wife (who is 5'10").
  13. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(efusco @ Mar 14 2007, 06:46 AM) [snapback]405338[/snapback]</div>
    Let me add, mediocre handling, lack of sound insulation (most noticeable at highway speeds) and the worst OEM tires I have had on any car I had owned since my 1967 Dodge Dart.
  14. brick
    brick Active Member
    1,083
    78
    Upstate NY
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Mar 14 2007, 03:09 PM) [snapback]405556[/snapback]</div>
    I think handling issues and the tires go hand-in-hand. Change the tires, get more traction, experience better handling. My snow tires (soft, sticky, and one size wider) seem to be be better in corners. But braking performance seems pretty good to me, and I think that's most important unless you're trying to set a lap record. I now realize that those snow tires were doing a number on my fuel economy, too. But it beats getting stuck!
    Noise may not be an issue for the OP depending on how his Element compares to the 2002 Accord that I was driving before the Prius. That thing was loud on the highway and especially in the rain. It was as if Honda decided not to use any sound deadening at all. The Prius is quieter than that car was. But it's not in the same league as something like a big Lexus, which is kind of like driving a cloud.
    I don't know. I'm 6'1 and I like mine. I commute 17 miles on 70% back roads, 30% 65mph highway, and drive plenty of highways on the weekend. Average since buying in December is just shy of 50mpg with conservative but reasonable driving. Doing 58mpg this week since morning temps got above freezing.
  15. jgills240
    jgills240 Member
    190
    Palmdale, CA
    I'm 6'1" and my only issue with fit is that the steering wheel needs to be adjustable toward the driver, not just up and down. although i've gotten used to it in less than a month, and don't even notice it anymore.
    Mediocre handling - I'm not doing any 4+ G turns, but I have noticed no lack of handling.
    The armrests should be higher & more padded.
    oh, and the shifter should be up for Drive and down for Reverse. just makes more sense.
    Other than that, I absolutely love it!
  16. hisshers
    hisshers New Member
    How are they in the snow?
  17. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    <div class='quotetop'>QUOTE(hisshers @ Mar 14 2007, 04:17 PM) [snapback]405643[/snapback]</div>
    To say that there is much disagreement on the performance of the Prius in the snow is a gross understatement. There are some (myself included) that have been amazed at how well the Prius performs with its stock tires. However, I should point out that I'm not in a serious winter climate. Southern New England certainly gets snow and ice, but it's nothing near the level that other places get. The consensus from most people in places that get real winters is that, with the stock tires, the Prius is anywhere from "OK" to "bad" in the snow. However, with decent tires, most people are pleasantly surprised about how the Prius does in the snow, even in those places. I should point out that these "decent tires" are not necessarily snow tires, although snow tires obviously help even more.
    One thing to realize is that the car does have relatively low clearance between the bottom and the ground. This means that it is definitely possible to "bottom out" the car in deepish snow. But this is no more true than on many other sedans.
    Some people complain about the so-called overly-aggressive traction control making winter driving impossible. I have never had a problem with this. Our car (again, with stock tires) has performed admirably in the snow that we get here.
  18. pewd
    pewd Clarinet Dude
    331
    Dallas, Texas
    I'm 6'5" - its a bit tight around the knees- have to be careful getting in and out.
    I occassionally hit the shift lever with my knees - I wish it was 2" higher.
    Try another (longer) test drive - get in and out several times - make sure its going to work for you.
    I'm averaging 48mpg - its going up as the weather continues to warm up.
    The last tank was 50mpg.
    About triple the mileage of the jeep I traded in. For that, I'll put up with the tight leg room.
  19. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(brick @ Mar 14 2007, 12:37 PM) [snapback]405572[/snapback]</div>
    No lap records, just the ability to safely complete emergency avoidance maneuvers without losing control.
  20. brick
    brick Active Member
    1,083
    78
    Upstate NY
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Mar 14 2007, 07:44 PM) [snapback]405716[/snapback]</div>
    Ehh...I still don't think the Prius is lacking anything important. What we experience in a Prius is a fair bit of body lean as a result of the soft-ish suspension. At the absolute handling limits you will get understeer and the sound of tires squealing, which is an engineered response to tell the driver "Hey, I can't hang on much longer!" If I modified your suspension with some stiffer springs and a set of 30mm sway bars you would probably interpret the experience as "better handling." In reality all I would have done for you is remove the tactile feedback (body lean and progressive understeer at the limits) and replaced them with a nasty surprise at the end, which is a sudden loss of grip and a probable loss of control. Again, the true handling limits will come down to your tires, and again I agree that you can do much better than stock in that respect. But I assure you, the car has what you need to maintain control in an emergency avoidance maneuver provided that you do have clear space into which to steer.
